Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Integrate EMF Compare in Subversion
| Integrate EMF Compare in Subversion [message #126975] |
Thu, 10 July 2008 05:00   |
Eclipse User  |
Originally posted by: schlichtomat.gmx.de
Hi! I got a question and it would be great if anyone could help me out
with this one: Is there a way to use EMF Compare as differencing and merge
tool in subversion? I did not find anything in the web, yet. I'm wondering
if this would be useful (this is what I think) and if so, I'm looking for
an existing integration.
| Re: Integrate EMF Compare in Subversion [message #130370 is a reply to message #130354] |
Tue, 21 October 2008 03:14   |
Eclipse User  |
--------------010104010006050808000702
Thanks Sudhakar,
We'll try to handle this issue asap.
Laurent Goubet
Obeo
Sudhakar a écrit :
> Logged bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=251456
> Thanks
> -sud
> laurent Goubet wrote:
>> Hi Sudhakar,
>> We've has many issues with the genmodel comparison ... something must
>> be wrong in the way we load it. Can you fill a bug with your stack
>> trace so that we remember this has to be fixed?
>> Laurent Goubet
>> Obeo
>> Sudhakar a écrit :
>>> I just noticed that this bug occurs when you compare a genmodel file
>>> even with it's local history. So this may rule out any issue with
>>> Suversion/Subclipe and place the issue in the Eclipse file versioning
>>> code. This is verified on Eclipse 3.4.1
>>> -sud
>>> Sudhakar wrote:
>>>> I've verified that EMF Compare works when comparing workspace .ecore
>>>> files against those stored in subversion.
>>>> But when I attempt to compare a workspace .genmodel file against
>>>> that in subversion I get several NPE. I'm using subclipse 1.4.5 with
>>>> EMF Compare 0.8.1. If I compare the two .genmodel files stored in my
>>>> workspace I don't get these NPEs.
>>>> Here is the stack trace:
>>>> !ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.484
>>>> !MESSAGE Problems occurred when invoking code from plug-in:
>>>> "org.eclipse.jface".
>>>> !STACK 0
>>>> java.lang.NullPointerException
>>>>     at
>>>>  org.eclipse.emf.codegen.ecore.genmodel.impl.GenDataTypeImpl. getQualifiedInstanceClassName(GenDataTypeImpl.java:212)
>>>>     at
>>>>  org.eclipse.emf.codegen.ecore.genmodel.provider.GenDataTypeI temProvider.getText(GenDataTypeItemProvider.java:120)
>>>>     at
>>>>  org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:374)
>>>>     at
>>>>  org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText (WrappedViewerLabelProvider.java:108)
>>>>     at
>>>>  org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:164)
>>>>     at
>>>>  org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
>>>>     at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>>>>     at org.eclipse.core.runtime.Platform.run(Platform.java:880)
>>>>     at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
>>>>     at  org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
>>>>     at
>>>>  org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
>>>>     at
>>>>  org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2041)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:827)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
>>>>     at
>>>>  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
>>>>     at
>>>>  org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1702)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1712)
>>>>     at
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1054)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1035)
>>>>     at
>>>>  org.eclipse.jface.viewers.AbstractTreeViewer.expandAll(Abstr actTreeViewer.java:1024)
>>>>     at
>>>>  org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.inputChanged(ModelContentMergeDiffTab.java: 364)
>>>>     at
>>>>  org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
>>>>     at
>>>>  org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
>>>>     at
>>>>  org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.setReflectiveInput(ModelContentMergeDiffTab .java:278)
>>>>     at
>>>>  org.eclipse.emf.compare.ui.viewer.content.part.ModelContentM ergeTabFolder.setInput(ModelContentMergeTabFolder.java:310)
>>>>     at
>>>>  org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.updateContent(ModelContentMergeViewer.java:675)
>>>>     at
>>>>  org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in ternalRefresh(ContentMergeViewer.java:715)
>>>>     at
>>>>  org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in putChanged(ContentMergeViewer.java:615)
>>>>     at
>>>>     at
>>>>  org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.setInput(ModelContentMergeViewer.java:281)
>>>>     at
>>>>  org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:256)
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput.internalSetContentPan eInput(CompareEditorInput.java:791)
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput.access$7(CompareEdito rInput.java:789)
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput$13.run(CompareEditorI nput.java:729)
>>>>     at
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput.feed1(CompareEditorIn put.java:723)
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput.feedInput(CompareEdit orInput.java:701)
>>>>     at
