Intro CVS [message #124691] |
Mon, 16 March 2009 07:46  |
the intro support seems to be in CVS, but I can't get it to work. I think I
did everthing that is needed (intro extension with binding to a branding,
created an IIntroPart, added "welcome" command to my menu).
The intro does not show up (I deleted workspace before) and the action is
grayed out.
Is there still something missing that I need to do, or is it not fully
implemented yet?
Markus
Re: Intro CVS [message #125553 is a reply to message #125495] |
Wed, 18 March 2009 08:00   |
Hi Markus,
there are several ways to open an intro. On the one side automatically
by the workbench (which itself has several ways to do that) or manually
via the IIntroManager.
There was a little oversight of me in one of the the mechanisms of the
first way which is now fixed in CVS. Sorry for the inconvenience!
Could you try it again with latest CVS?
Cheers
Benny
Markus Krüger wrote:
> Hi Rüdiger,
> yes, I tried exactly this. No intro at all.
> Regards,
> arkus
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
> news:gpp2ni$m2t$1@build.eclipse.org...
>> Markus,
>> did you try the simple example that is linked in the new & noteworthy [1]
>> entry?
>> HTH
>> Rüdiger
>> [1] http://www.eclipse.org/rap/noteworthy/news_12M6.php#Workbenc h
>>> Hello,
>>> I did everthing that is needed (intro extension with binding to a
>>> branding, created an IIntroPart, added "welcome" command to my menu).
>>> grayed out.
>>> implemented yet?
>>> Regards,
>>> Markus
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Intro CVS [message #125849 is a reply to message #125770] |
Fri, 20 March 2009 18:07   |
Hi Markus,
I'm really sorry but I won't have time to look at this before
EclipseCon. Please open a bug and I'll take care of it for M7.
Thanks!
Benny
> Hmmm,
> there seems to be a problem rap is opened wihtout the call to a branding.
> Uses the demo and add an intro with the "tea" branding. Now openening the
> "tea-party" everything works good, but if I open "rap?startup=default" I get
> a NullPointerException when creating the IntroAction at line 64 as there
> seems to be no Intro for the default rap entrypoint.
> Regards,
> Markus
> Stacktrace:
> !ENTRY org.eclipse.rap.ui.workbench 4 2 2009-03-19 12:52:12.000
> !MESSAGE Problems occurred when invoking code from plug-in:
> "org.eclipse.rap.ui.workbench".
> !STACK 0
> at org.eclipse.ui.internal.IntroAction.<init>(IntroAction.java:64)
> at org.eclipse.ui.actions.ActionFactory$10.create(ActionFactory .java:342)
> at
> org.eclipse.rap.demo.DemoActionBarAdvisor.makeActions(DemoAc tionBarAdvisor.java:87)
> at
> org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(A ctionBarAdvisor.java:147)
> at
> org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(Workb enchWindow.java:3394)
> at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:363)
> at
> org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchWindow(Workbench3xImplementation.java:29)
> at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1765)
> at org.eclipse.ui.internal.Workbench.access$11(Workbench.java:1 763)
> at
> org.eclipse.ui.internal.Workbench$55.runWithException(Workbe nch.java:3438)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
> at
> org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:119)
> at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
> at
> org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 455)
> at
> org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
> at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
> at
> org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
> at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:3435)
> at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:2165)
> at org.eclipse.ui.internal.Workbench.access$26(Workbench.java:2 150)
> at org.eclipse.ui.internal.Workbench$45.run(Workbench.java:2001 )
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1939)
> at
> org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:181)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:783)
> at
> org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1430)
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.Workbench.init(Workbench.java:1425)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2404)
> at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 95)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:514)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:497)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
> at org.eclipse.rap.demo.DemoWorkbench.createUI(DemoWorkbench.ja va:42)
> at
> org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
> at java.lang.Thread.run(Thread.java:595)
> at
> at
> at
> at
> at
> org.eclipse.ui.internal.Workbench$16.runWithException(Workbe nch.java:1043)
> at
> at
> at
> at
> at
> org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
> at
> org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:1041)
> at
> org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1888)
> at
> org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1824)
> at
> org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.ui 4 0 2009-03-19 12:52:12.515
> !MESSAGE Unhandled event loop exception
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 2009-03-19 12:52:13.511::WARN: /rap
> org.eclipse.swt.SWTException: Invalid thread access
> at org.eclipse.swt.SWT.error(SWT.java:2572)
> at org.eclipse.swt.SWT.error(SWT.java:2492)
> at org.eclipse.swt.SWT.error(SWT.java:2463)
> at org.eclipse.swt.widgets.Widget.error(Widget.java:832)
> at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:762)
> at org.eclipse.swt.widgets.Composite.getChildren(Composite.java :105)
> at
> org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:49)
> at org.eclipse.rwt.lifecycle.WidgetUtil.find(WidgetUtil.java:19 7)
> at
> org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readF ocusControl(DisplayLCA.java:531)
> at
> org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readD ata(DisplayLCA.java:316)
> at org.eclipse.rwt.internal.lifecycle.ReadData.execute(ReadData .java:26)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLife Cycle(RWTLifeCycle.java:206)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:115)
> "Benjamin Muskalla" <bmuskalla@eclipsesource.com> schrieb im Newsbeitrag
> news:gpqno6$76u$1@build.eclipse.org...
>> Hi Markus,
>> there are several ways to open an intro. On the one side automatically by
>> the workbench (which itself has several ways to do that) or manually via
>> the IIntroManager.
>> Cheers
>> Benny
>>> Hi Rüdiger,
>>> Regards,
>>> arkus
>>>> Markus,
>>>> [1] entry?
>>>> HTH
>>>> Rüdiger
>>>>> Hello,
>>>>> think I did everthing that is needed (intro extension with binding to a
>>>>> is grayed out.
>>>>> implemented yet?
>>>>> Regards,
>>>>> Markus
FUDForum. Page generated in 0.04528 seconds
