RTF Presentation [message #1271245] |
Fri, 14 March 2014 12:16  |
I installed the ProR essentials in a stand-alone ProR application. I followed the directions at www.formalmind.com/en/blog?page=2 all the way to the point where you open the presentation configuration and "From the "Select Action..." dropdown, select "Rtf"".
Problem is, Rtf doesn't show up in the list. I get Headline, Linewrap, Keyword, Id, Linkmanagement, and Highlight. I can see that the "ProR Xhtml Rtf Presentation Feature" is installed. I have version 0.9.0.20131011111617.
Anyone have any suggestions?
Thanks!
Re: RTF Presentation [message #1300836 is a reply to message #1299292] |
Thu, 17 April 2014 17:07  |
I made some further test and trials. Unfortunately without success...
I installed the last Eclipse version 4.3.2, then add the ProR, then added the "formalmind" "essentials"... nothing, no way to have RTF presentation available.
I tried also downloading the ProR standalone (last version that seems to be the 0.9 as long as a previous ones - I tried 0.6.1, the oldest available from the web site), but in this case I'm not even able to install "essentials" due to a conflict (system says that I have version 0.9 or 0.6 while there's need to have 0.10 to have "essentials" package installed. When I try to upgrade ProR system says there's a conflict of versions and 0.10 can not be installed because there's already a previous version installed. I don't see any way to upgrade.
Any chance to install previous version of "essentials" ? It seems that with update.formalmind.com/essentials I can get only the last version. Is there a possibility to find previous versions if I want to try also previous version of ProR (that do not work with "essentials" 0.10) ?
I'm not an expert of Eclipse and its package installation and it's frustrating to not be able to have it running.
Thanks for any suggestion or help.
Best regards. P.
FUDForum. Page generated in 0.03521 seconds
