Home » Archived » Buckminster » Kepler Resolve & Materialize Performance-Issue(Kepler Resolve & Materialize Performance-Issue)
Kepler Resolve & Materialize Performance-Issue [message #1235013] |
Thu, 23 January 2014 05:53  |
hi,
when we update our environment from juno (eclipse project sdk 4.2.2/buckminster 1.5.0) to kepler (eclipse project sdk 4.3.1/buckminster 1.6.0)
our resolve & materialize process will take much longer than before.
juno: 1 minute 12 seconds
kepler: 8 minute 46 seconds
this resolve job contacts 300 p2 repositories via http.
does anyone notice similar behaviour?
thanks, adrian
[Updated on: Thu, 23 January 2014 06:35] by Moderator
Re: Kepler Resolve & Materialize Performace-Issue [message #1259546 is a reply to message #1248777] |
Fri, 28 February 2014 09:12   |
hi,
i think it isn't enough to just share the cquery/rmap... therefore i made an example cquery with an example p2-repository.
to test this example, just install the p2 repository in apache and run the cqery against it.
for repeatable tests, i set up an local apache in a vm, set the maximum number of resolver threads to 1 and the network settings to direct.
before every testrun i cleaned the .metadata and .buckminster directory in the workspace because of caching stuff.
the example is simple: there is a bundle named com.test.resolve, this bundle has a dependency to bundle com.test.bundle9, this bundle is located in p2 repository com.test.feature9.
the bundle com.test.bundle9 has a dependency to bundle com.test.bundle8 witch is located in p2 repository com.test.feature8... and so on until bundle1 in feature1.
test results (seconds):
juno
resolve to wizard:
test1: 2,3
test2: 1,7
resolve and materialize:
test1: 10,3
test2: 10,5
kepler:
resolve to wizard:
test1: 5,8
test2: 5,8
test1: 26,5
test2: 26,4
regards, adrian
Re: Kepler Resolve & Materialize Performace-Issue [message #1268598 is a reply to message #1259546] |
Mon, 10 March 2014 14:17   |
Hi Adrian
I cannot test it right now, but I see that your cquery contains
useMaterialization="false"
useRemoteResolution="false"
useTargetPlatform="false"
this might cause it to check the repositories each time over and over...
could you please try to remove them and see if something changes? If I
understand correctly the meaning of those flags from the documentation...
cheers
Lorenzo
On 28/02/2014 15:12, Adrian Gaberell wrote:
> hi,
> juno
> resolve to wizard:
> test1: 2,3
> test2: 1,7
> test1: 10,3
> test2: 10,5
> kepler:
> resolve to wizard:
> test1: 5,8
> test2: 5,8
> test1: 26,5
> test2: 26,4
> regards, adrian
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Kepler Resolve & Materialize Performace-Issue [message #1281708 is a reply to message #1269175] |
Tue, 01 April 2014 04:38  |
On 11/03/2014 14:35, Adrian Gaberell wrote:
> hi lorenzo,
> those flags are only used for the bundle witch is desired as source:
> <cq:advisorNode namePattern="com.test.resolve" mutableLevel="REQUIRE"
> sourceLevel="REQUIRE" useMaterialization="false"
> useRemoteResolution="false" useTargetPlatform="false"/>
> not for the ones desired as binary (com.test.(bundle|feature):
> <cq:advisorNode namePattern=".*" mutableLevel="REJECT"
> sourceLevel="REJECT" useWorkspace="false"/>
> I have chosen this pattern, because I don't want to install a
> source-repository for this simple sample where I had to expand the rmap
> with unnecessary stuff.
> the problem is, if the resolve & materialize task need to download the
> information from a p2 repository I takes much longer with the new version.
> if you have a product with a lot of different features and plugins, this
> will happens every time you run resolve & materialize, because the
> bundles in the p2 repository may change with every nightly-build.
> regards, adrian
in this case I wouldn't know... I guess only Thomas can say something
useful :)
cheers
Lorenzo
Xtext Book:
Current Time: Wed Sep 17 14:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.03762 seconds
