FormPage in Visual Editor problem [message #125576] |
Sun, 04 June 2006 18:09  |
Originally posted by: andrey.batyuk.net
Greetings,
I've tried to edit FormPage subclass in Visual Editor:
public class PersonSummaryPage extends FormPage {
private FormToolkit formToolkit; // @jve:decl-index=0:visual-constraint=""
public PersonSummaryPage(String id, String title) {
super(id, title);
// TODO Auto-generated constructor stub
public PersonSummaryPage(FormEditor editor, String id, String title) {
super(editor, id, title);
protected void createFormContent(IManagedForm managedForm) {
FormToolkit toolkit = managedForm.getToolkit();
ScrolledForm form = managedForm.getForm();
form.setText("Empty FormPage");
Composite body = form.getBody();
toolkit.paintBordersFor(body);
On attempt to open this class in visual editor i get the following error
message in status bar:
java.lang.NoSuchMethodException(org.eclipse.ui.forms.editor. FormPage. <init>())
And the following error in .log:
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2506)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2437)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1927)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1831)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1766)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1574)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:876)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:854)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:626)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1089)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1126)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:902)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
What could be the cause of this?
Re: FormPage in Visual Editor problem [message #613016 is a reply to message #125616] |
Mon, 05 June 2006 11:19  |
I took a closer look. It is a current restriction. FormPage can't be
subclassed because it doesn't have a default constructor (one that takes
no arguments). You can open an enhancement against VE to be able to
handle this.
Rich Kulp wrote:
> What version of VE, GEF, EMF, and Eclipse are you using?
> Rich
Rich Kulp
Re: FormPage in Visual Editor problem [message #613020 is a reply to message #125641] |
Mon, 05 June 2006 16:21  |
No, i tried that. That won't work either because FormPage expects a
FormEditor to be set on it. The problem is there is no FormEditor set on
it and so it thows NullPointerExceptions whenever you try to anything
with the FormPage.
Andrey Batyuk wrote:
> Will do.
> But what if i make a subclass of FormPage with default constructor, and
> then subclass it? Will it work? (Sorry for newbie question, i'm not yet
> familiar with VE)
Rich Kulp
Re: FormPage in Visual Editor problem [message #613022 is a reply to message #125667] |
Mon, 05 June 2006 16:25  |
> with the FormPage.
Ok, but how do i design form pages in designer then? Create a form, design
it and copy source to form page?
Or any other workaround?
Re: FormPage in Visual Editor problem [message #613024 is a reply to message #125690] |
Mon, 05 June 2006 18:46  |
I don't know. I've never created a FormPage. I don't know what is
expected. There isn't any examples in the base Eclipse on what a
FormPage implementation looks like.
>> on it and so it thows NullPointerExceptions whenever you try to
>> anything with the FormPage.
> design it and copy source to form page?
Rich Kulp
FUDForum. Page generated in 0.57431 seconds
