Home » Archived » Jubula » How to extend jubula for Pshelf widget (nebula)?
How to extend jubula for Pshelf widget (nebula)? [message #1257358] Wed, 26 February 2014 05:36 Go to next message
Hi all;
I tried to extend pshelf widget (nebula component)But Jubula is not showing green border around it.I just want to check whether the pshelf widget is enabled or not..I deployed my features of my toolkit using upadte site.
Below code is the implementation of my tester class.
public class PshelfTester extends ButtonTester {
* @return the casted Group instance
protected PShelf getPshelf() {
return (PShelf) getRealComponent();
public void rcVerifyText(Boolean selected, String operator)
throws StepExecutionException {
final PShelf pshelfselected = getPshelf();
PShelf pshelf =(PShelf) getEventThreadQueuer()
.invokeAndWait("getSelection", new IRunnable() { //$NON-NLS-1$
public Object run() {
return pshelfselected.getSelection();
Verifier.equals(selected, pshelf.isEnabled());
My componentconfiguration.xml
compSystem xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="../../../org.eclipse.jubula.toolkit.common/resources/xml/ToolkitComponentConfiguration.xsd">
<configVersion>
<majorVersion>1</majorVersion>
<minorVersion>38</minorVersion>
</configVersion>
<toolkitComponent type="org.eclipse.swt.widgets.Canvas" visible="true">
<realizes>guidancer.abstract.Widgets.Canvas</realizes>
<testerClass>org.eclipse.jubula.rc.swt.tester.PshelfTester</testerClass>
<componentClass name="org.eclipse.swt.widgets.Canvas" />
<action name="CompSystem.VerifyText" changed="1.11">
<method>rcVerifyText</method>
<param name="CompSystem.selected">
<type>java.lang.String</type>
</param>
<param name="CompSystem.Operator">
<type>java.lang.Boolean</type>
<defaultValue>equals</defaultValue>
<valueSet>
<element name="CompSystem.Equals" value="equals"/>
<element name="CompSystem.NotEquals" value="not equals"/>
<element name="CompSystem.MatchesRegExp" value="matches"/>
<element name="CompSystem.SimpleMatch" value="simple match"/>
</valueSet>
</param>
</action>
</toolkitComponent>
</compSystem>
i18n.properties File
org.eclipse.swt.widgets.=(SWT) Canvas
But after doing all those I added to update site and installed it in jubula. But jubula could not detect this widget.Any feedback on this will be appreciated .
Re: How to extend jubula for Pshelf widget (nebula)? [message #1259270 is a reply to message #1257358] Fri, 28 February 2014 02:35 Go to previous message
Hi Rajesh,
The best place to look for help on this would be in the jubula rc-dev archives or even the jubula-dev archives. There have been a lot of threads there where we've helped out with extensions. If you don't find any answer in the threads, start a new one in the jubula rc-dev mailing list.
Bear in mind as well that you can also have the team implement it for you if you want to do it that way [1].
Alex
[1] http://testing.bredex.de/sponsored-development.html
Previous Topic:Store title of tab
Next Topic:Jubula 7.2 - missing Toolbar
Current Time: Mon Jul 21 04:11:20 EDT 2025
Powered by FUDForum. Page generated in 0.06596 seconds
