Home » Modeling » Papyrus » Ecore to UML/MARTE mapping
Ecore to UML/MARTE mapping [message #1241976] |
Sat, 08 February 2014 16:18  |
I would like to map an Ecore model to a UML/MARTE model(a model with stereotypes).
Technically, is it possible?
Amina
Re: Ecore to UML/MARTE mapping [message #1242966 is a reply to message #1242560] |
Mon, 10 February 2014 05:22   |
Still no idea what you mean by mapping.
Eclipse has a variety of model to model transformation tools that work
with UML stereotypes.
Ed Willink
On 09/02/2014 19:54, amina magd wrote:
> Hi Ed Willink,
> I mean by mapping, in this case, model to model mapping
> If i use the conversion option in the Ecore Editor Tool Bar menu, i
> will be able to add ,if needed, information to the obtained UML model?
> Or shall i create a template to be able to add data after mapping?
> Thanks a lot for your reply
> Best regards, Amina,
Re: Ecore to UML/MARTE mapping [message #1259233 is a reply to message #1258906] |
Fri, 28 February 2014 01:43   |
If it doesn't do what you want you have a problem.
There are many processing options for the converter; perhaps you used
the wrong ones. And before you ask, I don't know where they are
documented. You need to use your intuition/empirical discovery.
Ed Willink
On 27/02/2014 22:05, amina magd wrote:
> Hi Ed Willink,
> In fact, i wanted to convert a UML/MARTE model to a meta-model Ecore.
> I have already begun this by following these steps: -I used papyrus
> under Eclipse Kepler to create a UML/MARTE class diagram (representing
> a design pattern) -I created a new EMF Project
> -In the next step 'model importers', I selected UML model. -After that
> i selected the uml file (previously created) from the system for the
> 'Model url'
> After that, two files are generated : model.ecore and model.genmodel
> The classes existing in the UML/MARTE model are converted to the Ecore
> file, but the attributes and stereotypes offered by MARTE and
> annotating the UML/MARTE diagram are lost
> Is there any problem in the conversion that i used ?
> Any help please, Thanks for reply and help,
> Best regards,
Re: Ecore to UML/MARTE mapping [message #1259517 is a reply to message #1259394] |
Fri, 28 February 2014 08:26  |
Hi Camile
In so far as Profiles/Stereotypes extend classes, UML2Ecore supports
them. Just look at all the Ecore Profile add-ons in the UML meta-model.
Ed Willink
On 28/02/2014 10:30, Camille Letavernier wrote:
> It may exist. But not within the Papyrus Project.
> Many tools are built on top of Papyrus, so maybe one of them provides
> a "UML/Marte to Ecore" converter. But it seems very unlikely.
> Ed wasn't mentionning such a tool; he was just mentionning a generic
> "UML to Ecore" converter, which has absolutely no support for
> Profiles/Stereotypes.
> Regards,
> Camille
Current Time: Sun Jul 20 21:27:52 EDT 2025
Powered by FUDForum. Page generated in 0.27787 seconds
