Home » Eclipse Projects » Eclipse Platform » On the use of Workspace and WorkManager API
On the use of Workspace and WorkManager API [message #1258331] Thu, 27 February 2014 04:18 Go to next message
I was facing some troubles with an eclipse based product, I had the following exception raising at product startup:
	org.eclipse.core.runtime.AssertionFailedException: assertion failed: Operation was not prepared.
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
	at org.eclipse.core.internal.resources.Workspace.beginOperation(Workspace.java:297)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1971)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1957)
	at org.eclipse.jdt.internal.core.JavaModelManager$19.run(JavaModelManager.java:4733)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Sometimes it raises from the JavaModelManager.run and sometimes from another job (e.g. AutoBuildJob). The problem was our misuse of the WorkManager checkin/checkout, beginUnprotected/endUnprotected methods. It took me a while to understand that I should rather use workspace.prepareOperation / beginOperation instead of a checkin.
This misuse led to an Assert.isTrue(false) in the org.eclipse.core.internal.resources.Workspace.beginOperation(boolean) method:
	public void beginOperation(boolean createNewTree) throws CoreException {
		WorkManager workManager = getWorkManager();
		workManager.incrementNestedOperations();
		if (!workManager.isBalanced())
			Assert.isTrue(false, "Operation was not prepared.");
		if (workManager.getPreparedOperationDepth() > 1) {
			if (createNewTree && tree.isImmutable())
				newWorkingTree();
			return;
The WorkManager documentation says Quote:
" ...This class also tracks operation state for each thread that is involved in an operation. This includes prepared and running operation depth, auto-build strategy and cancel state."
But I still don't understand completely what is the semantics behind the WorkManager fields:
org.eclipse.core.internal.resources.WorkManager.preparedOperations
and org.eclipse.core.internal.resources.WorkManager.nestedOperations ?
And what is the meaning of an unbalanced WorkManger (workManager.isBalanced() == false) ?
Re: On the use of Workspace and WorkManager API [message #1258348 is a reply to message #1258331] Thu, 27 February 2014 04:38 Go to previous messageGo to next message
Comments below.
On 27/02/2014 10:19 AM, El Arbi Aboussoror wrote:
> at
> at
> at
> at
Why are you needing to use such internal methods directly? Can't you
use API like WorkspaceJob or WorkspaceModifyOperation instead?
> method:
> CoreException {
> newWorkingTree();
> return;
Re: On the use of Workspace and WorkManager API [message #1258413 is a reply to message #1258348] Thu, 27 February 2014 06:04 Go to previous message
It was a legacy code and we were facing memory leak problems due to the reference to workspace that was hold by the WorkspaceJob.
Previous Topic:Security Preferences
Next Topic:Problem update with proxy server
Current Time: Wed Jul 23 05:24:25 EDT 2025
Powered by FUDForum. Page generated in 0.05975 seconds
