Home » Eclipse Projects » Remote Application Platform (RAP) » problem with the height of TableViewerColumn and ComboBoxCellEditor
problem with the height of TableViewerColumn and ComboBoxCellEditor [message #126400] Mon, 30 March 2009 09:57 Go to next message
--------------030207050105040003070708
i have a little problem with the height of a TableViewerColumn when I'm
using a ComboBoxCellEditor.
When I doubleclick a cell, the value of the cell is not correctly
displayed. Look at the attachment.
The cell seems to be too small, but I can't set another size.
here is a snippet to reproduce:
public class Test implements IEntryPoint {
private TableViewer tableViewer;
private Table table;
private List<String> list;
public int createUI() {
Display display = PlatformUI.createDisplay();
Shell container = new Shell( display, SWT.SHELL_TRIM );
container.setSize( 500, 500 );
container.setLayout( new GridLayout() );
tableViewer = new TableViewer( container, SWT.NONE );
tableViewer.setUseHashlookup( true );
tableViewer.setContentProvider( new ContentProvider() );
tableViewer.setLabelProvider( new LabelProvider() );
table = tableViewer.getTable();
table.setLayoutData( new GridData( SWT.FILL, SWT.FILL, true, true ) );
table.setHeaderVisible( true );
table.setLinesVisible( true );
TableViewerColumn keyColumn = new TableViewerColumn( tableViewer,
SWT.NONE );
keyColumn.setLabelProvider( new LabelProvider() );
keyColumn.setEditingSupport( new CellEditingSupport( tableViewer ) );
TableColumn column = keyColumn.getColumn();
column.setText( "Key" );
column.setWidth( 200 );
list = new ArrayList<String>();
list.add( "key3" );
list.add( "key2" );
list.add( "key1" );
ColumnViewerEditorActivationStrategy activationStrategy = new
ColumnViewerEditorActivationStrategy( tableViewer ) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event ) {
return event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON;
TableViewerEditor.create( tableViewer, activationStrategy,
ColumnViewerEditor.TABBING_HORIZONTAL |
ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR );
tableViewer.setInput( list );
container.open();
while ( !container.isDisposed() ) {
if ( !display.readAndDispatch() ) {
display.sleep();
return 0;
private static final class ContentProvider implements
IStructuredContentProvider {
private Object[] elements;
public Object[] getElements( Object inputElement ) {
return elements;
public void inputChanged( Viewer viewer, Object oldInput, Object
newInput ) {
if ( newInput == null ) {
elements = new Object[0];
} else {
List<String> list = (List<String>) newInput;
elements = list.toArray();
public void dispose() {}
private static final class LabelProvider extends CellLabelProvider {
public void update( final ViewerCell cell ) {
cell.setText( (String) cell.getElement() );
private final class CellEditingSupport extends EditingSupport {
private final CellEditor cellEditor;
