Home » Modeling » OCL » USE_TYPE_CACHES and DYNAMIC_DISPATCH break basic OCL operations?
USE_TYPE_CACHES and DYNAMIC_DISPATCH break basic OCL operations? [message #1257548] |
Wed, 26 February 2014 10:05  |
Hi there,
before I enter the following report to the bugzilla, I want to ask if this is really a bug or maybe reported already. A complete example Project is attached below. In the following, I want to explain only important things.
Consider two classes: "Base" and "Derived". Both have an operation "op() : int" with OCL Body (invocation delegate, LPG). "op()" of "Base" shall simply return "1", "op()" of "Derived" shall return "2". I enable DYNAMIC_DISPATCH in order to enable common object-oriented bahavior, i.e., returning "2", if the object type is "Derived". So, only if this option is enabled, the following query call returns 2.
// create object
Derived m = PackFactory.eINSTANCE.createDerived();
// dynamic invocation (dynamic: result=2, non-dynamic: result=1)
QueryDelegate query1 = queryFactory.createQueryDelegate(m.eClass(),
null, "self.oclAsType(Base).op()");
System.out.println(query1.execute(m, null));
This works fine...
However, consider the following code:
QueryDelegate query2 = queryFactory.createQueryDelegate(m.eClass(),
null, "Set {self}->union(Set {self}).oclAsType(Base).op()");
System.out.println(query2.execute(m, null));
Currently (5.0.0M5), this returns "invalid".
The query works with DYNAMIC_DISPATCH disabled, i.e., "{1}" is returned.
With DYNAMIC_DISPATCH disabled, I expect "{2}".
Investigating this issue leads to the following lines "EvaluationVisitorImpl.visitOperationCallExp":
if (cachedTypeChecker != null) {
C dynamicSourceType = getEvaluationEnvironment().getType(sourceVal);
oper = cachedTypeChecker.getDynamicOperation(dynamicSourceType, oper);
if (oper == null) { // Ambiguous overload
return getInvalid();
The cached type checker is active, so it is using the type checker even for the OCL standard operation "union". However, the type checker returns null... *bang*. Furhter lines which actually handle "union" are not processed any more.
Other questions I have:
Q1: Is it true, that DYNAMIC_DISPATCH is only working with USE_TYPE_CACHES?
Q2: Is it true, that the only reason for USE_TYPE_CACHES is DYNAMIC_DISPATCH? Exist other advantages of using USE_TYPE_CACHES?
Q3: It was a horror for me creating the example project, because it was hard for me enabling both Options. I expected that the following code works:
DelegateEPackageAdapter ePackageAdapter = DelegateEPackageAdapter
.getAdapter(m.eClass().getEPackage());
OCLDelegateDomain delegateDomain = (OCLDelegateDomain) ePackageAdapter
.getDelegateDomain(OCLConstants.OCL_DELEGATE_URI_LPG);
ParsingOptions.setOption(delegateDomain.getOCL().getEnvironment(),
ParsingOptions.USE_TYPE_CACHES, Boolean.TRUE);
EvaluationOptions.setOption(delegateDomain.getOCL()
.getEvaluationEnvironment(),
EvaluationOptions.DYNAMIC_DISPATCH, Boolean.TRUE);
However, there are some issues... the delegate domain is recreated... or whatever, and the options are gone again. If you want to know what I am talking about, just enable those lines in the example project. Dynamic dispatching won't work. Therefore, I had to create own environments and factories (regular, evaluation and OCL domain)... just for two options! Is this a bug, so should my previously mentioned code work?
Attachment: Test.rar
(Size: 13.17KB, Downloaded 161 times)
[Updated on: Wed, 26 February 2014 10:06] by Moderator
Re: USE_TYPE_CACHES and DYNAMIC_DISPATCH breaks basic OCL operations? [message #1257718 is a reply to message #1257548] |
Wed, 26 February 2014 13:21   |
The darker corners of Classic OCL contain problems that are too hard to
solve. This is one of the motivations for re-engineering the Pivot-based
OCL.
In your particular case, I think you a re demonstrating that using Java
Set semantics does not work for nested collections. You should find that
it works with the Pivot evaluator.
Yes. There probably is a Bugzilla waiting to be WONTFIXed once the Pivot
gets promoted from examples quality.
Ed Willink
On 26/02/2014 15:05, Kirsten M. Z. wrote:
> Hi there,
> // create object
> This works fine...
Re: USE_TYPE_CACHES and DYNAMIC_DISPATCH breaks basic OCL operations? [message #1258185 is a reply to message #1257917] |
Thu, 27 February 2014 01:19   |
>> Java Set semantics does not work for nested collections.
> Don't know what you mean exactly... I think, that's a trivial bug, but
> haven't investigated too deep yet.
The problem is equality. Java Sets must observe uniqueness by Java
equality. OCL sets by OCL equality. The classic OCL switches to Java
equality once things nest.
>> This is one of the motivations for re-engineering the Pivot-based OCL.
> Do you really mean re-engeneering the pivot-based OCL, so create a
> "version 2" pivot-based OCL? Or do you mean dumping classic OCL and
> making pivot-based OCL the better choice?
Making the Pivot a better choice.
> The first answer to my questions is almost always like, why not using
> the newer pivot-based. Unfortunately, pivot-based OCL has never been
> an option for me. It is simply too big. It does not work on Android
> devices. It has too many dependencies, so the limit of having 65535
> methods is exceeded by far. My Android device laughed at me, when I
> told him to run that stuff... Using classic OCL is possible on the
> other hand. Too bad that the project has been cancelled.
One of many incomplete activities is the Xtext2LPG grammar
transformation to allow the Pivot-based OCL to use the faster and much
smaller LPG parser. This will probably make substantuial inroads on the
method count.
Ed Willink
Current Time: Fri Jul 18 23:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.05889 seconds
