File too long error [message #903247] |
Wed, 22 August 2012 12:55  |
Dear,
I am getting the below exception when trying to run ant build script i am getting file name too long exception . I tried to reduce the file name even getting the same exception.
I tried to search but found the this was an existing issue in eclipse.. if the file name is too long then we get this exception and the issue would be solved by changing eclipse plugin .. even that plugin change did not work for me.
the exception i am getting is as below.
Buildfile: C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml
init:
generateJAXB:
[echo] Generating JAXB classes for C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\WebContent\xsd\magiccbxsd\LciTrunkMisceqReply.xsd
[jaxbgen] JAXB generation started.
[xjcTask] Consider using <depends>/<produces> so that XJC won't do unnecessary compilation
[xjcTask] Compiling file:/C:/Users/chalh1/AppData/Local/Temp/jaxb-schema8004715255483005954.xsd
[xjcTask] removing old output files
[xjcTask] Writing output to C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\src
[jaxbgen] JAXB generation ended.
compileJAXB:
[javac] C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 11 source files to C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\build\classes
22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener taskFinished
WARNING:
ARNING:
iadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: Error running C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe compiler
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:525)
at org.apache.tools.ant.taskdefs.compilers.JavacExternal.execute(JavacExternal.java:61)
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:1134)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:912)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:390)
at org.apache.tools.ant.Target.performTasks(Target.java:411)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.eclipse.ant.internal.launching.remote.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.eclipse.ant.internal.launching.remote.InternalAntRunner.run(InternalAntRunner.java:424)
at org.eclipse.ant.internal.launching.remote.InternalAntRunner.main(InternalAntRunner.java:138)
Caused by: java.io.IOException: Cannot run program "C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe": CreateProcess error=206, The filename or extension is too long
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
at java.lang.Runtime.exec(Runtime.java:593)
at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:862)
at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:481)
at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:495)
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:522)
... 19 more
Caused by: java.io.IOException: CreateProcess error=206, The filename or extension is too long
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:81)
at java.lang.ProcessImpl.start(ProcessImpl.java:30)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
... 24 more
22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener targetFinished
ARNING: 22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener targetFinished
nished
... 19 more
... 24 more
BUILD FAILED
C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: Error running C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe compiler
FUDForum. Page generated in 0.03435 seconds
