Home » Eclipse Projects » Eclipse Platform » console redirection
console redirection [message #124612] Mon, 08 September 2003 19:02 Go to next message
Is there a way I can do console redirection when I run my Java class
files within Eclipse. For example, I want to use a file called
input.txt as my standard input, but typing "< input.txt" in the program
arguments section of my java application configuration doesn't seem to work.
-mike
Re: console redirection [message #125652 is a reply to message #124612] Tue, 09 September 2003 11:56 Go to previous messageGo to next message
> work.
That's because that is operating system/command shell functionality, not
Java functionality.
I would recommend re-writing the app to accept the name of an input file
as an (optional?) parameter. Or write a wrapper that reads the input
file and feeds the underlying app that expects System.in input.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: console redirection [message #125896 is a reply to message #125652] Tue, 09 September 2003 13:48 Go to previous messageGo to next message
>> work.
> Java functionality.
> HTH,
> Eric
i am sure its easier than that. In netbeans their was a launching
context, and you could put your command line options there. Their is
likely a command like option somewhere in Eclipse that launches the
'javaw' command. I dont know where though...
Re: console redirection [message #125933 is a reply to message #125896] Tue, 09 September 2003 13:57 Go to previous message
"CL [dnoyeB] Gilbert" <ThisisFake@Fakeness.xyz> wrote in message
news:pan.2003.09.09.17.48.21.878997@Fakeness.xyz...
> >> work.
> > Java functionality.
> > HTH,
> > Eric
To use java instead of javaw:
See the JRE Tab for your launch configuration.
Specify to launch in an Alternate JRE and then you are able to specify the
Java executable that will be used.
Darins
Previous Topic:Launch delegate classpath problems
Next Topic:Moving a class to another package with Refactor feature?
Current Time: Fri Jul 18 22:26:59 EDT 2025
Powered by FUDForum. Page generated in 0.11092 seconds
