Home » Language IDEs » ServerTools (WTP) » MySQL statements with incorrect quotes
MySQL statements with incorrect quotes [message #120453] Wed, 13 July 2005 08:52 Go to next message
Originally posted by: alain.poirier.net-ng.com
I use WTP M5, eclipse 3.1, MySQL 4.0.24 and jdbc-mysql 3.0.16.
I can connect to a database and send SQL requests with the SQL ScrapBook.
But, when I try to open a table with the Explorer View, I see
Eclipse emitting incorrect SQL statements with quotes, like
SELECT * FROM "test"."address"
instead of the correct ones: SELECT * FROM test.address
Any ideas ? Is it a bug or some configuration is needed ?
Re: MySQL statements with incorrect quotes [message #120935 is a reply to message #120453] Thu, 14 July 2005 19:41 Go to previous messageGo to next message
Alain,
I thought we already fixed this in M5. Please verify that the database
definition file (org.eclipse.wst.rdb.dbdefinition.MySQL plugin) that you
get for MySQL contains following tag:
<queryDefinition hostVariableMarker="@" IdentifierQuoteString="'" />
MySQL need to use the single quote instead.
Hope this help.
Der Ping
Re: MySQL statements with incorrect quotes [message #121060 is a reply to message #120935] Fri, 15 July 2005 06:48 Go to previous messageGo to next message
Thanks for your reply.
Indeed, I checked the MySql_4.0.xmi file and found the line :
<queryDefinition identifierQuoteString="`" hostVariableMarker="@"
hostVariableMarkerSupported="true"/>
This definition seems to be correct because MySQL needs a back-quote char.
But this delimiter is not used into the SQL queries. In fact, the only
values that I can use are "\"" and "'". All others values ("`" included)
seems to be ignored and replaced by "
Does a filter on the possible values exist somewhere ?
Re: MySQL statements with incorrect quotes [message #126103 is a reply to message #121060] Tue, 26 July 2005 14:38 Go to previous messageGo to next message
I am using RC3 and am having the same issue. It is defined correctly as
a backtick ( ` ) in the xmi file. It would seem however that this
definition is being ignored. It doesn't matter what I change the
identifier quote to it continues to insert a double-quote in its place.
Any help would be very much appreciated.
Dion
___________
Alain Poirier wrote:
> Regards
Re: MySQL statements with incorrect quotes [message #144823 is a reply to message #126103] Fri, 21 October 2005 11:30 Go to previous messageGo to next message
Originally posted by: user.domain.invalid
Top posting reformatted.
>> Hi,
>> char.
>> Regards
> as a backtick ( ` ) in the xmi file. It would seem however that this
> place.
> Thanks, Dion
> ___________
I see there hasn't been any activity on this thread since July. I'm
running Eclipse 3.1.0, WST 0.7.0 and MySQL 4.0.26 and am encountering
the same problem. It doesn't matter what I change the value of
identifierQuoteString to be in MySQL_4.0.xmi, the query still uses "s
around the database and table names.
Has anyone been able to work around this yet?
Sean
Re: MySQL statements with incorrect quotes [message #145324 is a reply to message #144823] Wed, 26 October 2005 21:34 Go to previous message
>>>Hi,
>>>char.
>>>Regards
>>place.
>>Thanks, Dion
>>___________
BTW, I upgraded to WST 0.7.1. Still no luck.
Anybody get this working with MySQL yet?
Sean
Previous Topic:WTP & Weblogic
Next Topic:connecting to Informix 7.x
Current Time: Sat Nov 08 02:21:29 EST 2025
Powered by FUDForum. Page generated in 0.05443 seconds
