Home » Modeling » Papyrus » Ecore to UML/MARTE mapping
Ecore to UML/MARTE mapping [message #1241976] Sat, 08 February 2014 16:18 Go to next message
I would like to map an Ecore model to a UML/MARTE model(a model with stereotypes).
Technically, is it possible?
Amina
Re: Ecore to UML/MARTE mapping [message #1242516 is a reply to message #1241976] Sun, 09 February 2014 13:08 Go to previous messageGo to next message
'map' could mean many things.
You can convert Ecore to UML (with stereotypes) using the conversion
option in the Ecore Editor Tool Bar menu.
Ed Willink
On 08/02/2014 21:18, amina magd wrote:
> Hello,
> stereotypes). Technically, is it possible?
> Best regards, Amina
Re: Ecore to UML/MARTE mapping [message #1242560 is a reply to message #1242516] Sun, 09 February 2014 14:54 Go to previous messageGo to next message
Hi Ed Willink,
I mean by mapping, in this case, model to model mapping
If i use the conversion option in the Ecore Editor Tool Bar menu, i will be able to add ,if needed, information to the obtained UML model? Or shall i create a template to be able to add data after mapping?
Thanks a lot for your reply
Amina,
Re: Ecore to UML/MARTE mapping [message #1242966 is a reply to message #1242560] Mon, 10 February 2014 05:22 Go to previous messageGo to next message
Still no idea what you mean by mapping.
Eclipse has a variety of model to model transformation tools that work
with UML stereotypes.
Ed Willink
On 09/02/2014 19:54, amina magd wrote:
> Hi Ed Willink,
> Best regards, Amina,
Re: Ecore to UML/MARTE mapping [message #1258906 is a reply to message #1242966] Thu, 27 February 2014 17:05 Go to previous messageGo to next message
Hi Ed Willink,
In fact, i wanted to convert a UML/MARTE model to a meta-model Ecore.
I have already begun this by following these steps:
-I used papyrus under Eclipse Kepler to create a UML/MARTE class diagram (representing a design pattern)
-I created a new EMF Project
-In the next step 'model importers', I selected UML model.
-After that i selected the uml file (previously created) from the system for the 'Model url'
After that, two files are generated : model.ecore and model.genmodel
The classes existing in the UML/MARTE model are converted to the Ecore file, but the attributes and stereotypes offered by MARTE and annotating the UML/MARTE diagram are lost
Is there any problem in the conversion that i used ?
Any help please,
Thanks for reply and help,
Re: Ecore to UML/MARTE mapping [message #1259233 is a reply to message #1258906] Fri, 28 February 2014 01:43 Go to previous messageGo to next message
If it doesn't do what you want you have a problem.
There are many processing options for the converter; perhaps you used
the wrong ones. And before you ask, I don't know where they are
documented. You need to use your intuition/empirical discovery.
Ed Willink
On 27/02/2014 22:05, amina magd wrote:
> Hi Ed Willink,
> I have already begun this by following these steps: -I used papyrus
> a design pattern) -I created a new EMF Project
> -In the next step 'model importers', I selected UML model. -After that
> 'Model url'
> Any help please, Thanks for reply and help,
> Best regards,
Re: Ecore to UML/MARTE mapping [message #1259381 is a reply to message #1259233] Fri, 28 February 2014 05:11 Go to previous messageGo to next message
There exists a standard UML-to-Ecore converter (Which handles a subset of UML, i.e. ~ Class Diagrams), but I'm not aware of any "UML/Marte to Ecore" converter. At least, it doesn't exist in Papyrus.
Papyrus provides the Marte profile, as well as a few customizations for manipulating (Creating & Viewing) Marte-profiled UML models.
Camille
Re: Ecore to UML/MARTE mapping [message #1259390 is a reply to message #1259381] Fri, 28 February 2014 05:23 Go to previous messageGo to next message
Hi Camille,
I am using Papyrus under Eclipse Kepler, so the converter doesn't exist even under eclipse?
Thanks for reply,
Amina
Re: Ecore to UML/MARTE mapping [message #1259394 is a reply to message #1259390] Fri, 28 February 2014 05:30 Go to previous messageGo to next message
It may exist. But not within the Papyrus Project.
Many tools are built on top of Papyrus, so maybe one of them provides a "UML/Marte to Ecore" converter. But it seems very unlikely.
Ed wasn't mentionning such a tool; he was just mentionning a generic "UML to Ecore" converter, which has absolutely no support for Profiles/Stereotypes.
Camille
Re: Ecore to UML/MARTE mapping [message #1259401 is a reply to message #1259394] Fri, 28 February 2014 05:39 Go to previous messageGo to next message
Hi Camille,
In that case, i think that i should create my own template for UML/MARTE 2 Ecore conversion
Thank you Camille and Ed Willink
Amina
[Updated on: Fri, 28 February 2014 05:40] by Moderator
Re: Ecore to UML/MARTE mapping [message #1259517 is a reply to message #1259394] Fri, 28 February 2014 08:26 Go to previous message
Hi Camile
In so far as Profiles/Stereotypes extend classes, UML2Ecore supports
them. Just look at all the Ecore Profile add-ons in the UML meta-model.
Ed Willink
On 28/02/2014 10:30, Camille Letavernier wrote:
> Regards,
> Camille
Previous Topic:Stereotype "display place" appearance property
Next Topic:Any developments regarding Profile/Stereotype styling?
Current Time: Sun Jul 20 21:36:32 EDT 2025
Powered by FUDForum. Page generated in 0.09521 seconds
