Home » Modeling » TMF (Xtext) » Embeddededitor - Keybinding conflicts occur
Embeddededitor - Keybinding conflicts occur [message #1249828] Tue, 18 February 2014 12:27 Go to next message
I have an EditorPart which uses several instances of EmbeddedEditor.
When this editor is opened, a lot of warnings are produced regarding keybinding conflicts.
Many keybindings do not work afterwards (e.g. F2, Ctrl-C,...).
For instance:
Warning
Tue Feb 18 19:10:08 EET 2014
A conflict occurred for F2:
Binding(F2,
ParameterizedCommand(Command(org.eclipse.ui.edit.rename,Rename,
Rename the selected item,
Category(org.eclipse.ui.category.file,File,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@167213b,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(F2,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.showInformation,Show Tooltip Description,
Displays information for the current caret location in a focused hover,
Category(org.eclipse.ui.category.textEditor,Text Editing,Text Editing Commands,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@d6128b,
,,true),null),
org.eclipse.xtext.ui.embeddedTextEditorScope,,,system)
Could anyone suggest a fix for this, please ?
Best regards
Vlad Gheorghe
Re: Embeddededitor - Keybinding conflicts occur [message #1250842 is a reply to message #1249828] Wed, 19 February 2014 11:55 Go to previous messageGo to next message
The F2 seem to be a real conflict, but I guess the other warnings are
different in the sense that they have 'only' a different scope but point
to the same command. Can you add some other warnings to this thread?
I tried to reproduce and for F2 I get a pop up, but CTRL-C works nicely
(although I also see the warnings).
Sven
Am 18/02/14 18:27, schrieb Vlad Gheorghe:
> Hello,
> For instance:
> Warning
> Binding(F2,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@167213b,
> ,,true),null),
> Binding(F2,
> hover,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@d6128b,
> ,,true),null),
> Best regards
> Vlad Gheorghe
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Embeddededitor - Keybinding conflicts occur [message #1261297 is a reply to message #1250842] Sun, 02 March 2014 07:16 Go to previous messageGo to next message
!ENTRY org.eclipse.jface 2 0 2014-03-02 14:13:35.795
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2014-03-02 14:13:35.795
!MESSAGE A conflict occurred for CTRL+SHIFT+J:
Binding(CTRL+SHIFT+J,
ParameterizedCommand(Command(org.eclipse.ui.edit.findIncrementalReverse,Incremental Find Reverse,
Incremental find reverse,
Category(org.eclipse.ui.category.edit,Edit,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@b68dfe,
,,true),null),
org.eclipse.ui.textEditorScope,,,system)
,,true),null),
!MESSAGE A conflict occurred for CTRL+ARROW_UP:
Binding(CTRL+ARROW_UP,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.scroll.lineUp,Scroll Line Up,
Scroll up one line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1242f79,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for ALT+CTRL+ARROW_UP:
Binding(ALT+CTRL+ARROW_UP,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.copyLineUp,Duplicate Lines,
Duplicates the selected lines and leaves the selection unchanged,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@a8ca23,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+INSERT:
Binding(CTRL+SHIFT+INSERT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.toggleInsertMode,Toggle Insert Mode,
Toggle insert mode,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@16edff8,
,,true),null),
Toggle insert mode,
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+DEL:
Binding(CTRL+SHIFT+DEL,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.delete.line.to.end,Delete to End of Line,
Delete to the end of a line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@323143,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for ALT+ARROW_DOWN:
Binding(ALT+ARROW_DOWN,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.moveLineDown,Move Lines Down,
Moves the selected lines down,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1405d33,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for ALT+CTRL+ARROW_DOWN:
Binding(ALT+CTRL+ARROW_DOWN,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.copyLineDown,Copy Lines,
Duplicates the selected lines and moves the selection to the copy,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@a6e9f8,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+A:
Binding(ALT+SHIFT+A,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.toggleBlockSelectionMode,Toggle Block Selection,
Toggle block / column selection in the current text editor,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4aac9b,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+ARROW_RIGHT:
Binding(CTRL+SHIFT+ARROW_RIGHT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.select.wordNext,Select Next Word,
Select the next word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@8a0092,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+ARROW_DOWN:
Binding(CTRL+ARROW_DOWN,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.scroll.lineDown,Scroll Line Down,
Scroll down one line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2b9986,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for ALT+/:
Binding(ALT+/,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.hippieCompletion,Word Completion,
Context insensitive completion,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@6c5067,
,,true),null),
Binding(ALT+/,
,,true),null),
!MESSAGE A conflict occurred for HOME:
Binding(HOME,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.lineStart,Line Start,
Go to the start of the line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@112c78b,
,,true),null),
Binding(HOME,
,,true),null),
!MESSAGE A conflict occurred for END:
Binding(END,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.lineEnd,Line End,
Go to the end of the line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1ea8ed1,
,,true),null),
Binding(END,
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+Y:
Binding(CTRL+SHIFT+Y,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.lowerCase,To Lower Case,
Changes the selection to lower case,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4679df,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+X:
Binding(CTRL+SHIFT+X,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.upperCase,To Upper Case,
Changes the selection to upper case,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@eb2ae5,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+CR:
Binding(CTRL+SHIFT+CR,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.smartEnterInverse,Insert Line Above Current Line,