private String[] keys = { "key1", "key2", "key3" };
public CellEditingSupport( TableViewer viewer ) {
super( viewer );
cellEditor = new ComboBoxCellEditor( viewer.getTable(), keys );
protected boolean canEdit( Object element ) {
return true;
protected CellEditor getCellEditor( Object element ) {
return cellEditor;
protected Object getValue( Object element ) {
for ( int i = 0; i < keys.length; i++ ) {
if ( element.equals( keys[i] ) )
return i;
return null;
protected void setValue( Object element, Object value ) {
element = keys[((Integer) value).intValue()];
getViewer().update( element, null );
Roland
Content-Type: image/png;
name="tableviewer.png"
Content-Disposition: inline;
filename="tableviewer.png"
iVBORw0KGgoAAAANSUhEUgAAATAAAAC2CAMAAABpuyGwAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
AwBQTFRFAAAAAABIAABSAAB0AAB+RQAASAAATAAAcQAAdAAARQBISABIRQB0 SAB0cQBIdABI
cQB0dAB0RUUAcXF0dHR0AEWcAEicAE2cAHG/AHS/MWrFMWrPMWrZXmrFO6kp AIDABoTBEojE
HI7HKJPKMYfZM5rNPp/QMYfjMaLsTJO7dKa/RZffSJzfSaTSVKrVX6/XXrv2 cbn/dL//l0UA
kU0AnEgApHYAuXEAv3QAl0VInEhIkU1+nEh07x0vhWrFhWrPr5NSsqZ+2ZdI 35xI+Ll0/790
gICAhYeMkbC7kbC/rKiZsrCcp6aqpLSvr7SvpLS7pLS/r7S7r7S/srSvsrS7 srS/hYfFpofF
pofZnN+/hdP/l9n/nN//udn/v9//ufjfv//fpun2pun/ufj/v///xaLF47vP +Nmc/9+c+Nm/
/9+/+Pi///+/wMDA0NDQxdPs3N/kxenjxf/sxf/2xf//0uTz1OXz1eb02Oj0 2ej12+r13er2
3+z22fj/3////9PZ+Pjf///f4ez34u735O744//s5vD44//24///6PH56fL5 6vL67fT6/+nj
///s8PD48Pb78vf88/j89Pj89vr89vr9///2+Pj/+Pr9+vz+//39/P3+/f7+ /v7/AAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAQVjrmQAAABh0RVh0U29mdHdhcmUAUGFpbnQu TkVUIHYzLjM2
qefiJQAACL9JREFUeF7tnfdj20QUx9VBacqeBTfgDJLQlkK6aBlhpNQFEzYh kJTVQQMZFCiU
3YTV0gJhC0ruf+W9O0m+k2xLZ+li6fS+PyRScj5JH3/v3dOzZDkfk7QIOJ+Q tAg4Z0laBAiY
Fq6zZ31g95HiCSBbH9i9pHgCHNinQrvKKaZoV/vVXQjK+UxouJxid0piw+HV MUlseBhB+cCG
yimV0FB4VQE2NMSBfS40WE6phAZh1R+VsDTIxsYuryI0BktscBBBOV8IDZRT KrABFdgAYFpl
QIzxHwMDCMoH1l9OqcD6EZgIarjUD8CQ2GXkNcb6+2VgfeWUCqxPBdaHwMBe nNcY6+vjwL4U
qpZTKrCqCqyqAqtWERQBa+QVrBkw8JewGPOAfSNUToMhIW9exIUmwDgsEfmr VQTlEDCRSATA
vLyC8wNMPH6tXm4A+1aoxA4LxiR3mDJClcS1WkVQzndCBMwbku2AIaiyA1NO t6vqyXd4tcqB
/SBUUofpHTaCImAazGRgntHoVxwB50eSFgHnIkmLAAHTwnXxonOJpEWAgGnh unTJ+UmSu/aq
y9svwjIB03yXCBgB0ySg2dz5VZLrntoy47pzm3euWTCry9svwnITYHObd68Z L9cCYEt7Oa9x
x1k3447fBosHDBqueMB+k8SHpMAzfstX7qmrj89dO+POXX/cnOPq8vaLsOz8 LgmB3bgB8SAo
d+mBGXQXd5kp1eXtF2HZ+UMSALti5wHwFsR9B7UbXPYmYDOnurz9IiyHgW2Z WdoLjuIOQy3t
vQkBGpMFwERWgTHMffd1130CbGZQxQP2p6QgDwOPwSyJ0yRGfoO83Lq8/SIs O39JakZm3GBO
Adury9svwnIcsCCYGbJZ8YD9I8kQlHbd1uXtF2HZkXey3gUVAZK8j86/krrA qy5vvwjLCrBK
ZWLtxSo51EJIK8F7GQZ2ZK11Op/A1Kssam2AqS2Nr03kFZgyU8nA/pMEQ/KI cUSMyftSFGAB
JYeANQuhC8q76tZWGsBWJXkO44WKlkpvwSI6LKDkELBEDmsLbOsL+ww7zHHA ZfxHzmNYTYyG
2konwLZPTk6+1ONkMiQBFueVc2C1miAmA5OP34thzR22/knw3fanr8wEGODi vPINDHgJYrWV
4KgVw0jAtr74GOCZnHx5n7P9cTi6HbAK2vpsTzbAXMEr18A4L04sHtjG5+/n dkJCG5/b52x8
pocD25GVw/yZMtcxzPNGAmAPIS8E5eBABHdxl61/KrMYFmQWuQYW7GWMw9IP uvY9FDEPaxvD
