Home » Newcomers » Newcomers » Eclipse Arduino IDE problem(The Building file in the CDT Console)
Eclipse Arduino IDE problem [message #1271715] Sat, 15 March 2014 20:42 Go to next message
The building file in my project is :
19:59:38 **** Incremental Build of configuration Release for project Blob ****
make all
Building file: C:/Program Files (x86)/Arduino/hardware/arduino/avr/cores/arduino/avr-libc/malloc.c
Starting C compile
make: Interrupt/Exception caught (code = 0xc00000fd, addr = 0x4217b3)
19:59:38 Build Finished (took 454ms)
I'd like to move the AVR reference out of the Arduino core to a separate folder because there is an indication that there's a bug in the AVR that causes the indicated error if it's located in a folder with () in its name.
The default install folder for the AVR libraries is WinAVR-20110110.
How do I go about changing the location of the Building file?
Please be as detailed as you can. I'm very new at working with Eclipse.
Re: Eclipse Arduino IDE problem [message #1271915 is a reply to message #1271715] Sun, 16 March 2014 11:51 Go to previous messageGo to next message
> Blob ****
> make all Building file: C:/Program Files
> Starting C compile
The Eclipse IDE is created by the Eclipse community at eclipse.org.
However, there are innumerable projects, such as Arduino, that use
Eclipse, but are not Eclipse.
For help with C/C++ programming on Eclipse, see the Eclipse CDT forum.
For help with Arduino-related problems, check out Arduino resources.
Re: Eclipse Arduino IDE problem [message #1271942 is a reply to message #1271915] Sun, 16 March 2014 13:11 Go to previous messageGo to next message
Actually I believe it's properly something for the Eclipse forum somewhere rather than for something related more to the Arduino community because what I want to do is to employ the AVR files in my WinAVR-20110110 folder. When I try to include this folder in the "includes" of my project I get an error indicating that the folder is inaccessible.
I don't understand why I cannot include this folder in my project and that's an Eclipse issue, isn't it?
Re: Eclipse Arduino IDE problem [message #1271960 is a reply to message #1271942] Sun, 16 March 2014 14:28 Go to previous messageGo to next message
Re: Eclipse Arduino IDE problem [message #1271980 is a reply to message #1271960] Sun, 16 March 2014 15:54 Go to previous message
> inaccessible.
It's not at all improper to ask. I hope someone can answer you in this
forum. Best of luck!
Cheers.
Previous Topic:Source Code
Next Topic:Setting up default project setup preferences
Current Time: Mon Jul 21 03:13:06 EDT 2025
Powered by FUDForum. Page generated in 0.33137 seconds
