Accessibility [message #664725] |
Mon, 11 April 2011 13:13  |
Is there any specific information about accessibility using RAP? In
particular, I am looking at what keyboard shortcuts are available to
navigate in the interface: for example, how do I select a non-selected
tab (in a CTabFolder) to make it the selected tab? Is that browser
dependent or is that something RAP is providing?
Jean Bovet
Re: Accessibility [message #664742 is a reply to message #664725] |
Mon, 11 April 2011 15:31   |
Hello Jean.
In general all SWT/RWT widgets should be possible to use without the
mouse. However, in case of CTabFolder its key-handling implementation is
still missing in RAP. If you need this specific feature, open an
enhacment request on bugzilla.
Keyhandling in RAP is not browser-dependent. (Some very minor
differences might exit.) Also, you can define your own custom
keybindings (Ctrl/Alt/Shift + any alphanumeric key), which should make
it relatively easy to work around any issues that might still exist for
keyboard-controlling the UI.
We are actually doing some research on RAP and accessibility right now,
though any results are a few months away.
Greetings,
Tim
> Jean Bovet
Re: Accessibility [message #665257 is a reply to message #664742] |
Wed, 13 April 2011 17:32   |
Thanks Tim. I will open an enhancement request for that.
Jean
On 2011-04-11 12:31:02 -0700, Tim Buschtöns said:
> Hello Jean.
> is still missing in RAP. If you need this specific feature, open an
> Greetings,
> Tim
>> Hi,
>> Thanks,
>> Jean Bovet
Re: Accessibility [message #1243797 is a reply to message #1242756] |
Tue, 11 February 2014 08:02   |
Hi Barys,
WAI-ARIA support is not built into the web client directly, but it is
available as a commercial add-on from EclipseSource. This add-on has
been developed to support UI testing frameworks, but it can also be used
for adding accessibility to RAP applications. However, depending on your
application, some features may still be missing.
Please also note that the SWT accessibility API (Accessible,
AccessibleListener, etc.) is not yet implemented in RAP.
If you're interested in the ARIA add-on, please contact us at
info@xxxxxxxx.
Best Regards,
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Accessibility [message #1255814 is a reply to message #1244092] |
Mon, 24 February 2014 16:11  |
Unfortunately, WAI-ARIA addon that we've tried in our application didn't fix accessibility violations but instead introduced dozens more since the use of ARIA tags comes with its own set of guidelines/rules. We realize now that the addon was not designed to provide accessibility coverage but was used for UI testing purposes but it was worth a shot.
This puts even more emphasis on Accessibility: implement real Accessibility API for RAP.
FUDForum. Page generated in 0.17406 seconds
