Home » Modeling » TMF (Xtext) » Cross reference with the same name
Cross reference with the same name [message #1269354] Tue, 11 March 2014 15:11 Go to next message
Hi guys, i need to do a model like this
Relationships
Vp1 : V1;
Vp2 : V2 V3 V4;
Constraints
V1 require V2
V2 require Vp1
Vp1 require Vp2
And my Grammar is like this
Model:
	'Relationships'
	a+=ElementA*
	'Constraints'
	c+=Constraint*
Constraint:
	c1=[ElementA] 'require' c2=[ElementB] |
	c1=[ElementB] 'require' c2=[ElementA] |
	c1=[ElementB] 'require' c2=[ElementB]
ElementB:
	name=ID
ElementA:
	name=ID ':' b+=ElementB ';'
I have had problems because the name of elements are equals:
warning(200): ../org.ovm.ui/src-gen/org/ovm/ui/contentassist/antlr/internal/InternalOvm.g:176:1: Decision can match input such as "RULE_ID 'require' RULE_ID" using multiple alternatives: 1, 2, 3
As a result, alternative(s) 3,2 were disabled for that input
error(201): ../org.ovm.ui/src-gen/org/ovm/ui/contentassist/antlr/internal/InternalOvm.g:176:1: The following alternatives can never be matched: 2,3
I have tried create two terminals with differents names, like ID1 and ID2 with same regex inside. Tried to use the operator =>. Create QualifiedNames, etc, with no success.
Here is my last hope.
Thanks in advance.
Re: Cross reference with the same name [message #1269357 is a reply to message #1269354] Tue, 11 March 2014 15:18 Go to previous messageGo to next message
parsing and lexing is done in two phases
you have to solve it like
Constraint:
c1=[Element] 'require' c2=[Element];
Element: ElementA|ElementB;
and adapt nameprovider and maybe write some checks
Re: Cross reference with the same name [message #1269369 is a reply to message #1269357] Tue, 11 March 2014 15:36 Go to previous message
Man, i don't know how to thank you. I passed many days working at this and you solved in one minute.
I will put your name in my final project.
Thank you very much.
Previous Topic:strange behavior in error marker generation
Next Topic:Tutorial Errors
Current Time: Tue Jul 22 16:57:40 EDT 2025
Powered by FUDForum. Page generated in 0.04540 seconds
