Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Can't persist reference when EOpposite is set.
[Teneo] Can't persist reference when EOpposite is set. [message #125318] Fri, 06 June 2008 17:18 Go to next message
I am using emf 2.4 (dynamic efeatures) and teneo 0.8.0RC1A. We have this
issue where the relation between 2 object is not persisted when both
object`s reference to each other has their EOpposite set to each other.
ex:
A Book.author is referring [1] to an Author, with EOpposite set to
Author.book
An Author is referring [1 to *] to Book, and with an EOpposite set to
Book.author
When I set the author of the book, then persist the book (and author
through cascading) and commit, the author and the book are persisted but
the relation between the twos is not.
Any idea why from this brief description?
If not, I will try to provide a sample.
François
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125636 is a reply to message #125318] Tue, 10 June 2008 13:49 Go to previous messageGo to next message
--------------020109020602020908070806
Hi Martin,
I was able to reproduce it. The problem is caused by the order in which
the EClass are declared in the genmodel.
In the test case I attached:
Person has 1 Team
Team has 0 to Many Person.
Person eOpposite is team.members.
Team eOpposite is Person.team
In the model description, if Person is declared before Team. The column
"person_team_e_id" from the "person" table is correctly set to an id
from the team.members table.
The problem rise when Team is declared before Person. In this case the
column "person_team_e_id" from "person" table is always set to null.
This cause the person.getTeam() call to always return null.
To go from a working to failing state, simply change the order of the 2
EClass and restart the application.
Is there anyway to fix that issue without changing the order of the
EClass, it maybe impossible to do for me because my EClasses are from
different package.
Fran
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125681 is a reply to message #125636] Wed, 11 June 2008 02:21 Go to previous messageGo to next message
Hi François,
A special issue for sure. I will probably have time tomorrow to look at this in more detail.
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> Hi,
>> this issue where the relation between 2 object is not persisted when
>> both object`s reference to each other has their EOpposite set to each
>> other.
>> ex:
>> Author.book
>> Book.author
>> but the relation between the twos is not.
>> Regards
>> François
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125960 is a reply to message #125636] Sat, 14 June 2008 18:23 Go to previous messageGo to next message
Hi François,
I tried your testcase but I could not reproduce the exception. Maybe I misunderstood you, I
exchanged the order of Team and Person several times in the ecore file. Each time I started with an
empty database and all the time the test passed.
Can you try again?
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> Hi,
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125973 is a reply to message #125960] Mon, 16 June 2008 08:35 Go to previous messageGo to next message
I confirm that I get the issue.
After I move the declaration of Team before the declaration of Person in
the ecore, I save the ecore, and reload the genmodel from the ecore,
then I "Generate the model code". I run the same test case and my
person_team_e_id is set to NULL.
When Person is defined first:
mysql> select * from person;
| e_id | dtype | e_version | name | section | person_team_e_id |
| 1 | Person | 0 | LaPoune | NULL | 1 |
1 row in set (0.00 sec)
When Team is defined first:
| 1 | Person | 0 | LaPoune | NULL | NULL |
Martin Taal wrote:
> Hi François,
> misunderstood you, I exchanged the order of Team and Person several
> times in the ecore file. Each time I started with an empty database and
> Can you try again?
> gr. Martin
> François M. wrote:
>> Hi Martin,
>> which the EClass are declared in the genmodel.
>> Person has 1 Team
>> column "person_team_e_id" from the "person" table is correctly set to
>> an id from the team.members table.
>> 2 EClass and restart the application.
>> different package.
>> François
>> François M. wrote:
>>> Hi,
>>> other.
>>> ex:
>>> Author.book
>>> Book.author
>>> Regards
>>> François
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125990 is a reply to message #125973] Mon, 16 June 2008 08:49 Go to previous messageGo to next message
--------------040500090007040406050003
I modified the test case so that it actually shows the problem without
requiring you to do a manual query to the database.
When Team is defined first: you should get a null pointer exception
because person.getTeam() return null.
Fran
Re: [Teneo] Can't persist reference when EOpposite is set. [message #126003 is a reply to message #125960] Mon, 16 June 2008 08:57 Go to previous messageGo to next message
--------------050900090501070003080605
Hi Martin,
When the code runs, no errors are generated. But...
