Home » Eclipse Projects » Equinox » The state indicates the bundle is resolved?
The state indicates the bundle is resolved? [message #125672] Mon, 09 February 2009 10:05 Go to next message
Hi All,
I left Eclipse running over the weekend and my machine got rebooted. When
I tried to start it again this morning the Ganymede splash appeared and
then it seemed to hang. Nothing was written to the workspace log but I
found the information below in a timestamped log in the configuration
directory.
Can anyone tell me what has caused this issue? I had no option by to
reinstall.
TIA,
Miles
!SESSION 2009-02-09 09:02:45.816
eclipse.buildId=M20080911-1700
java.version=1.6.0_10
Framework arguments: -refresh -plugincustomization
C:\dev\tools\eclipseide\3.4qa\eclipse\configuration\msde-glo bal-eclipse-prefs.ini
-showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -refresh -clean
-data C:\Documents and
Settings\radcliff\MSDE\eclipseide\3.4qa\workspaces\default -showlocation
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2009-02-09 09:02:51.394
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.equinox.internal.simpleconfigurator.Activator.st art() of
bundle org.eclipse.equinox.simpleconfigurator.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.IllegalStateException: The state indicates the bundle
is resolved
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureMessage(AbstractBundle.java:1381)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.startBundles(ConfigApplier.java:317)
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.install(ConfigApplier.java:86)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:12 4)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:13 8)
at
org.eclipse.equinox.internal.simpleconfigurator.Activator.st art(Activator.java:48)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 21 more
Root exception:
java.lang.IllegalStateException: The state indicates the bundle is resolved
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: The state indicates the bundle is resolved? [message #125747 is a reply to message #125672] Tue, 10 February 2009 13:01 Go to previous messageGo to next message
Has anyone else seen this issue?
Miles
Re: The state indicates the bundle is resolved? [message #125759 is a reply to message #125672] Tue, 10 February 2009 13:21 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
If this ever happens again, you can try running with the -clean command
line option to see if it will recover without requiring a re-install.
Hope this helps,
Eric
On 2/9/2009 10:05 AM, Miles Daffin wrote:
> Hi All,
> When I tried to start it again this morning the Ganymede splash appeared
> and then it seemed to hang. Nothing was written to the workspace log but
> I found the information below in a timestamped log in the configuration
> directory.
> reinstall.
> TIA,
> Miles
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> -showlocation
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> bundle is resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 21 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: The state indicates the bundle is resolved? [message #125968 is a reply to message #125759] Thu, 19 February 2009 06:09 Go to previous messageGo to next message
Hi Eric,
I always start eclipse with -clean. From the original message:
>> C:devtoolseclipseide3.4qaeclipseconfigurationmsde-global-ecl ipse-prefs.ini
>> -showlocation
>> -data C:Documents and
>> SettingsradcliffMSDEeclipseide3.4qaworkspacesdefault -showlocation
This is happening to increasing numbers of users at my firm. They are all
being forced to reinstall. Some people are having to reinstall once a
week. This did not used to happen with 3.3.
Any more ideas?
Miles
Re: The state indicates the bundle is resolved? [message #126089 is a reply to message #125968] Fri, 20 February 2009 10:16 Go to previous messageGo to next message
On 2/19/2009 6:09 AM, Miles Daffin wrote:
> Hi Eric,
>> command line option to see if it will recover without requiring a
>> re-install.
>>> -showlocation
> all being forced to reinstall. Some people are having to reinstall once
> a week. This did not used to happen with 3.3.
> Any more ideas?
Other than to say that I've been using 3.4 for a year now, and the rest
of my team for several months and none of us has experienced a need to
re-install.
Of course Eclispe 3.4 is used by tens of thousands of people every day
for at least the past year. If Bugzilla doesn't have any related bugs
reported, I'd suggest that there might be something that everyone on
your team is doing similarly or some specific setup that causes problems
- I don't know.
Sorry, but this is not a widely reported issue (unless I've missed it in
my quick Bugzilla search).
<shrug>
Eric
Re: The state indicates the bundle is resolved? [message #126280 is a reply to message #126089] Mon, 23 February 2009 12:30 Go to previous messageGo to next message
Do you know what the error means?
Under what circumstances would this exception be thrown and what are the
possible causes?
Miles
Re: The state indicates the bundle is resolved? [message #126304 is a reply to message #126280] Mon, 23 February 2009 14:17 Go to previous messageGo to next message
On 2/23/2009 12:30 PM, Miles Daffin wrote:
>> in my quick Bugzilla search).
No, but a stack trace would likely give enough information to start
investigating. If you have a stack trace, open a bug report with as much
information as possible, including the stack.
BTW, using -clean to start Eclipse every time is really not necessary
and will make it a lot slower to start up each time.
Eric
Re: The state indicates the bundle is resolved? [message #127180 is a reply to message #125747] Sat, 07 March 2009 18:33 Go to previous message
Just for the records: Yes, I remember seeing this error.
However, I gave up on reporting every p2 bug I observed,
I simply don't have the time to write all those reports...
So I don't have any details on when and where it happened.
sorry nothing to help spot the cause of this error,
Stephan
Previous Topic:Simple question about bundle registration
Next Topic:P2 Software Update UI shows .qualifier, but Help/About does not
Current Time: Tue Sep 16 04:03:46 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
