[EMF Compare] Origin of a moved element in a 'MOVE' change! [message #1268437] |
Mon, 10 March 2014 09:57  |
Hello everyone,
I am using EMF Compare in order to have the difference model from two versions of an ecore.
I noticed that when I move a property from a class to another, let say I move property p from A to B. I cannot find the information about the origin, in my example class A. However, I do find the information that p is in B now.
I have looked into the container, but I did not find anything.
I do not think that this information does not exist in EMF Compare, may be I am missing it somewhere.
Could someone help me here please?
Best Regards.
Re: [EMF Compare] Origin of a moved element in a 'MOVE' change! [message #1270144 is a reply to message #1268437] |
Wed, 12 March 2014 10:42  |
For the sake of keeping the comparison model brief, we have not duplicated some of the info that "can be computed". Furthermore, this is not a straightforward thing to determine and even if we did set up a reference to the "origin container"... it would most likely be hard to understand as the "origin" might not always be present anymore and we decided not to reference Match elements from the differences. You might want to look at the ReferenceChangeMerger to see how we determine the needed information when merging moves, but in a nutshell, this could be determined with something similar to :
Diff moveDiff = ...;
Comparison comparison = diff.getMatch().getComparison();
EObject movedValue = moveDiff.getValue();
Match valueMatch = comparison.getMatch(movedValue);
EObject originContainer;
if (!comparison.isThreeWay()) {
originContainer = valueMatch.getLeft();
} else {
originContainer = valueMatch.getOrigin();
Basically, you should always use the "Match" elements when trying to navigate from one side to the other.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.30491 seconds