CFglkul3E5haQcrpybcX8P1frWfJ02uuXJZ3VsJq7rDFRdOjsVn/izlUQmBw OF2ouHbjTYrb
pgawuK5S/j9S+51I2aGZl+cIWLj2S8Dav+WR+brgwGZN7z8B04whlgKbveqo JoikzcsGbP66
lCTLBWy+x1mXEbCg9ms6aCa1vtoucVrhBX0ckrOb7mHsEFxVd5Qduh26Owir LPVY9RzWqP1a
A2y+Zw/wuvVrNnvNCRyI8zecyA6YVPu1BdhryItHrOUHj6K7uMsycphc+7UE 2CYHvMUgZqH2
gMveAmyZAXOl2q8twPago4I5cXn/zQgwK4c1Sq61lYIDY2L/MbYfBGIYw9h7 bzB2GGxGwJBA
+HPZBrDl/UALZkmeSUDkh8Z8iAqrdSrb8jDPYREchzCnyEIL4dpvoYcklD6b 73/qBD9gHckI
J3JYb11cTJy4tnJYFubifUSBZdZ1lh0RME2aBIyAaRLQbJ7YYcYrrrbFMAIm rEgOoyGpSUCz
ua7DUtcJW+6fpTGsBTA8s9yAJ5Wdq1TAlh8GWLyA0bksBta0pu/XLTomZi+w 5jV9qIyRw2S3
BJ8atajpw2dJopLYqWxzmF9xbVnTT8nL1moF+KhpTf9w2s9xrQXWvKZ/OGVO YV09LKi4Yh4W
remLT93SmawsFdfMavqWBv3wHGiypt/pfGv0dYnPJammr1neIWAErKOhqzEk DX+vi31Bn4Bp
lajZBAHLFzD7bp0x7LAFNQZbcH0YBzZyfsoQOPsud2oHbBTs8csjqVCWCti2 t8F3oz/fkYaY
xcBGLrwDeBj7e6oyeg4YTcMqjtbvU1nMXmC9Z04KOwGh3o+mKr0fClDT5DBl 3hJ52Mj5V5EX
gqrgQAR3cZdtO5ZJDLPoOn0vcR25wNBIvWc4zJPgskcxfqHuThf1xZDkxPC7 /QqeVmDFVTjs
wkl0FHcYatux9/2RGPyts9DfuNeIfxciACv6Na5BWjENxPiUeNcr4CuwWaX3 A1gbzcJhQEp8
d2TBHQbDz49hU+AqoIWZF0yT3tw4nWEeJr6V0RZgkeE2KnKK9LI0rQiDSRm4 pO5KAiy9s/we
CJgmS7tunQmCviYFjeb2lajX/NuKOvqQwvSLkn8IYnpPwv135Qu44g+SgMUz UloQMAKmSUCz
OTmMgGkS0GxODiNgmgQ0m5PDzADLZfGzKztFDjPjMM1es2hOp0aaFAkYAdMk oNmcHEbANAlo
Ns+pwyIXSgaHlcFznTQRqc3zCkzdy1YPUUl16J29OLfA5Ce9tHyuUWfHnOpV BEwTHwEjYJoE
NJuTwywCFv8wO82DzaJ5rh0mXShJeVj7dztyoSQBSwSscaFkc2BdKW7mcqPB VVn+hZLksGQO
8/J9OjWKm68SPi4xrhsD/8/1LBn7BFMDQOK6zCuwZM+XjDs6A//PKbCEH7NF ymaR11n6h9b1
wohHlALiQrhsZimfyGFFDrz1WAoBC5XNygOsVb0wzmEETNzQQw5rP1Zap11J HcYfnVYry4hc
8c+1o4l9QmBw92cpgQWP2NMckni7bDmBCWK6MYzfX1xSYF4sIoclCvrejeja DsOb2EvqMP/G
ak2H4S3ZpRySglcHDnPdUgLjR90hsFLmYf55ju4s2XhdWTLXjjP9cNmsNMBa 1gvbZ/pl4RN/
nAlnSQMVVeu67PYViIUDSsA03zICRsA0CWg2J4dpAvsfachI8QOepYQAAAAA SUVORK5CYII=
--------------030207050105040003070708--
Re: problem with the height of TableViewerColumn and ComboBoxCellEditor [message #126414 is a reply to message #126400] Mon, 30 March 2009 11:29 Go to previous message
Hi Roland,
the current implementation of cell editors uses Combo control. There is
a bug related to this issue:
264225: [Combo] Omit border if used as celleditor
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264225
Since 1.2M6 we have an implementation of CCombo which is originally used
in the Cell Editors (see comment 2).
Best,
Ivan
Roland Siebert wrote:
> I'm using a ComboBoxCellEditor.
> true ) );
> tableViewer, SWT.NONE );
> tableViewer ) );
> list.add( "key3" );
> list.add( "key2" );
> list.add( "key1" );
> container.open();
> display.sleep();
> return 0;
> return elements;
> Object newInput ) {
> } else {
> super( viewer );
> keys );
> @Override
> return true;
> @Override
> return cellEditor;
> @Override
> return i;
> return null;
> @Override
> Roland
Previous Topic:HTTP Status 404 - ProxyServlet:
Next Topic:Working example of RAP Menu Bar
Current Time: Sun Jul 27 13:55:43 EDT 2025
Powered by FUDForum. Page generated in 0.05454 seconds
