Home » Eclipse Projects » Eclipse Platform » splash screen problem
| splash screen problem [message #125533] |
Tue, 09 September 2003 11:00  |
When we execute eclipse through batch file, I am not getting splash screen.
Please help me.
MorPheus
| Re: splash screen problem [message #126541 is a reply to message #126320] |
Wed, 10 September 2003 11:11   |
Originally posted by: dorian.birsan.net
Chris has already answered it, it is the eclipse.exe that displays the
splash screen, but you are bypassing eclipse.exe by calling the Main class
directly.
-Dorian
"Smith" <mmahudeeswaran@selectica.com> wrote in message
news:bjms8f$5p7$1@eclipse.org...
> yes, obviously it launches the virtual machine,
> because the contents of my batch file is
> java -classpath startup.jar org.eclipse.core.launcher.Main
> Everything is working except the splash screen.
> Please help
> Regards,
> Smith
> "Chris Laffra" <Chris_Laffra@oti.com> wrote in message
> news:bjktcc$93o$1@eclipse.org...
> > The splash screen is shown by the eclipse.exe program.
> > This program launches the VM (does what your batch file does).
> > It also listens to the VM process. If it returns with a restart request
> > the VM is restarted (happens when update manager is run).
> > If the VM crashes, the exe presents you with the famous (and not
> > really helpful) message to check the .log file in your workspace.
> > If it is really so smart, why doesn't it show the log file to me???
> > Chris
> > "MorPheus" <rgurupackiam@selectica.com> wrote in message
> > news:bjkplt$4mq$2@eclipse.org...
> > > Hi
> > screen.
> > > Please help me.
> > > Thanks,
> > > MorPheus
| Re: splash screen problem [message #126662 is a reply to message #126541] |
Wed, 10 September 2003 13:39   |
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
> directly.
Actually (at least if I've read the code right), the sequence is:
* eclipse starts java and sets the 'splash' options
* java startup of eclipse, splash handler is called via
System.something()
* splash handler puts up the splashscreen
* splash prozess is killed, when eclipse has started up.
The only thing is, that 'eclipse(.exe)' is startup and splash screen
handler in one. On linux, you can observe it via repeated 'ps aux |grep
eclipse' calls during startup.
So, do this call:
java -cp ... Main -showsplash "$ECLIPSE_DIR/eclipse.exe -showsplash 600"
(note the quotes: '$ECLIPSE_DIR/eclipse.exe -showsplash 600' must be one
string!)
That's at least how I do it in the debian startscript for eclipse,
which uses the binary launcher only for splash screen.
Jan
| Re: splash screen problem [message #127065 is a reply to message #126662] |
Wed, 10 September 2003 21:12   |
"Jan Schulz" <muelleimer@usenet.katzien.de> wrote in message
news:slrnbluoe3.8nq.muelleimer@snoopy.katzien.de...
> Hallo!
class
> > directly.
> System.something()
> So, do this call:
> string!)
I think this works only when the configuration (.config) exists and no
(implicit) restart is needed.
I've been wrong before, so I don't claim this is correct :-)
-Dorian
> Jan
| Re: splash screen problem [message #127104 is a reply to message #127065] |
Wed, 10 September 2003 22:11   |
Hallo!
>> string!)
'.config'? You mean '.metadata' and subdirs? I just tested it with
'eclipse -data test' and it works like a charm: first the 'completing
install' and then the normal splash and eclipse window coming up.
..metatdata/.config/platform.cfg* was also there afterwards, showing
everything I expected.
I've code in the startscript, which handles that. Basicly I've done a
rewrite of the eclipse launcher. This was needed to provide a
'eclipse-platform' package, which does not depend on any widget
toolkit (only 'Suggests:'). The splash screen may fail, but eclipse will
still be started up, if only motif libs are available (eclipse is
compiled with '-ws gtk').
I also needed to integrate a $HOME/.eclipse/eclipsrc, which handles some
default values for vmargs, data, window toolkit and some other things,
so that a menu entry can be used.
As far as my testing goes, everything works. The only thing I
couldn't figure out yet was the '-install <path to eclipse>' option.
I've seen that a few times, but I couldn't reproduce it. Its not in
the C code (plugins/platform-launcher/library/eclipse.c)... Any ideas?
Jan
| Re: splash screen problem [message #127687 is a reply to message #127104] |
Thu, 11 September 2003 15:38   |
news:slrnblvmeg.3ld.muelleimer@snoopy.katzien.de...
> Hallo!
600"
one
> >> string!)
I meant the .config directory which used to be inside .metadata, but it is
now (in M3) relocated to the install directory or some place under the
user's home (this work is not finished yet:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37686).
However, as you describe the end result, you've been running an older
driver, so the above comment does not apply.
However, I have tried this on Windows and, with a brand new install, only
the "completing install" shows up, but not the eclipse splashscreen. The
splash showed up fine in the next invocation (once the .config was there).
Nice work!
What doesn't work?
> Jan
| Re: splash screen problem [message #127766 is a reply to message #127687] |
Thu, 11 September 2003 18:27   |
Hallo!
Just to get to know what work will be ahead:
* is now the binary starter given some more 'responsibility', which I
can easily emulate?
* Is there a document describing what's going on internaly? Code
comments, which I can checkout?
* will it be possible to specify some default values (like the described
workspace, ws, vmargs), so that eclipse can be started up from a
menu entry?
It would be nice however if the 'starter' code would be seperated from
the 'splash scree code'. Messages like the 'Error:...' could also be
handled by a XWindow call.
2.1.1 I'm still waiting for the main API changes in RCP before I start
packaging eclipse 3.0.
So it seems that I have to check whether tehr is already a workspace
there, add a option if not, and go on starting :) Hope thats all...
> Nice work!
Thanks!
> What doesn't work?
Nothing doesn't work, so I'm curious, what I miss :)
Jan
| Re: splash screen problem [message #128191 is a reply to message #127766] |
Fri, 12 September 2003 10:27  |
news:slrnbm1tls.24u.muelleimer@snoopy.katzien.de...
> Hallo!
is
> can easily emulate?
> menu entry?
Jan, I'd suggest you'd raise these questions on one of the developer's
mailing lists, such as platform-dev@eclipse.org or
platform-core-dev@eclipse.org , so it is more likely someone who's directly
involved with the startup code can answer.
only
there).
some
> > Nice work!
> Thanks!
> > What doesn't work?
Sorry, can't help, I am not familiar with it.
-Dorian
> Jan
Current Time: Thu Oct 30 16:42:36 EDT 2025
Powered by FUDForum. Page generated in 0.30847 seconds
