Home » Archived » Visual Editor (VE) » No Beans; No Design
No Beans; No Design [message #126588] Tue, 20 June 2006 18:23 Go to next message
Originally posted by: jmh.joelhalpern.com
Using Eclipse 3.1.0 and VE 1.1.0 on Windows XP (SP2)
I have a number of projects with a number of visual classes created by VE.
They worked just fine.
I did something that has broken VE.
I did not install any upgrades to VE or Eclipse.
However, now, when I open any of those visual classes (and yes, I
checked that I am opening them in the Visual Editor):
The Java Beans window shows up empty,
The design process runs, but then the Design window shows up empty,
and of course the properties window is empty.
The palette shows up fine, but that doesn't do me much good...
While I was debugging other code, I had to direct Eclipse as to where to
find the source for various parts of Java rt.jar.
However, none of the project properties appear to have changed.
So what do I need to change, and what do I need to change it to?
The Log is:
!SESSION 2006-06-20 17:41:59.203
eclipse.buildId=I20050627-1435
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 4 2 2006-06-20 17:42:07.144
!MESSAGE Plug-in com.vp.vpsde.ec was unable to load class
com.vp.vpsde.ec.VPSDEECMain.
!STACK 0
java.lang.ClassNotFoundException: com.vp.vpsde.ec.VPSDEECMain
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:406)
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:371)
at
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:340)
at
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:28)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:361)
at
at
org.eclipse.ui.internal.EarlyStartupRunnable.getPluginForCom patibility(EarlyStartupRunnable.java:145)
at
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:73)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1587 )
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.core.runtime 4 2 2006-06-20 17:42:07.164
!MESSAGE Problems encountered starting up plug-in:
"org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of
bundle com.vp.vpsde.ec.".
!STACK 0
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
at
at
at
at
at
at
at
at
Caused by: org.eclipse.core.runtime.CoreException: Plug-in
com.vp.vpsde.ec was unable to load class com.vp.vpsde.ec.VPSDEECMain.
at
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDescriptor.java:296)
at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:409)
at
at
at
at
at
... 15 more
Root exception:
org.eclipse.core.runtime.CoreException[2]:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-06-20 17:42:07.184
!MESSAGE Unhandled Exception
!ENTRY com.vp.vpsde.ec 4 0 2006-06-20 17:42:07.194
!MESSAGE Unable to execute early startup code for an extension
!STACK 0
at
at
at
Caused by: org.eclipse.core.runtime.CoreException: Problems encountered
starting up plug-in: "org.osgi.framework.BundleException: Exception in
at
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:363)
at
... 10 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 15 more
!ENTRY org.eclipse.ui 4 4 2006-06-20 17:42:07.194
!MESSAGE Bad extension specification
!ENTRY com.vp.vpsde.ec 4 0 2006-06-20 17:42:07.204
!MESSAGE startup class must implement org.eclipse.ui.IStartup
!ENTRY org.eclipse.ve.java.core 4 0 2006-06-20 17:42:10.689
!MESSAGE Exception thrown.
!STACK 0
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:83)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:508)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:831)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:911)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:577)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1857)
Re: No Beans; No Design [message #126604 is a reply to message #126588] Tue, 20 June 2006 18:51 Go to previous messageGo to next message
You may have a dirty cache from when you redirected the rt.jar stuff. So
let's try cleaning the cache:
1) Open a VE, close it and all other VE's.
2) Do Project->Clean All... and wait for build to finish.
3) Open a VE. See if ok now.
Also I would suggest stepping up to VE 1.1.0.1. It has many fixes. You
can use the update manager from your IDE and it should find the update.
In a few weeks you should probably step up to Eclipse 3.2 and the latest
VE (VE 1.2) when they get released. But VE 1.2 will not work with
Eclipse 3.1
Rich Kulp
Re: No Beans; No Design [message #126630 is a reply to message #126604] Tue, 20 June 2006 19:54 Go to previous message
Thank you for the prompt and effective reply.
It actually took two round of cleaning and exiting before everything got
sorted out, but things are in working order again.
I will get the upgrades, and look forward to the next release as well.
Yours,
Joel M. Halpern
> Eclipse 3.1
Re: No Beans; No Design [message #613378 is a reply to message #126588] Tue, 20 June 2006 18:51 Go to previous message
Eclipse 3.1
Rich Kulp
Re: No Beans; No Design [message #613380 is a reply to message #126604] Tue, 20 June 2006 19:54 Go to previous message
Yours,
Joel M. Halpern
> Eclipse 3.1
Previous Topic:Can I use VE to make RCP applications for Eclipse?
Next Topic:Access by method name (xxxxx) (not by proxy) requires a receiver.
Current Time: Sat Jul 19 04:12:21 EDT 2025
Powered by FUDForum. Page generated in 0.06384 seconds
