Home » Eclipse Projects » Remote Application Platform (RAP) » JAAS set-up
JAAS set-up [message #125249] Tue, 17 March 2009 08:12 Go to next message
I'm trying to set up authorization and authentication in a RAP project,
using JAAS. I'm having trouble setting the platform up though.
The RAP target platform doesn’t include the org.eclipse.equinox.security
plugins. I installed them there manually (hoping it would be alright to do
so), and it solves a few issues, but now I’m having access restriction
problems with several classes that Eclipse is resolving in the
javax.security packages. For example, for the Callback class (with import
javax.security.auth.callback.Callback), I get:
Access restriction: The type Callback is not accessible due to restriction
on required library C:\Program Files\Java\jdk1.6.0_07\jre\lib\rt.jar
How should I set everything up to be able to use JAAS in a RAP application?
Thank you :-) Keep up the great work!
Tiago
Re: JAAS set-up [message #125294 is a reply to message #125249] Tue, 17 March 2009 09:50 Go to previous messageGo to next message
Try to add the package of this type Callback in the plugin manifest under
"Imported Packages" in the Dependencies Tab of the manifest editor.
I hope it works, i had a simular problem with an other Class.
best regards,
p-lex
Re: JAAS set-up [message #125332 is a reply to message #125294] Tue, 17 March 2009 11:15 Go to previous messageGo to next message
Originally posted by: roland.muecke.itemis.de
> under "Imported Packages" in the Dependencies Tab of the manifest editor.
If you add the plugin org.eclipse.equinix.security unter "Required
plugins" and enable option "Reexport this dependency" you get the import
of "javax.security.auth.callback" and many other imports for free.
Wheter this is a good idea may be debatable, but it eases developement
of JAAS login modules.
If the access restriction problem persists check your execution
environment. Maybe it is not sufficient to provide the javax.security
packages (see http://www.eclipsezone.com/eclipse/forums/t97259.html).
Roland Mücke
Consultant & Coach
itemis AG
Niederlassung Leipzig
Ludwig-Erhard-Straße 51
04103 Leipzig
Rechtlicher Hinweis:
Registergericht: Amtsgericht Dortmund HRB 20621
Sitz der Gesellschaft: 44536 Lünen, Am Brambusch 15-24
Vorstand: Wolfgang Neuhaus, Jens Wagener, Dr. Georg Pietrek
Aufsichtsrat: Prof. Dr. Burkhard Igel (Vorsitzender), Stephan Grollmann,
Michael Neuhaus
Re: JAAS set-up [message #125342 is a reply to message #125332] Tue, 17 March 2009 11:46 Go to previous messageGo to next message
p-lex, Roland, thank you for your replies. I experimented with both your
hints, but the javax.security.* packages do not appear as options in the
Imported Packages dialog in either way. I tried adding them manually in
the MANIFEST.MF file, but even though Eclipse did not complain about it, I
still have the same issue.
My execution environment for this plug-in is OSGI/Minimum-1.1. Thank you
for the link Roland, I will investigate.
Re: JAAS set-up [message #125834 is a reply to message #125342] Fri, 20 March 2009 11:56 Go to previous messageGo to next message
Still no luck. Apparently OSGI/Minimum-1.1 is not sufficient, and CDC
would be. Is this a valid workaround? Will I be able to deploy the plug-in
onto an equinox container?
TIA,
Tiago
Re: JAAS set-up [message #125918 is a reply to message #125834] Mon, 23 March 2009 07:55 Go to previous messageGo to next message
>> you for the link Roland, I will investigate.
> plug-in onto an equinox container?
I think so. Depending on the installed JRE your equinox may support even
JavaSE-1.6.
Roland
Roland Mücke
Consultant & Coach
itemis AG
04103 Leipzig
Michael Neuhaus
Re: JAAS set-up [message #126145 is a reply to message #125918] Tue, 24 March 2009 12:07 Go to previous messageGo to next message
Thank you Roland.
I am getting closer, changing the execution environment to CDC Foundation
(1.1) gave me access to some classes (e.g ILoginContext and
LoginContextFactory in org.eclipse.equinox.security.auth).
I still don't have access to Callback, CallbackHandler or
UnsupportedCallbackException, for example.
I am requiring the plug-ins org.eclipse.equinox.security and
org.eclipse.equinox.security.ui. Are there others that I should require?
I find it interesting that other people have managed to implement this use
case without mentioning these issues, there must be something I have
overlooked.
Thank you,
Tiago
Re: JAAS set-up [message #126221 is a reply to message #126145] Wed, 25 March 2009 06:41 Go to previous message
> Foundation (1.1) gave me access to some classes (e.g ILoginContext and
Maybe you should check your project settings, especially the JRE System
Library in the Java Build Path. The Execution Environment specified in
MANIFEST.MF does not influence which JDK eclipse uses for compliling.
In order to use JAAS you need at least JDK 1.4.2.
Roland
Roland Mücke
Consultant & Coach
itemis AG
04103 Leipzig
Michael Neuhaus
Previous Topic:Adding link to browser bookmarks
Next Topic:SingleSourcing - Replacement of Widget.notifyListeners
Current Time: Sat Jul 19 03:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.03418 seconds
