Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » GMF using Teneo resources with the JPOX backend
GMF using Teneo resources with the JPOX backend [message #125815] Wed, 11 June 2008 18:16 Go to next message
Hi!
I'd like to know whether the GMF Editor Tutorial for Hibernate should work
using JPOX (with a few modifications) as well? Are there any known
incompatibilities?
Florian
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: GMF using Teneo resources with the JPOX backend [message #125828 is a reply to message #125815] Wed, 11 June 2008 18:29 Go to previous messageGo to next message
Hi Florian,
It won't be possible to store the gmf diagram in a database using jpox because to store a GMF
diagram the system also needs to persist the ecore model and the GMF base objects and these can not
be enhanced (which is required for jpox).
Storing only the data should work though.
gr. Martin
DI Florian Hackenberger wrote:
> Hi!
> incompatibilities?
> Cheers,
> Florian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: GMF using Teneo resources with the JPOX backend [message #125841 is a reply to message #125828] Thu, 12 June 2008 06:53 Go to previous message
Martin Taal wrote:
> Hi Florian,
> because to store a GMF diagram the system also needs to persist the ecore
> model and the GMF base objects and these can not be enhanced (which is
> required for jpox).
Ok, that's quite convincing.
Are there howtos available for this task?
Thanks for answering!
Florian
www.hackenberger.at
Re: GMF using Teneo resources with the JPOX backend [message #619243 is a reply to message #125815] Wed, 11 June 2008 18:29 Go to previous message
Hi Florian,
gr. Martin
> Hi!
> incompatibilities?
> Cheers,
> Florian
The Netherlands
Re: GMF using Teneo resources with the JPOX backend [message #619244 is a reply to message #125828] Thu, 12 June 2008 06:53 Go to previous message
Martin Taal wrote:
> Hi Florian,
> required for jpox).
Florian
www.hackenberger.at
Previous Topic:GMF using Teneo resources with the JPOX backend
Next Topic:Resource.load is emptying all resources
Current Time: Thu Oct 23 00:29:24 EDT 2025
Powered by FUDForum. Page generated in 0.04317 seconds
