Home » Eclipse Projects » EclipseLink » Error obtaining the Transaction Manager(jndi lookup fails)
Error obtaining the Transaction Manager [message #1254997] Sun, 23 February 2014 21:10 Go to next message
Using Eclipse 4.3.1, EclipseLink 2.5.0, Glassfish 4.0, and PostgreSQL 9.3.2. The error occurs from JPA Tools->Generate tables from Entities...
persistence.xml:
<persistence version="2.1" ...
persistence/persistence_2_1.xsd">
<persistence-unit name="libkedesign" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>jdbc/libkedesignDS</jta-data-source>
<properties>
<property name="javax.persistence.schema-generation.database.action"
value="create" />
<property name="javax.persistence.schema-generation.scripts.action"
value="drop-and-create" />
<property name="javax.persistence.schema-generation.scripts.drop-target"
value="/src/main/resouece/ld-db-drop.ddl" />
<property name="javax.persistence.schema-generation.scripts.create-target"
value="/src/main/resouece/ld-db-create.ddl" />
<property name="eclipselink.deploy-on-startup" value="true" />
<property name="eclipselink.target-server" value="Glassfish" />
<property name="eclipselink.logging.level" value="FINEST" />
<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
<property name="eclipselink.application-location"
value="/Users/dlibke/Workspaces/MyEclipse Pro 2014/libkedesign/enterprise/domain/src/main/resources" />
<property name="eclipselink.create-ddl-jdbc-file-name"
value="ld-db-createDDL.sql" />
<property name="eclipselink.drop-ddl-jdbc-file-name" value="ld-db-dropDDL.sql" />
</properties>
</persistence-unit>
</persistence>
Stack Trace:
Local Exception Stack:
Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error obtaining the Transaction Manager
Internal Exception: Exception [EclipseLink-23001] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error looking up external Transaction resource under JNDI name [java:appserver/TransactionManager]
Internal Exception: javax.naming.NamingException: Lookup failed for 'java:appserver/TransactionManager' in SerialContext[myEnv={java.naming.factory.initial=com.sun.enterprise.naming.impl.SerialInitContextFactory, java.naming.factory.url.pkgs=com.sun.enterprise.naming, java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl} [Root exception is javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]]
at org.eclipse.persistence.exceptions.TransactionException.errorObtainingTransactionManager(TransactionException.java:125)
at org.eclipse.persistence.transaction.JTATransactionController.<init>(JTATransactionController.java:69)
at org.eclipse.persistence.transaction.glassfish.GlassfishTransactionController.<init>(GlassfishTransactionController.java:36)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at java.lang.Class.newInstance(Class.java:374)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.newInstanceFromClass(PrivilegedAccessHelper.java:417)
at org.eclipse.persistence.platform.server.ServerPlatformBase.initializeExternalTransactionController(ServerPlatformBase.java:295)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.preConnectDatasource(DatabaseSessionImpl.java:775)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:733)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:239)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:681)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:182)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getDatabaseSession(EntityManagerFactoryImpl.java:527)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:140)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:177)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:79)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.buildEntityManagerFactory(Main.java:94)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.execute(Main.java:80)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.main(Main.java:68)
Caused by: Exception [EclipseLink-23001] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
at org.eclipse.persistence.exceptions.TransactionException.jndiLookupException(TransactionException.java:47)
at org.eclipse.persistence.transaction.AbstractTransactionController.jndiLookup(AbstractTransactionController.java:454)
at org.eclipse.persistence.transaction.glassfish.GlassfishTransactionController.acquireTransactionManager(GlassfishTransactionController.java:44)
at org.eclipse.persistence.transaction.JTATransactionController.<init>(JTATransactionController.java:67)
... 21 more
Caused by: javax.naming.NamingException: Lookup failed for 'java:appserver/TransactionManager' in SerialContext[myEnv={java.naming.factory.initial=com.sun.enterprise.naming.impl.SerialInitContextFactory, java.naming.factory.url.pkgs=com.sun.enterprise.naming, java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl} [Root exception is javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]]
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:491)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:438)
at javax.naming.InitialContext.lookup(InitialContext.java:411)
at org.eclipse.persistence.transaction.AbstractTransactionController.jndiLookup(AbstractTransactionController.java:452)
... 23 more
Caused by: javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]
at com.sun.enterprise.naming.impl.JavaURLContext.lookup(JavaURLContext.java:229)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:471)
... 26 more
at com.sun.enterprise.naming.impl.JavaURLContext.lookup(JavaURLContext.java:167)
... 27 more
Exception in thread "main" javax.persistence.PersistenceException: Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:762)
Caused by: Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
... 9 more
... 21 more
... 23 more
... 26 more
... 27 more
What am I missing or have incorrect
Dave
Re: Error obtaining the Transaction Manager [message #1255516 is a reply to message #1254997] Mon, 24 February 2014 09:27 Go to previous message
This is occuring because org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.main(Main.java:68) is being called, which uses the current persistence.xml settings to try and run. Unfortunately the persistence unit is configured to run within Glassfish with a transaction manager, but the code is being executed locally.
You will need to change the persistence unit settings to run outside the glassfish server for table generation to work; you will need to remove the datasource and server definition and then define the javax.persistence.jdbc properties required to connect to the database since there is no datasource available. The properties are shown here:
https://wiki.eclipse.org/EclipseLink/Examples/JPA/Configure
with an example here:
https://wiki.eclipse.org/EclipseLink/Examples/JPA/OutsideContainer
Previous Topic:Future of DBWS webservice generation
Next Topic:Reload Persistence Unit at Runtime
Current Time: Sun Jul 27 07:34:32 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
