Home » Eclipse Projects » Subversive » What happened to the 1.7 support?
What happened to the 1.7 support? [message #1236804] Tue, 28 January 2014 00:14 Go to next message
One of the third party repos I use still has a 1.5 server. The 1.7
client support seemed to work fine, but using Luna M4 I can now only use
1.8 and accesses to the server just hang. A quick glance with Wireshark
suggests that a protocol interchange is expected that 1.5 does not support.
Any chance of restoring the 1.7 connectors (or fixing 1.8 to work with 1.5)?
Ed Willink
Re: What happened to the 1.7 support? [message #1238850 is a reply to message #1236804] Sun, 02 February 2014 11:54 Go to previous messageGo to next message
Looks like it's fixed in M5.
Ed Willink
On 28/01/2014 05:14, Ed Willink wrote:
> Hi
> use 1.8 and accesses to the server just hang. A quick glance with
> Wireshark suggests that a protocol interchange is expected that 1.5
> does not support.
> 1.5)?
> Regards
> Ed Willink
Re: What happened to the 1.7 support? [message #1240065 is a reply to message #1238850] Wed, 05 February 2014 11:18 Go to previous messageGo to next message
No it's not. But sometimes it works. TortoiseSVN 1.8.4 seems troubled too.
Checking out afresh with TortoiseSVN 1.7.12 and all is wonderful.
Definitekly seems that allowing a project conversion to 1.8 against a
1.5 server is really bad.
Ed Willink
On 02/02/2014 16:54, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hi
>> does not support.
>> with 1.5)?
>> Regards
>> Ed Willink
Re: What happened to the 1.7 support? [message #1257463 is a reply to message #1240065] Wed, 26 February 2014 08:03 Go to previous messageGo to next message
If you're working with SVN 1.8 connectors and the native one has some issues with SVN 1.5 server support I could suggest you to try using SVN Kit-based one. Also the SVN 1.7 compatible connectors support is not discontinued and both (native and SVN Kit) connectors are available at update sites. Though we will discontinue support of SVN 1.6 compatible conectors soon.
Re: What happened to the 1.7 support? [message #1257499 is a reply to message #1257463] Wed, 26 February 2014 08:51 Go to previous messageGo to next message
TortoiseSVN 1.8 fails as well so I have to use TortoiseSVN 1.7 for this
legacy repo since while the 1.7 support may not be discontinued, the
1.7 options are disabled in the Luna add-in installation window.
Ed Willink
Re: What happened to the 1.7 support? [message #1283467 is a reply to message #1257499] Thu, 03 April 2014 08:57 Go to previous message
Hi Ed,
I tried Subversive in Eclipse Luna M6, in my case connectors discovery didn't even try to start and I'm not sure if it is the Luna's or Subversive's fault.
On the other hand when I used update site's URL directly, I was able to install connectors for SVN 1.6, 1.7 and 1.8.
So, please try using this URL to install SVN 1.7 support.
http://community.polarion.com/projects/subversive/download/eclipse/4.0/update-site/
Subversive Team.
Previous Topic:Subversion on Hudson-3.1.2
Next Topic:Duplication occured
Current Time: Wed Jul 23 20:16:13 EDT 2025
Powered by FUDForum. Page generated in 0.05613 seconds
