Home » Eclipse Projects » Eclipse Scout » Get old value of radio button group after/while changing
Get old value of radio button group after/while changing [message #1269862] Wed, 12 March 2014 05:10 Go to next message
Is there a Scout method (like execChangedValue()) in the AbstractRadioButtonGroup which presents the old selected value in the radio button group after/while changing the selected value?
Re: Get old value of radio button group after/while changing [message #1270035 is a reply to message #1269862] Wed, 12 March 2014 08:31 Go to previous messageGo to next message
I don't think such a method exists. For other field types I have seen/used code similar to (untested code, just wrote it from scratch):
public class MyRadioButtonGroup extends AbstractRadioButtonGroup<Integer> {
  private Integer myOldValue;
  public class RadioButton1 extends AbstractRadioButton {
    protected Object getConfiguredRadioValue() {
      return Integer.valueOf(1);
  public class RadioButton2 extends AbstractRadioButton {
      return Integer.valueOf(2);
  protected void execChangedValue() throws ProcessingException {
    super.execChangedValue();
    if(myOldValue > getValue()) {
      // do something
    // last line of code for this method
    myOldValue = getValue();
If the button group has an initial value (or the value is changed by other methods) of course the variable myOldValue should also be set there.
[Updated on: Wed, 12 March 2014 08:32] by Moderator
Re: Get old value of radio button group after/while changing [message #1270073 is a reply to message #1269862] Wed, 12 March 2014 09:10 Go to previous message
AbstractRadioButtonGroup extends from AbstractValueField so you'll have access to all methods for value setting/validation.
As an example you might use execValidateValue to compare old value to the value being set
Previous Topic:SWT Rendering inner Group Box on a Custom Field
Next Topic:FileChooser in RAP
Current Time: Sat Jul 26 09:37:37 EDT 2025
Powered by FUDForum. Page generated in 0.05437 seconds
