Home » Eclipse Projects » Remote Application Platform (RAP) » Intro CVS
Intro CVS [message #124691] Mon, 16 March 2009 07:46 Go to next message
the intro support seems to be in CVS, but I can't get it to work. I think I
did everthing that is needed (intro extension with binding to a branding,
created an IIntroPart, added "welcome" command to my menu).
The intro does not show up (I deleted workspace before) and the action is
grayed out.
Is there still something missing that I need to do, or is it not fully
implemented yet?
Markus
Re: Intro CVS [message #125433 is a reply to message #124691] Tue, 17 March 2009 16:55 Go to previous messageGo to next message
Markus,
did you try the simple example that is linked in the new &
noteworthy [1] entry?
HTH
Rüdiger
[1] http://www.eclipse.org/rap/noteworthy/news_12M6.php#Workbenc h
Markus Krüger wrote:
> Hello,
> grayed out.
> implemented yet?
> Regards,
> Markus
Re: Intro CVS [message #125495 is a reply to message #125433] Wed, 18 March 2009 05:58 Go to previous messageGo to next message
Hi R
Re: Intro CVS [message #125553 is a reply to message #125495] Wed, 18 March 2009 08:00 Go to previous messageGo to next message
Hi Markus,
there are several ways to open an intro. On the one side automatically
by the workbench (which itself has several ways to do that) or manually
via the IIntroManager.
There was a little oversight of me in one of the the mechanisms of the
first way which is now fixed in CVS. Sorry for the inconvenience!
Could you try it again with latest CVS?
Cheers
Benny
> Hi Rüdiger,
> yes, I tried exactly this. No intro at all.
> Regards,
> arkus
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
> news:gpp2ni$m2t$1@build.eclipse.org...
>> Markus,
>> did you try the simple example that is linked in the new & noteworthy [1]
>> entry?
>> HTH
>> Rüdiger
>>> Hello,
>>> I did everthing that is needed (intro extension with binding to a
>>> branding, created an IIntroPart, added "welcome" command to my menu).
>>> grayed out.
>>> implemented yet?
>>> Regards,
>>> Markus
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Intro CVS [message #125756 is a reply to message #125553] Thu, 19 March 2009 07:49 Go to previous messageGo to next message
Hin Benjamin,
now it works!
Markus
"Benjamin Muskalla" <bmuskalla@eclipsesource.com> schrieb im Newsbeitrag
news:gpqno6$76u$1@build.eclipse.org...
> Hi Markus,
> there are several ways to open an intro. On the one side automatically by
> the workbench (which itself has several ways to do that) or manually via
> the IIntroManager.
> Cheers
> Benny
> Markus Kr
Re: Intro CVS [message #125770 is a reply to message #125553] Thu, 19 March 2009 07:56 Go to previous messageGo to next message
Hmmm,
there seems to be a problem rap is opened wihtout the call to a branding.
Uses the demo and add an intro with the "tea" branding. Now openening the
"tea-party" everything works good, but if I open "rap?startup=default" I get
a NullPointerException when creating the IntroAction at line 64 as there
seems to be no Intro for the default rap entrypoint.
Markus
Stacktrace:
!ENTRY org.eclipse.rap.ui.workbench 4 2 2009-03-19 12:52:12.000
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.rap.ui.workbench".
!STACK 0
at org.eclipse.ui.internal.IntroAction.<init>(IntroAction.java:64)
at org.eclipse.ui.actions.ActionFactory$10.create(ActionFactory .java:342)
at
org.eclipse.rap.demo.DemoActionBarAdvisor.makeActions(DemoAc tionBarAdvisor.java:87)
at
org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(A ctionBarAdvisor.java:147)
at
org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(Workb enchWindow.java:3394)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:363)
at
org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchWindow(Workbench3xImplementation.java:29)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1765)
at org.eclipse.ui.internal.Workbench.access$11(Workbench.java:1 763)
at
org.eclipse.ui.internal.Workbench$55.runWithException(Workbe nch.java:3438)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:119)
at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 455)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
at
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:3435)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:2165)
at org.eclipse.ui.internal.Workbench.access$26(Workbench.java:2 150)
at org.eclipse.ui.internal.Workbench$45.run(Workbench.java:2001 )
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1939)
at
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:181)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:783)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1430)
at
at
at
at
at
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1425)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2404)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 95)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:514)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:497)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at org.eclipse.rap.demo.DemoWorkbench.createUI(DemoWorkbench.ja va:42)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:595)
at
at
at
at
at
org.eclipse.ui.internal.Workbench$16.runWithException(Workbe nch.java:1043)
at
at
at
at
at
org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
at
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:1041)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1888)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1824)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui 4 0 2009-03-19 12:52:12.515
!MESSAGE Unhandled event loop exception
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
2009-03-19 12:52:13.511::WARN: /rap
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2572)
at org.eclipse.swt.SWT.error(SWT.java:2492)
at org.eclipse.swt.SWT.error(SWT.java:2463)
at org.eclipse.swt.widgets.Widget.error(Widget.java:832)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:762)
at org.eclipse.swt.widgets.Composite.getChildren(Composite.java :105)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:49)
at org.eclipse.rwt.lifecycle.WidgetUtil.find(WidgetUtil.java:19 7)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readF ocusControl(DisplayLCA.java:531)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readD ata(DisplayLCA.java:316)
at org.eclipse.rwt.internal.lifecycle.ReadData.execute(ReadData .java:26)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLife Cycle(RWTLifeCycle.java:206)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:115)
> Hi Markus,
> the IIntroManager.
> Cheers
> Benny
> Markus Kr
Re: Intro CVS [message #125849 is a reply to message #125770] Fri, 20 March 2009 18:07 Go to previous messageGo to next message
Hi Markus,
I'm really sorry but I won't have time to look at this before
EclipseCon. Please open a bug and I'll take care of it for M7.
Thanks!
Benny
> Hmmm,
> Regards,
> Markus
> Stacktrace:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi Markus,
>> the IIntroManager.
>> Cheers
>> Benny
>>> Hi Rüdiger,
>>> Regards,
>>> arkus
>>>> Markus,
>>>> [1] entry?
>>>> HTH
>>>> Rüdiger
>>>>> Hello,
>>>>> think I did everthing that is needed (intro extension with binding to a
>>>>> is grayed out.
>>>>> implemented yet?
>>>>> Regards,
>>>>> Markus
Re: Intro CVS [message #126136 is a reply to message #125849] Tue, 24 March 2009 08:54 Go to previous message
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=269819
news:gq1430$60r$1@build.eclipse.org...
> Hi Markus,
> I'm really sorry but I won't have time to look at this before EclipseCon.
> Thanks!
> Benny
> Markus Kr
Previous Topic:Passing GET Parameters to RAP Applikation
Next Topic:No separator visible on Form
Current Time: Fri Jul 25 21:26:13 EDT 2025
Powered by FUDForum. Page generated in 0.04099 seconds
