Xtext plugin doesn't work.... [message #1240093] |
Wed, 05 February 2014 12:27  |
Hi, i made an xtext based plugin but i got this error and i cannot run the eclipse plugin anymore. This is the output
0 [Worker-1] WARN org.eclipse.xtext.ui.shared.internal.Activator - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
11 [Worker-1] WARN org.eclipse.xtext.ui.shared.internal.Activator - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
2012 [Worker-2] ERROR org.xtext.passi.ui.internal.DocGenActivator - Failed to create injector for org.xtext.passi.DocGen
2017 [Worker-2] ERROR org.xtext.passi.ui.internal.DocGenActivator - Guice creation errors:
1) Error injecting method, java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.containers.JavaProjectsState
at org.eclipse.xtext.ui.shared.Access$InternalProviderForContribution.inject(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:73)
Caused by: java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.containers.JavaProjectsState
at org.eclipse.xtext.ui.shared.internal.SharedStateContributionRegistryImpl.getLazySingleContributedInstance(SharedStateContributionRegistryImpl.java:93)
at org.eclipse.xtext.ui.shared.Access$InternalProviderForContribution.inject(Access.java:59)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.MembersInjectorImpl$1.call(MembersInjectorImpl.java:75)
at com.google.inject.internal.MembersInjectorImpl$1.call(MembersInjectorImpl.java:73)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.MembersInjectorImpl.injectAndNotify(MembersInjectorImpl.java:73)
at com.google.inject.internal.Initializer$InjectableReference.get(Initializer.java:147)
at com.google.inject.internal.Initializer.injectAll(Initializer.java:92)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:173)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at org.xtext.passi.ui.internal.DocGenActivator.createInjector(DocGenActivator.java:67)
at org.xtext.passi.ui.internal.DocGenActivator.getInjector(DocGenActivator.java:55)
at org.xtext.passi.ui.DocGenExecutableExtensionFactory.getInjector(DocGenExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:39)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:77)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:93)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.isValidUri(Storage2UriMapperImpl.java:240)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.getUri(Storage2UriMapperImpl.java:226)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.getUri(ToBeBuiltComputer.java:316)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateStorage(ToBeBuiltComputer.java:258)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer$2.visit(ToBeBuiltComputer.java:233)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:126)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:95)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:52)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:124)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:108)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProject(ToBeBuiltComputer.java:228)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProjectNewResourcesOnly(ToBeBuiltComputer.java:197)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:212)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:89)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:321)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:396)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
at org.eclipse.core.internal.resources.Project.build(Project.java:124)
at org.eclipse.xtext.builder.impl.BuildScheduler$BuildJob.run(BuildScheduler.java:164)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
2) Error injecting method, java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.resource.IStorage2UriMapperJdtExtensions
Caused by: java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.resource.IStorage2UriMapperJdtExtensions
2 errors
com.google.inject.CreationException: Guice creation errors:
2 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:175)
2065 [Worker-2] ERROR org.xtext.passi.ui.DocGenExecutableExtensionFactory - java.lang.RuntimeException: Failed to create injector for org.xtext.passi.DocGen
2067 [Worker-2] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor - Failed to create injector for org.xtext.passi.DocGen ExtensionFactory: org.xtext.passi.ui.DocGenExecutableExtensionFactory
org.eclipse.core.runtime.CoreException: Failed to create injector for org.xtext.passi.DocGen ExtensionFactory: org.xtext.passi.ui.DocGenExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:57)
Caused by: java.lang.RuntimeException: Failed to create injector for org.xtext.passi.DocGen
at org.xtext.passi.ui.internal.DocGenActivator.createInjector(DocGenActivator.java:71)
... 36 more
Caused by: com.google.inject.CreationException: Guice creation errors:
2 errors
... 39 more
2307 [Worker-2] ERROR org.eclipse.xtext.builder.impl.XtextBuilder - The type null is not a valid interface org.eclipse.xtext.resource.IResourceServiceProvider or interface org.eclipse.xtext.resource.IResourceServiceProvider$Provider contributed by org.xtext.passi.DocGen.ui[565]
java.lang.ClassCastException: The type null is not a valid interface org.eclipse.xtext.resource.IResourceServiceProvider or interface org.eclipse.xtext.resource.IResourceServiceProvider$Provider contributed by org.xtext.passi.DocGen.ui[565]
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:57)
3378 [main] ERROR org.xtext.passi.ui.internal.DocGenActivator - Failed to create injector for org.xtext.passi.DocGen
3382 [main] ERROR org.xtext.passi.ui.internal.DocGenActivator - Guice creation errors:
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347)
at org.eclipse.ui.internal.handlers.HandlerProxy.setEnabled(HandlerProxy.java:230)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.canExecute(E4HandlerProxy.java:56)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.canExecute(HandlerServiceImpl.java:110)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.canExecute(HandlerServiceImpl.java:93)
at org.eclipse.ui.internal.MakeHandlersGo.isEnabled(MakeHandlersGo.java:142)
at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.registerLegacyHandler(LegacyHandlerService.java:230)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.readHandlers(LegacyHandlerService.java:791)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.readRegistry(LegacyHandlerService.java:732)
at org.eclipse.ui.internal.Workbench$47.runWithException(Workbench.java:2117)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2533)
at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:2441)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:586)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
2 errors
Re: Xtext plugin doesn't work.... [message #1255418 is a reply to message #1240093] |
Mon, 24 February 2014 07:17  |
Did you find a solution to your problem ?
In my company, we face one of the issue mentioned in your trace:
The type null is not a valid interface org.eclipse.xtext.resource.IResourceServiceProvider or interface org.eclipse.xtext.resource.IResourceServiceProvider$Provider contributed by com.mycompany.blah
This happens when we release our tool (using an Eclipse update site, and building the release with 'Build All' from Eclipse's GUI). In development mode (launched with a run configuration from the Eclipse we develop in), it works fine.
We updated from xtext 2.3 to xtext 2.5 (and java 6 to java 7) recently, it must be related with the problem.
FUDForum. Page generated in 0.04638 seconds