>>>>  org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:524)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:415)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareEditor.createPartControl (CompareEditor.java:379)
>>>>     at
>>>>  org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
>>>>     at
>>>>  org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
>>>>     at
>>>>  org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
>>>>     at
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
>>>>     at
>>>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2635)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareUIPlugin$1.run(CompareUI Plugin.java:454)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareUIPlugin.syncExec(Compar eUIPlugin.java:1171)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareUIPlugin.internalOpenEdi tor(CompareUIPlugin.java:465)
>>>>     at
>>>>  org.eclipse.compare.internal.CompareUIPlugin.openCompareEdit or(CompareUIPlugin.java:429)
>>>>     at
>>>>  org.eclipse.compare.CompareUI.openCompareEditorOnPage(Compar eUI.java:135)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.CompareWithRemote Action$1.run(CompareWithRemoteAction.java:57)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.repository.RepositoryMana ger.run(RepositoryManager.java:375)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(S VNAction.java:226)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(S VNAction.java:235)
>>>>     at
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:232)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.CompareWithRemote Action.execute(CompareWithRemoteAction.java:53)
>>>>     at
>>>>  org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:56)
>>>>     at
>>>>  org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
>>>>     at
>>>>  org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
>>>>     at
>>>>  org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
>>>>     at
>>>>  org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
>>>>     at
>>>>  org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
>>>>     at  org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>>>>     at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
>>>>     at
>>>>  org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
>>>>     at
>>>>  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
>>>>     at
>>>>  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
>>>>     at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
>>>>     at  org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
>>>>     at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
>>>>     at
>>>>  org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
>>>>     at
>>>>  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
>>>>     at
>>>>  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>>>>     at
>>>>  org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
>>>>     at
>>>>  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
>>>>     at
>>>>  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>>>>     at
>>>>  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>>>>     at
>>>>  org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
>>>>     at
>>>>  org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>>>>     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>>     at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>>>     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>>>     at java.lang.reflect.Method.invoke(Unknown Source)
>>>>     at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
>>>>     at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
>>>>     at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
>>>> !ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.703
>>>> !STACK 0
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> !ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.781
>>>> !STACK 0
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> Cédric Brun wrote:
>>>>> Hi Marco,
>>>>> EMF compare is, indeed, already integrated with Subversion if
>>>>> you're using a an plugin providing Eclipse integration with
>>>>> Subversion (aka Subversive or Subclipse). That means for instance
>>>>> that comparing models with the team repository should trigger EMF
>>>>> Compare.
>>>>> We even have a specific plugin for Subversive correcting a few
>>>>> issues we had at some time but as we are not sure yet if it's an
>>>>> issue from our side or from the subversive implementation we did
>>>>> not build this plugin yet and it's only available on the Eclipse
>>>>> modeling CVS.
>>>>> Anyway installing an SVN plugin + EMF compare should work fine,
>>>>> please tell us if you encounter issues.
>>>>> Cédric
>>>>>> out
>>>>>> and merge
>>>>>> wondering
>>>>>> looking for
 name="laurent_goubet.vcf"
 filename="laurent_goubet.vcf"
 PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
 OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------010104010006050808000702--
| Re: Integrate EMF Compare in Subversion [message #619375 is a reply to message #126975] |
Thu, 10 July 2008 05:47   |
Eclipse User  |
Hi Marco,
EMF compare is, indeed, already integrated with Subversion if you're using a an plugin providing Eclipse integration with Subversion (aka Subversive or Subclipse). That means for instance that comparing models with the team repository should trigger EMF Compare.
