Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Solved]How to generate an ecore metamodel diagram from an .ecore file?
icon7.gif  [Solved]How to generate an ecore metamodel diagram from an .ecore file? [message #1258598] Thu, 27 February 2014 09:52 Go to next message
Greetings to all the forum members!
I am using eclipse and I have generated an .ecore file of a model I am working on. However, I would like to show this model graphically as an ecore model diagram. I am attaching an image to illustrate the case.
I had some troubles finding an answer on this when googling around maybe because I am not using the proper keywords.
Can someone please explain me how I can achieve this?
Thank you in advance!
[Updated on: Fri, 28 February 2014 04:23] by Moderator
Re: How to generate an ecore metamodel diagram from an .ecore file? [message #1258604 is a reply to message #1258598] Thu, 27 February 2014 09:59 Go to previous messageGo to next message
just right click on your *.ecore file, select New -> Ecore Diagram and follow the wizard.
Simone
Re: How to generate an ecore metamodel diagram from an .ecore file? [message #1259343 is a reply to message #1258604] Fri, 28 February 2014 04:22 Go to previous message
Hi Simone,
thank you for you reply.
Yes, was not that of a hard time after all.
Previous Topic:Overriding attributes of EStructuralFeature
Next Topic:ECP Views Extension
Current Time: Sun Jul 27 01:55:37 EDT 2025
Powered by FUDForum. Page generated in 0.50900 seconds
