Home » Eclipse Projects » Eclipse 4 » Handler can not search desired class
Handler can not search desired class [message #1257556] Wed, 26 February 2014 10:14 Go to next message
hi,
I am a learner I have searched over internet also but could not found or relate answers
I make dialogue class and a class to open it from handler
but when I press Find Class option in handler it doesnt show desired class I have made a Menu and a Command the menu stay dim(not activated means i cant click it)
Here is the code of both classes
import org.eclipse.e4.core.di.annotations.Execute;
import org.eclipse.jface.dialogs.IMessageProvider;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.nebula.widgets.cdatetime.CDT;
import org.eclipse.nebula.widgets.cdatetime.CDateTime;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class Voggela extends TitleAreaDialog {
  public Voggela(Shell parentShell) {
    super(parentShell);
  public void create() {
    super.create();
    setTitle(" Weather Data Simulation ");
    setMessage("This is a TitleAreaDialog", IMessageProvider.INFORMATION);
  protected Control createDialogArea(Composite parent) {
	Composite area = (Composite) super.createDialogArea(parent);
    Composite container = new Composite(area, SWT.NONE);
    container.setLayoutData(new GridData(GridData.FILL_BOTH));
    GridLayout layout = new GridLayout(2, false);
    container.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
    container.setLayout(layout);
    createtextComposite(container);
    createDateComposite(container);
    return area;
  private void createtextComposite(Composite container){
	    Composite textComposite = new Composite(container, SWT.CENTER);
	    GridLayout textGrid = new GridLayout();
	    textGrid.numColumns = 4;
	    textComposite.setLayout(textGrid);
	    new Label(textComposite, SWT.NONE);
	    Label lblNewLabel = new Label(textComposite, SWT.NONE);
	    lblNewLabel.setText("File");
	    Label lblNewLabel_2 = new Label(textComposite, SWT.NONE);
	    lblNewLabel_2.setText("File Name ABC");
	    Label lblNewLabel_1 = new Label(textComposite, SWT.NONE);
	    lblNewLabel_1.setText("Weather");
	    Label lblNewLabel_3 = new Label(textComposite, SWT.NONE);
	    GridData gd_lblNewLabel_3 = new GridData(SWT.LEFT, SWT.CENTER, false, false, 1, 1);
	    gd_lblNewLabel_3.heightHint = 16;
	    lblNewLabel_3.setLayoutData(gd_lblNewLabel_3);
	    lblNewLabel_3.setText("Name  Data");
  private void createDateComposite(Composite container){
	    Composite dateComposite = new Composite(container, SWT.CENTER);
	    dateComposite.setLayout(new GridLayout(2, true));
	    GridData gd_dateComposite = new GridData(SWT.FILL, SWT.FILL, true, true);
	    gd_dateComposite.heightHint = 77;
	    dateComposite.setLayoutData(gd_dateComposite);
	    Label startDate = new Label(dateComposite,SWT.READ_ONLY | SWT.TOP);
	    startDate.setText("Start Date");
	    startDate.setLayoutData(new GridData(SWT.CENTER, SWT.BOTTOM, true, true));
	    Label endDate = new Label(dateComposite,SWT.READ_ONLY | SWT.TOP);
	    endDate.setText("End Date");
	    endDate.setLayoutData(new GridData(SWT.CENTER, SWT.BOTTOM, true, true));
	    final CDateTime cdtStop = new CDateTime(dateComposite, CDT.BORDER | CDT.DROP_DOWN);
	    cdtStop.setLayoutData(new GridData(SWT.RIGHT, SWT.TOP, true, true));
	    final CDateTime cdtStart = new CDateTime(dateComposite, CDT.BORDER | CDT.DROP_DOWN);
	    cdtStart.setLayoutData(new GridData(SWT.RIGHT, SWT.TOP, true, true));
  protected boolean isResizable() {
    return true;
import javax.inject.Named;
import org.eclipse.e4.ui.services.IServiceConstants;
import de.fraunhofer.iwes.coast.simulator.userstories.dialog.Voggela;
public class OpenHandler {
	  @Execute
	  public void execute(
	  @Named(IServiceConstants.ACTIVE_SHELL) final Shell shell) {
		Voggela dialog = new Voggela(shell);
		dialog.open();
Re: Handler can not search desired class [message #1264589 is a reply to message #1257556] Wed, 05 March 2014 05:40 Go to previous messageGo to next message
So what's your issue ? 'Find class' in the e4xmi editor does not work for handlers? I think it does as I use it daily.
Re: Handler can not search desired class [message #1264604 is a reply to message #1264589] Wed, 05 March 2014 05:52 Go to previous message
IIRC it takes the classpath into account so if the handler is defined in
another bundle than the e4xmi then it would be found.
Tom
Previous Topic:No CSS styling in exported Eclipse RCP product
Next Topic:target definition error
Current Time: Mon Jul 21 02:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.05290 seconds
