Home » Eclipse Projects » Remote Application Platform (RAP) » RAP support for other Eclipse bundles
RAP support for other Eclipse bundles [message #125931] Mon, 23 March 2009 09:04 Go to next message
Originally posted by: Florin-Alexandru.Bratu.sophia.inria.fr
Hello!
My scenario is the following: I have an Eclipse RCP application, and I
would like to port it for the Web. I found out about RAP which promises
to being able to do it without actually rewriting the interface code. So
I gave it a shot but apparently it is not that easy - like it never is! :D
The problems I get are mostly related to the fact that RAP(in fact RWT)
implements a subset of the SWT functionality, not all. Also, the
problems with using other bundles with RAP are not fully solved.
My question is the following:
- is there a description of the features from SWT that are done in RWT
and the ones that are still missing(something like a TODO plan) ?
- is there a list of the Eclipse bundles that are supported by RAP, and
those that are not yet supported?
All I found is:
http://www.eclipse.org/projects/project-plan.php?projectid=t echnology.rap
but I this document does not provide all the information I need.
Re: RAP support for other Eclipse bundles [message #125944 is a reply to message #125931] Mon, 23 March 2009 10:16 Go to previous messageGo to next message
Hi Florin-Alexandru,
in general we use the presumption of compile-error (all missing features
in RAP will give you a compile error). A RAP project plan for upcoming
1.2 release is published at [1].
About the supported Eclipse bundles - look at the RAP target platform [2].
[1]
[2] http://www.eclipse.org/rap/downloads/
Best,
Ivan
Florin-Alexandru Bratu wrote:
> Hello!
> promises to being able to do it without actually rewriting the
> interface code. So I gave it a shot but apparently it is not that easy
> RWT) implements a subset of the SWT functionality, not all. Also, the
> and those that are not yet supported?
> All I found is:
Re: RAP support for other Eclipse bundles [message #125955 is a reply to message #125944] Mon, 23 March 2009 11:05 Go to previous messageGo to next message
Not too practical approach because I get about 6000+ errors...
10x for the tip, this helped!
> Best,
> Ivan
Florin.
Re: RAP support for other Eclipse bundles [message #126250 is a reply to message #125955] Wed, 25 March 2009 11:56 Go to previous messageGo to next message
Florin,
6000+ errors sound a lot. Did you change the dependencies from
org.eclipse.ui to to org.eclpse.rap.ui?
Are you aware of the single sourcing webinar [1]?
HTH
Rüdiger
[1] http://www.eclipse.org/rap/singlesourcing.php
>> features in RAP will give you a compile error).
>> [2].
>> Best,
>> Ivan
> Cheers,
> Florin.
Re: RAP support for other Eclipse bundles [message #126262 is a reply to message #126250] Wed, 25 March 2009 15:32 Go to previous message
Sorry for the late reply. In the meanwhile, I tried a different
approach: javaws'ing my RCP plugin...
Rüdiger Herrmann wrote:
> Florin,
yap.
Nope. Watching it right now...
> HTH
> Rüdiger
Previous Topic:custom widget problems
Next Topic:Image from hard drive
Current Time: Sun Jul 27 11:16:25 EDT 2025
Powered by FUDForum. Page generated in 0.04495 seconds
