Home » Eclipse Projects » Remote Application Platform (RAP) » RAP in stand-alone Equinox
RAP in stand-alone Equinox [message #127159] Sat, 04 April 2009 06:26 Go to next message
Originally posted by: seb.q.strixforge.pl
Hello!
I have for my company created several stand-alone Equinox servers.
The servers uses Web Services (Axis2) and Web UI interface. Both using
Jetty.
I just wanted to show management how good it would be to migrate the
JSP/Servlet
based GUI into using RAP. I had no problems in creating a demo app and run
it
from Eclipse, but I just can't get RAP running in s stand-alone Equinox. I
have simplified everyting
and just now I'm struggeling to get just my demo app running stand-alone
(e..g no other functionally
than just the GUI)
I have mimiced the launch config into a config.ini file. The problems I run
into are
mostly dependecies to other bundles and versioning problems, which is
strange becuase
I have used the same Eclipse SDK and the same RAP bundles as when running
from
within Eclipse. As its best I got it started somehow but then I got a
problem with SAX exceptions.
Are there any general trick, WoW that I completly have missed. I have
sucessfully run and
executed BIRT and other apps in my Equinox container, but just can't get RAP
to work.
Seb
Re: RAP in stand-alone Equinox [message #127188 is a reply to message #127159] Sat, 04 April 2009 06:53 Go to previous messageGo to next message
Hi Sebastian
maybe this [1] article will help you. If you are interest in how to
deploy RAP application as war file, read this article [2].
[1]
http://eclipsesource.com/blogs/2007/11/28/rap-deployment-par t-1-deploying-your-application-with-jetty/
[2]
http://eclipsesource.com/blogs/2007/12/07/rap-deployment-par t-2-deploying-your-application-as-a-war-file/
Best,
Ivan
Sebastian Q wrote:
> Hello!
> Jetty.
> JSP/Servlet
> it
> than just the GUI)
> into are
> strange becuase
> from
> sucessfully run and
> to work.
> Seb
Re: RAP in stand-alone Equinox [message #127214 is a reply to message #127188] Sun, 05 April 2009 04:21 Go to previous messageGo to next message
I did follow article 1 but it is somewhat outdated, so its not possible to
do exactly what is states.
Actually I think that there it is something fishy about the versioning of
the tooling and target RAP distribution, and I think
that is the reason that I can't resolve some of the bundles. I have used the
RAP versison that should be working for 3.3 and 3.4, but
to me it looks like some bundles is depending of 3.5 versions. I have to do
some futher digging to verify that however, but I need to
get this working with Equinox 3.3
Seb
"Ivan Furnadjiev" <ivan@eclipsesource.com> skrev i meddelandet
news:gr7e7p$fst$2@build.eclipse.org...
> Hi Sebastian
> maybe this [1] article will help you. If you are interest in how to deploy
> [1]
> [2]
> Best,
> Ivan
> Sebastian Q wrote:
>> Hello!
>> Jetty.
>> JSP/Servlet
>> run it
>> I have simplified everyting
>> than just the GUI)
>> run into are
>> strange becuase
>> from
>> sucessfully run and
>> RAP to work.
>> Seb
Re: RAP in stand-alone Equinox [message #127228 is a reply to message #127214] Sun, 05 April 2009 04:55 Go to previous message
Hi Sebastian,
which RAP version (target platform) do you use? What the ss command in
osgi console gives you?
Best,
Ivan
Sebastian Q wrote:
> Seb
>> Hi Sebastian
>> [1]
>> [2]
>> Best,
>> Ivan
>> Sebastian Q wrote:
>>> Hello!
>>> Jetty.
>>> JSP/Servlet
>>> run it
>>> than just the GUI)
>>> run into are
>>> strange becuase
>>> from
>>> sucessfully run and
>>> RAP to work.
>>> Seb
Previous Topic:Multi-column TreeViewer Rendering Problems (possibly a bug?)
Next Topic:Tomcat errror while starting framework using security manager
Current Time: Sat Jul 19 01:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.04665 seconds