What I did to reproduce the problem, was simply to change the order,
declare Team before Person, reload the genmodel, regenerate the model
code, run my test case and voil
Re: [Teneo] Can't persist reference when EOpposite is set. [message #126017 is a reply to message #126003] Mon, 16 June 2008 17:25 Go to previous message
Hi Luc/Francois,
Yes, I should have looked in the db with your previous testcase...
Using your last testcase I could re-produce this. It showed that bidirectional lists with jointables
do not work well in all cases. In addition Hibernate does not support bi-directional lists.
Therefore Teneo maps them as two independent relations: one-to-many with a join-table and
many-to-one (with a fk) for the other side.
I made some changes in the code to handle this better. This will be in a new build.
As a workaround (for now) you can set a @OneToMany(indexed=false) on the members efeature. Let me
know if this works.
Btw, as Teneo is graduating to 1.0.0 it will move to the main EMF newsgroup. I have cross-posted
there so we can continue the thread there.
gr. Martin
Luc wrote:
> Hi Martin,
> code, run my test case and voilà, the "person_team_e_id" is gone, see
> below (with attached softball.ecore.bad):
> mysql> select e_id, dtype, person_team_e_id from person;
> | e_id | dtype | person_team_e_id |
> | 1 | Person | NULL |
> mysql> select e_id, dtype from team;
> | e_id | dtype |
> | 1 | Team |
> Yet when I declare Person before Team, reload the genmodel, regenerate
> the model code, run my test case, the "person_team_e_id" is set to 1,
> see below (with attached softball.ecore.good):
> | 1 | Person | 1 |
> | e_id | dtype |
> | 1 | Team |
> Thanks for your help!
> Luc
> Martin Taal wrote:
>> Hi François,
>> Can you try again?
>> gr. Martin
>> François M. wrote:
>>> Hi Martin,
>>> Person has 1 Team
>>> the column "person_team_e_id" from "person" table is always set to
>>> null. This cause the person.getTeam() call to always return null.
>>> different package.
>>> François
>>> François M. wrote:
>>>> Hi,
>>>> each other.
>>>> ex:
>>>> Author.book
>>>> to Book.author
>>>> Regards
>>>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619229 is a reply to message #125318] Tue, 10 June 2008 13:49 Go to previous message
Hi Martin,
Person has 1 Team
different package.
Fran
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619232 is a reply to message #125636] Wed, 11 June 2008 02:21 Go to previous message
Hi François,
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> Hi,
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619253 is a reply to message #125636] Sat, 14 June 2008 18:23 Go to previous message
Hi François,
Can you try again?
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> Hi,
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619254 is a reply to message #125960] Mon, 16 June 2008 08:35 Go to previous message
Martin Taal wrote:
> Hi François,
> Can you try again?
> gr. Martin
> François M. wrote:
>> Hi Martin,
>> Person has 1 Team
>> different package.
>> François
>> François M. wrote:
>>> Hi,
>>> other.
>>> ex:
>>> Author.book
>>> Book.author
>>> Regards
>>> François
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619255 is a reply to message #125973] Mon, 16 June 2008 08:49 Go to previous message
Fran
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619256 is a reply to message #125960] Mon, 16 June 2008 08:57 Go to previous message
Hi Martin,
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619257 is a reply to message #126003] Mon, 16 June 2008 17:25 Go to previous message
Hi Luc/Francois,
know if this works.
gr. Martin
Luc wrote:
> Hi Martin,
> | 1 | Person | NULL |
> | e_id | dtype |
> | 1 | Team |
> | 1 | Person | 1 |
> | e_id | dtype |
> | 1 | Team |
> Luc
> Martin Taal wrote:
>> Hi François,
>> Can you try again?
>> gr. Martin
>> François M. wrote:
>>> Hi Martin,
>>> Person has 1 Team
>>> different package.
>>> François
>>> François M. wrote:
>>>> Hi,
>>>> each other.
>>>> ex:
>>>> Author.book
>>>> to Book.author
>>>> Regards
>>>> François
The Netherlands
Previous Topic:Sparse lists seem to cause havoc in Teneo 0.7.5
Next Topic:[Announce] EMFT COMPARE 0.8.0RC5 is available
Current Time: Thu Jul 24 21:17:57 EDT 2025
Powered by FUDForum. Page generated in 0.50571 seconds
