Home » Archived » Visual Editor (VE) » adding a new "tool" to the palette
adding a new "tool" to the palette [message #126771] Thu, 22 June 2006 10:26 Go to next message
Is there a way to add a custom tool (not a bean) to the palette? From
looking at the code in JavaVisualEditorPart (where selection and marquee
(and I think Choose Bean) are added), it doesn't appear to be possible.
Ernest
Re: adding a new "tool" to the palette [message #126785 is a reply to message #126771] Thu, 22 June 2006 11:09 Go to previous messageGo to next message
See
http://www.eclipse.org/articles/Article-VE-Custom-Widget/cus tomwidget.html
For how to access the palette, and then if you want to have a custom
tool instead of the standard tools:
Instead of an AnnotatedCreationEntry, your would use a ToolEntry:
<xmi:XMI xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:palette="http:///org/eclipse/ve/internal/cde/palette.ecore"
xmlns:utility="http:///org/eclipse/ve/internal/cde/utility.ecore">
<palette:CategoryCmp>
<categoryLabel xsi:type="utility:ConstantString" string="Custom"/>
<cmpGroups xsi:type="palette:GroupCmp">
<cmpEntries xsi:type="palette:ToolEntry"
toolClassName="your.bundle.id/your.fully-qualified-tool-class "
icon16Name=" platform:/plugin/org.eclipse.ve.example.customwidget/icons/c ustom.gif ">
</cmpEntries>
</cmpGroups>
</palette:CategoryCmp>
</xmi:XMI>
The tool class must implement org.eclipse.gef.Tool
> Ernest
Rich Kulp
Re: adding a new "tool" to the palette [message #126823 is a reply to message #126785] Thu, 22 June 2006 12:53 Go to previous messageGo to next message
Excellent. Thanks very much.
Rich Kulp wrote:
> See
> xmlns:xmi="http://www.omg.org/XMI"
> </cmpEntries>
> </cmpGroups>
> </xmi:XMI>
>> marquee (and I think Choose Bean) are added), it doesn't appear to be
>> possible.
>> Thanks,
>> Ernest
Re: adding a new "tool" to the palette [message #126949 is a reply to message #126785] Fri, 23 June 2006 12:15 Go to previous messageGo to next message
I got SAX errors until I added the following line:
This line was also missing from the tutorial. Is that just an oversight?
Rich Kulp wrote:
> See
> </cmpEntries>
> </cmpGroups>
> </xmi:XMI>
>> possible.
>> Thanks,
>> Ernest
Re: adding a new "tool" to the palette [message #126963 is a reply to message #126949] Fri, 23 June 2006 13:12 Go to previous messageGo to next message
No, it's not. Soemtime in the last year since the tutorial was written,
EMF got more specific on what was required. You didn't use to need the
xmlns:xsi for it to work.
Rich Kulp
Re: adding a new "tool" to the palette [message #126976 is a reply to message #126963] Fri, 23 June 2006 14:48 Go to previous message
Ah. Well, we all get the rug pulled out from under us sometimes.
Thanks.
Re: adding a new "tool" to the palette [message #613392 is a reply to message #126771] Thu, 22 June 2006 11:09 Go to previous message
See
</cmpEntries>
</cmpGroups>
</xmi:XMI>
> Ernest
Rich Kulp
Re: adding a new "tool" to the palette [message #613395 is a reply to message #126785] Thu, 22 June 2006 12:53 Go to previous message
Rich Kulp wrote:
> See
> </cmpEntries>
> </cmpGroups>
> </xmi:XMI>
>> possible.
>> Thanks,
>> Ernest
Re: adding a new "tool" to the palette [message #613405 is a reply to message #126785] Fri, 23 June 2006 12:15 Go to previous message
Rich Kulp wrote:
> See
> </cmpEntries>
> </cmpGroups>
> </xmi:XMI>
>> possible.
>> Thanks,
>> Ernest
Re: adding a new "tool" to the palette [message #613406 is a reply to message #126949] Fri, 23 June 2006 13:12 Go to previous message
Rich Kulp
Re: adding a new "tool" to the palette [message #613407 is a reply to message #126963] Fri, 23 June 2006 14:48 Go to previous message
Thanks.
Previous Topic:Parsing Stopped working for simple visual class
Next Topic:Parsing Stopped working for simple visual class
Current Time: Thu Nov 06 20:43:35 EST 2025
Powered by FUDForum. Page generated in 0.27615 seconds
