Home » Modeling » Epsilon » // Comments cause remainder of EGL document to be ignored
// Comments cause remainder of EGL document to be ignored [message #12662] Mon, 16 February 2009 11:22 Go to next message
It seems that using // for line comments in EOL causes the remainder of
an EGL file to be ignored from that position. This is an easy mistake to
make, as the actual comment format is not document for EOL (or have I
overlooked something?)
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to ECMDA-FA 2009, the 5th European Conference on
Model-Driven Architecture Foundations and Applications.
http://www.ecmda-fa.org/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Re: // Comments cause remainder of EGL document to be ignored [message #12685 is a reply to message #12662] Mon, 16 February 2009 11:28 Go to previous messageGo to next message
Hi Steffen,
This should be indicated with an error marker in the editor... Could you
please file a bug report for this?
Dimitris
Steffen Zschaler wrote:
> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #12706 is a reply to message #12662] Tue, 17 February 2009 05:48 Go to previous messageGo to next message
Bug report filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=265127
Steffen
> of an EGL file to be ignored from that position. This is an easy
> mistake to make, as the actual comment format is not document for EOL
> (or have I overlooked something?)
> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #12793 is a reply to message #12706] Tue, 17 February 2009 07:00 Go to previous messageGo to next message
Hi Steffen,
Thanks for filing the bug report. This has now been fixed but I can't
seem to be able to commit to the SVN at the moment. I'll let you know
once I do.
Dimtiris
> Steffen
>> Hi,
>> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #13505 is a reply to message #12793] Tue, 17 February 2009 10:20 Go to previous message
Hi Steffen,
Still no luck with the SVN (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265156) but I noticed your
comment on the syntax for comments in EOL and EGL :)
In EOL, the syntax is -- for single line comments and -* *- for
multi-line comments. In EGL on the other hand, you can still comment out
individual EOL statements using the EOL comments but you can also
comment out entire EGL parts including both dynamic and static text
using [* *]. I'll add this to the book shortly.
Dimitris
Dimitris Kolovos wrote:
> Hi Steffen,
> once I do.
> Cheers,
> Dimtiris
>> Steffen
>>> Hi,
>>> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #565379 is a reply to message #12662] Mon, 16 February 2009 11:28 Go to previous message
Hi Steffen,
Dimitris
> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #565399 is a reply to message #12662] Tue, 17 February 2009 05:48 Go to previous message
Steffen
> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #565493 is a reply to message #12706] Tue, 17 February 2009 07:00 Go to previous message
Hi Steffen,
once I do.
Dimtiris
> Steffen
>> Hi,
>> Steffen
Re: // Comments cause remainder of EGL document to be ignored [message #565675 is a reply to message #12793] Tue, 17 February 2009 10:20 Go to previous message
Hi Steffen,
Dimitris
> Hi Steffen,
> once I do.
> Cheers,
> Dimtiris
>> Steffen
>>> Hi,
>>> Steffen
Previous Topic:re. Wishlist...
Next Topic:[Eugenia] Including certain GMF options?
Current Time: Sat Nov 08 23:24:10 EST 2025
Powered by FUDForum. Page generated in 0.15665 seconds
