Home » Eclipse Projects » BPMN 2.0 Modeler » Customize a Start Event Message
Customize a Start Event Message [message #1252771] Fri, 21 February 2014 10:38 Go to next message
Hi Robert, Hi Everybody
I'm trying to customize a message start event. I looked how it is done on JBoss runtime but if we use it, we cannot create on our properties tab and so on .. so I have created a CustomTask. The associated featureContainer extends CustomShapeFeatureContainer.
I override getAddFeature and createFeatureContainer with two new classes :
CreateStartEventMessageFeature that extends AbstractCreateEventFeature<StartEvent>
and AddStartEventMessageFeature extends AddEventFeature<StartEvent>.
In the palette I see my Event, no problem but I have trouble when I drag and drop in the editor : I fall in a infinite loop.
After investigation, I see that AddStartEventMessageFeature calls add function in AddEventFeature class . In this function we have this.getFeatureProvider().getAddFeature(context).add(context);
and this call AddEventFeature.add ... So I should override the add function where the pictogram is drawn and it is a lot of works to do.
Moreover I had to override createBusinessObject in CreateStartEventMessageFeature class to add the messageEventDefinition in the startEvent. Is it the right way to customize a start event message ?
Thks a lot.
Re: Customize a Start Event Message [message #1268537 is a reply to message #1252771] Mon, 10 March 2014 12:36 Go to previous messageGo to next message
check the latest version of the bpmn2 modeler released in March, the infinite loop problem was fixed.
Regards.
Re: Customize a Start Event Message [message #1269256 is a reply to message #1268537] Tue, 11 March 2014 11:49 Go to previous message
Hi Cedric
It works well with the latest build. Thks Cedric for the advice.
and thanks a lot Robert for your works.
Previous Topic:How to access BPMN Resource
Next Topic:Infinite loop when creating a custom task
Current Time: Sat Jul 26 18:58:50 EDT 2025
Powered by FUDForum. Page generated in 0.12582 seconds