Adds a new line above the current line,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@14d5840,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for SHIFT+CR:
Binding(SHIFT+CR,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.smartEnter,Insert Line Below Current Line,
Adds a new line below the current line,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@dcf445,
,,true),null),
Binding(SHIFT+CR,
,,true),null),
!MESSAGE A conflict occurred for INSERT:
Binding(INSERT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.toggleOverwrite,Toggle Overwrite,
Toggle overwrite mode,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@28e395,
,,true),null),
Binding(INSERT,
,,true),null),
!MESSAGE A conflict occurred for CTRL+L:
Binding(CTRL+L,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.line,Go to Line,
Go to a specified line of text,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7563e6,
,,true),null),
Binding(CTRL+L,
,,true),null),
!MESSAGE A conflict occurred for CTRL+J:
Binding(CTRL+J,
ParameterizedCommand(Command(org.eclipse.ui.edit.findIncremental,Incremental Find,
Incremental find,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@f1b841,
,,true),null),
Binding(CTRL+J,
Incremental find,
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+K:
Binding(CTRL+SHIFT+K,
ParameterizedCommand(Command(org.eclipse.ui.edit.findPrevious,Find Previous,
Find previous item,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@177cb7a,
,,true),null),
Find previous item,
,,true),null),
!MESSAGE A conflict occurred for CTRL+K:
Binding(CTRL+K,
ParameterizedCommand(Command(org.eclipse.ui.edit.findNext,Find Next,
Find next item,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1cff7f7,
,,true),null),
Binding(CTRL+K,
Find next item,
,,true),null),
!MESSAGE A conflict occurred for F2:
Binding(F2,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@672666,
,,true),null),
Binding(F2,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@a08243,
,,true),null),
Binding(F2,
,,true),null),
!MESSAGE A conflict occurred for CTRL+F10:
Binding(CTRL+F10,
ParameterizedCommand(Command(org.eclipse.ui.window.showViewMenu,Show View Menu,
Show the view menu,
Category(org.eclipse.ui.category.window,Window,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1c8346c,
,,true),null),
org.eclipse.ui.contexts.dialogAndWindow,,,system)
Binding(CTRL+F10,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.showRulerContextMenu,Show Ruler Context Menu,
Show the context menu for the ruler,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@e9adba,
,,true),null),
Binding(CTRL+F10,
,,true),null),
!MESSAGE A conflict occurred for SHIFT+HOME:
Binding(SHIFT+HOME,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.select.lineStart,Select Line Start,
Select to the beginning of the line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@18cb0a7,
,,true),null),
Binding(SHIFT+HOME,
,,true),null),
!MESSAGE A conflict occurred for CTRL+ARROW_LEFT:
Binding(CTRL+ARROW_LEFT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.wordPrevious,Previous Word,
Go to the previous word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1a1e34f,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+HOME:
Binding(CTRL+HOME,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.textStart,Text Start,
Go to the beginning of the text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1528167,
,,true),null),
Binding(CTRL+HOME,
,,true),null),
!MESSAGE A conflict occurred for SHIFT+END:
Binding(SHIFT+END,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.select.lineEnd,Select Line End,
Select to the end of the line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1adc008,
,,true),null),
Binding(SHIFT+END,
,,true),null),
!MESSAGE A conflict occurred for CTRL+DEL:
Binding(CTRL+DEL,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.deleteNextWord,Delete Next Word,
Delete the next word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1a5021,
,,true),null),
Binding(CTRL+DEL,
,,true),null),
!MESSAGE A conflict occurred for ALT+ARROW_UP:
Binding(ALT+ARROW_UP,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.moveLineUp,Move Lines Up,
Moves the selected lines up,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@182d0a3,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+ARROW_RIGHT:
Binding(CTRL+ARROW_RIGHT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.wordNext,Next Word,
Go to the next word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@14f9ce1,
,,true),null),
,,true),null),
!MESSAGE A conflict occurred for CTRL+D:
Binding(CTRL+D,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.delete.line,Delete Line,
Delete a line of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1c4a48f,
,,true),null),
Binding(CTRL+D,
,,true),null),
!MESSAGE A conflict occurred for CTRL+BS:
Binding(CTRL+BS,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.deletePreviousWord,Delete Previous Word,
Delete the previous word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@10fbebb,
,,true),null),
Binding(CTRL+BS,
,,true),null),
!MESSAGE A conflict occurred for CTRL+END:
Binding(CTRL+END,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.textEnd,Text End,
Go to the end of the text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@b3261b,
,,true),null),
Binding(CTRL+END,
,,true),null),
!MESSAGE A conflict occurred for ALT+CTRL+J:
Binding(ALT+CTRL+J,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.join.lines,Join Lines,
Join lines of text,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@18adae0,
,,true),null),
Binding(ALT+CTRL+J,
Join lines of text,
,,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+ARROW_LEFT:
Binding(CTRL+SHIFT+ARROW_LEFT,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.select.wordPrevious,Select Previous Word,
Select the previous word,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@127b640,
,,true),null),
,,true),null),
Re: Embeddededitor - Keybinding conflicts occur [message #1261298 is a reply to message #1261297] Sun, 02 March 2014 07:18 Go to previous messageGo to next message
Hello Sven,
I confirm that Control-C/-X/-V works in the embeddede editor.
The only issue seems to remain F2 (e.g. rename in the project explorer)
Best regards
Vlad Gheorghe
Re: Embeddededitor - Keybinding conflicts occur [message #1403857 is a reply to message #1261298] Mon, 28 July 2014 05:54 Go to previous message
Hi!
Is there a known solution for this problem?
Best regards
Jonas
Previous Topic:Inherit properties of supertype
Next Topic:Creating a wildcard reference
Current Time: Sat Jul 26 08:59:13 EDT 2025
Powered by FUDForum. Page generated in 0.04668 seconds
