Cannot insert to 'path' field in Postgres db using EclipseLink [message #1270048] |
Wed, 12 March 2014 08:48  |
I'm not sure if this is the right place for this question, but I have a java app running in JBoss that uses EclipseLink to persist to a Postgres database. I've added a field with a 'path' datatype to one of the tables but I keep getting the following exception when I try to insert data:
org.postgresql.util.PSQLException: Can't infer the SQL type to use for an instance of org.postgresql.geometric.PGpath. Use setObject() with an explicit Types value to specify the type to use.
Here's the table definition:
CREATE TABLE schema.table_name
item_id uuid NOT NULL,
item_path path NOT NULL
The java entity is representing the item_path field as a List<Point> object, and I'm using a converter to map from the List<Point> object to a PGpath object:
import org.eclipse.persistence.mappings.DatabaseMapping;
import org.eclipse.persistence.mappings.converters.Converter;
import org.eclipse.persistence.sessions.Session;
import org.postgresql.geometric.PGpath;
import java.awt.Point;
import java.util.ArrayList;
import java.util.List;
import static java.sql.Types.OTHER;
public class PgPathConverter implements Converter
public boolean isMutable ()
return false;
public List<Point> convertDataValueToObjectValue (Object value, Session session)
// Code that converts PGpath to List<Point>
public PGpath convertObjectValueToDataValue (Object value, Session session)
// Code that converts List<Point> to PGpath
public void initialize (DatabaseMapping mapping, Session session)
mapping.getField ().setSqlType (OTHER);
The entity class is defined as follows:
@Entity
@Table (
name = "table_name",
schema = "schema"
@Converter (
name = "path",
converterClass = PgPathConverter.class
public class TableName
public TableName () {}
private static final long serialVersionUID = 1L;
@Column (name = "item_path")
@Convert ("path")
private List<Point> m_ItemPath;
@Id
@Column (
name = "item_id",
unique = true,
nullable = false
private UUID m_ItemId;
public UUID getItemId ()
return m_ItemId;
public List<Point> getItemPath ()
return m_InkPath;
public void setItemId (UUID itemId)
m_ItemId = itemId;
public void setInkPath (List<Point> itemPath)
m_ItemPath = itemPath;
Finally, here's the exception I get when I call `EntityManager.persist (entity)`:
18:10:33,789 ERROR [org.jboss.as.ejb3] (http-/0.0.0.0:8080-1) javax.ejb.EJBTransactionRolledbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.postgresql.util.PSQLException: Can't infer the SQL type to use for an instance of org.postgresql.geometric.PGpath. Use setObject() with an explicit Types value to specify the type to use.
Error Code: 0
Call: INSERT INTO schema.table_name (item_id, item_path) VALUES (?, ?)
bind => [2 parameters bound]
18:10:33,789 ERROR [org.jboss.as.ejb3.invocation] (http-/0.0.0.0:8080-1) JBAS014134: EJB Invocation failed on component TableNameRepository for method public void com.mycompany.myproject.data.Repository.flush() throws javax.persistence.TransactionRequiredException,javax.persistence.PersistenceException: javax.ejb.EJBTransactionRolledbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 0
Call: INSERT INTO schema.table_name (item_id, item_path VALUES (?, ?)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.handleInCallerTx(CMTTxInterceptor.java:138) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInCallerTx(CMTTxInterceptor.java:228) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.tx.CMTTxInterceptor.required(CMTTxInterceptor.java:317) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:214) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:288) [jboss-invocation-1.1.1.Final-redhat-2.jar:1.1.1.Final-redhat-2]
at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.component.interceptors.ShutDownInterceptorFactory$1.processInvocation(ShutDownInterceptorFactory.java:64) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:59) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50) [jboss-as-ee-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:55) [jboss-as-ejb3-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ee.component.TCCLInterceptor.processInvocation(TCCLInterceptor.java:45) [jboss-as-ee-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:61) [jboss-invocation-1.1.1.Final-redhat-2.jar:1.1.1.Final-redhat-2]
at org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:165) [jboss-as-ee-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ee.component.ViewDescription$1.processInvocation(ViewDescription.java:182) [jboss-as-ee-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ee.component.ProxyInvocationHandler.invoke(ProxyInvocationHandler.java:72) [jboss-as-ee-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
Re: Cannot insert to 'path' field in Postgres db using EclipseLink [message #1271290 is a reply to message #1270202] |
Fri, 14 March 2014 14:54  |
Turns out that it was a problem with how I had configured my application in JBoss. I had multiple copies of the jdbc driver jar, one in the deployed EAR file and one in the JBoss container. This was causing confusion because each jar was being loaded by a separate ClassLoader. Java identifies the class by its full name AND the ClassLoader.
Since I had already added the driver jar as a module to the JBoss server, I needed to remove the driver jar from the deployed EAR and set a dependency to the module that was in the JBoss server.
FUDForum. Page generated in 0.03405 seconds
