Home » Eclipse Projects » Eclipse 4 » PreDestroy not called
PreDestroy not called [message #1272155] Mon, 17 March 2014 03:49 Go to next message
I've created a the following Xtend-class in my e4 application, that runs in compat mode:
@Creatable
class FileProvider {
	@Inject
	Logger logger
	@Inject
	new() {
	         // CALLED
	@PostConstruct
	def initialize() {
                // CALLED
	@PreDestroy
	def cleanup() {
		// NOT CALLED
I added it via ContextInjectionFactory.make(FileProvider.class, context);. The package javax.annotation (1.1.0) is also specified in the manifest.
Has anyone an idea what might cause this?
Best regards and thanks for any kind of help.
Bastian
Re: PreDestroy not called [message #1272298 is a reply to message #1272155] Mon, 17 March 2014 11:16 Go to previous messageGo to next message
did you dispose the context?
To
On 17.03.14 00:49, Bastian Wagenfeld wrote:
> in compat mode: @Creatable
> @Inject
> Logger logger
> @Inject
> new() {
> // CALLED
> @PostConstruct
> def initialize() {
> // CALLED
> @PreDestroy
> def cleanup() {
> // NOT CALLED
> manifest.
> Bastian
Re: PreDestroy not called [message #1272538 is a reply to message #1272298] Tue, 18 March 2014 02:31 Go to previous messageGo to next message
Hi Thomas,
not that I'd know... If there isn't any other way to dispose it other than calling context.dispose(), I did not.
Best regards
Bastian
Re: PreDestroy not called [message #1272565 is a reply to message #1272538] Tue, 18 March 2014 04:10 Go to previous messageGo to next message
I have a similar (the same?) problem. My PreDestroy is also not called. I annotated my class in a similar way and used the correct make() call. When calling context.dispose(), the disposal is triggered, but no PreDestroy is called.
Please shed some light in here because I want to use it "the correct way".
EDIT: Turned out that I forgot javax.annotation in the "Imported packages." It works now.
[Updated on: Tue, 18 March 2014 05:34] by Moderator
Re: PreDestroy not called [message #1272687 is a reply to message #1272565] Tue, 18 March 2014 09:57 Go to previous messageGo to next message
Can you show me your Bean? If you only use postconstruct and constructor
injection you might be running into
https://bugs.eclipse.org/bugs/show_bug.cgi?id=430041
Tom
> I currently need to use a bad hack using restricted APIs where I cast my
> IEclipseContext do EclipseContext and attach an IContextDisposalListener
> via context.notifyOnDisposal().
Re: PreDestroy not called [message #1272692 is a reply to message #1272155] Tue, 18 March 2014 10:11 Go to previous message
As I already stated, I forgot to include javax.annotation in the dependencies. I added this and it now works.
Previous Topic:org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler
Next Topic:Product run differs from development run
Current Time: Wed Jul 23 04:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.05581 seconds
