Home » Archived » Lua Development Tools » Limited autocomplete issue on multiple globals
Limited autocomplete issue on multiple globals [message #1268179] Mon, 10 March 2014 02:43 Go to next message
it seems that I won't get completion on more then the first module global
I know it's not recommended to use globals but I'm documenting an existing lib
--bar.lua
local M = {}
---@field [parent=#global] bar#bar bar
bar = M
---@function [parent=#bar] foobar
function M.foobar()
end
return M
--foo.lua
local M = {}
---@field [parent=#global] foo#foo foo
foo = M
---@function [parent=#foo] completeme
function M.completeme()
end
return M
--main.lua
local Foo = require("foo")
local Bar = require("bar")
local function main()
Foo.completeme()
Bar.foobar()
bar.foobar()
foo.
end
main()
I get completion on Foo, Bar and bar but not on foo
using Standalone 1.1
Re: Limited autocomplete issue on multiple globals [message #1269167 is a reply to message #1268179] Tue, 11 March 2014 09:27 Go to previous messageGo to next message
Hi Tobias,
Thanks for your feedback. It's seems there is a bug somewhere, when trying to reproduce I even don't have auto-completion after the "bar.".
I have filed a bug for this, feel free to follow it and comment it if you find more informations about the cases when this bug appears.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=430089
Marc
Re: Limited autocomplete issue on multiple globals [message #1269425 is a reply to message #1269167] Tue, 11 March 2014 17:32 Go to previous message
yeah thx for confirmation
I can get completion for the first module global I make not for any following. In the given example I could get completion on foo instead of bar the other day but before posting and retrying I only could get it on bar. strange that you won't get completion on the global at all
it is all in all strange and I did take my time to study the docs to see if I was wrong, but at least it is reproducible
Previous Topic:Lua Socket library
Next Topic:Koneki / Mihini Mac OSX install
Current Time: Mon Nov 03 03:45:43 EST 2025
Powered by FUDForum. Page generated in 0.03706 seconds