We even have a specific plugin for Subversive correcting a few issues we had at some time but as we are not sure yet if it's an issue from our side or from the subversive implementation we did not build this plugin yet and it's only available on the Eclipse modeling CVS.
Anyway installing an SVN plugin + EMF compare should work fine, please tell us if you encounter issues.
Cédric
| Re: Integrate EMF Compare in Subversion [message #620351 is a reply to message #127013] |
Thu, 16 October 2008 12:34   |
Eclipse User  |
But when I attempt to compare a workspace .genmodel file against that in
subversion I get several NPE. I'm using subclipse 1.4.5 with EMF Compare
0.8.1. If I compare the two .genmodel files stored in my workspace I
!STACK 0
	at
	at
	at
	at
	at
	at  org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
	at
	at
	at
	at
	at
	at
	at
	at  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
	at
	at  org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
	at
	at
	at
	at
	at
	at
	at
	at  org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at  org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
	at  org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at  org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
	at
	at
	at
	at  org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
	at  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
	at  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
	at
	at
	at  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
	at
	at
	at
	at
	at
	at
!STACK 0
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
!STACK 0
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
Cédric Brun wrote:
> Hi Marco,
> Cédric
| Re: Integrate EMF Compare in Subversion [message #620352 is a reply to message #130214] |
Thu, 16 October 2008 15:19   |
Eclipse User  |
-sud
> !STACK 0
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> !STACK 0
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> !STACK 0
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> Cédric Brun wrote:
>> Hi Marco,
>> Cédric
>>> merge
>>> wondering
>>> for
| Re: Integrate EMF Compare in Subversion [message #620355 is a reply to message #130229] |
Fri, 17 October 2008 03:37   |
Eclipse User  |
--------------040202060309030609060007
Hi Sudhakar,
We've has many issues with the genmodel comparison ... something must be
wrong in the way we load it. Can you fill a bug with your stack trace so
Laurent Goubet
Obeo
> -sud
>> in subversion I get several NPE. I'm using subclipse 1.4.5 with EMF
>> !STACK 0
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> !STACK 0
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> !STACK 0
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> Cédric Brun wrote:
>>> Hi Marco,
>>> Cédric
>>>> merge
>>>> wondering
>>>> looking for
--------------040202060309030609060007--
| Re: Integrate EMF Compare in Subversion [message #620362 is a reply to message #130267] |
Mon, 20 October 2008 15:14   |
Eclipse User  |
Logged bug
-sud
> Hi Sudhakar,
> Laurent Goubet
> Obeo
>> -sud
>>> !STACK 0
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>> !STACK 0
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>> !STACK 0
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>>     at
>>> Cédric Brun wrote:
>>>> Hi Marco,
>>>> modeling CVS.
>>>> Cédric
>>>>> and merge
>>>>> wondering
>>>>> looking for
| Re: Integrate EMF Compare in Subversion [message #620363 is a reply to message #130354] |
Eclipse User  |
Thanks Sudhakar,
Laurent Goubet
Obeo
Sudhakar a écrit :
> Logged bug
> Thanks
> -sud
>> Hi Sudhakar,
>> Laurent Goubet
>> Obeo
>>> -sud
>>>> !STACK 0
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> !STACK 0
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> !STACK 0
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> Cédric Brun wrote:
>>>>> Hi Marco,
>>>>> Compare.
>>>>> modeling CVS.
>>>>> Cédric
>>>>>> out
>>>>>> and merge
>>>>>> wondering
>>>>>> looking for
 Current Time: Mon Nov 03 22:09:38 EST 2025
 Powered by  FUDForum. Page generated in 0.09013 seconds
