Home » Archived » Orion (Archived) » Hi(about a good tutorial)
Hi [message #1266775] Fri, 07 March 2014 18:54 Go to next message
I am fascinated by Orion so I want to provide a plugin for my own language.
I could use content assistance and it worked well. However, I could not provide a highlighter. I used documentation but it didn't work for me.
I wonder if there is a good step by step guide with a sample which shows how to highlight some specified keywords.
thanks in advance.
This is my plugin:
<!DOCTYPE html>
<html>
<head>
<script src="plugin.js"></script>
<script type="text/javascript">
/*global window eclipse*/
var provider = new eclipse.PluginProvider();
provider.registerServiceProvider("orion.edit.highlighter",
// no service methods
contentTypes: { id: "application/ump", extension: ["ump"], "extends": "text/plain"},
patterns: [
include: "orion.lib"
match: "\b(if|while|for|return)\b",
provider.connect();
</script>
</head>
<body>
</body>
</html>
[Updated on: Fri, 07 March 2014 19:04] by Moderator
Re: Hi [message #1268732 is a reply to message #1266775] Mon, 10 March 2014 19:16 Go to previous message
Hi, you need to change a couple of things (these changes are shown at the bottom):
1. The grammar's contentTypes needs to be an array of strings, a content type cannot be declared in-line here. The snippet below first registers an orion.core.contenttype for the type, and orion.edit.highlighter's contentType then just refers to it as "application/ump".
2. Your \b's need double-escaping (the first '\' escapes the second '\' in the JS string, resulting in one '\' in the string).
provider.registerService("orion.core.contenttype", {}, {
    contentTypes: [
            "extends": "text/plain",
            extension: ["ump"]
        contentTypes: ["application/ump"],
        patterns: [
                match: "\\b(if|while|for|return)\\b",
Grant
Previous Topic:Seeking editor customization advise
Next Topic:Orion editor didn't support Korean language
Current Time: Thu Nov 06 08:31:29 EST 2025
Powered by FUDForum. Page generated in 0.02664 seconds
