Home » Modeling » EMF » How to check if my object state has changed ?
How to check if my object state has changed ? [message #1253585] Sat, 22 February 2014 07:33 Go to next message
So far I'm using the following code to check if my objects where changed:
EContentAdapter adapter = new EContentAdapter() {
public void notifyChanged(Notification notification) {
super.notifyChanged(notification);
eventBroker.post(CommonEvents.TOPIC_MODEL_IS_DIRTY, Boolean.TRUE);
But this is not a real solution. If the users types two character and deletes this two characters (i'm using EMF databinding) I would like to get the info that my model is not dirty anymore. Is this possible ?
[Updated on: Sat, 22 February 2014 07:38] by Moderator
Re: How to check if a model is changed ? [message #1253665 is a reply to message #1253585] Sat, 22 February 2014 09:37 Go to previous messageGo to next message
On 22/02/2014 13:33, Roger Gilliar wrote:
> So far I'm using the following code to check if a model has changed:
> @Override
> deletes this two characters I would like to get the info that the model
As far as EMF goes, the content adapter is at good as it gets. There is
also the (iirc command-stack based) resource.isModified(). Possible to
solve otherwise? I have seen somewhere in Sirius code that they simply
save the model to a temporary file and then check if the files are
equal. Not sure if there's a better solution, it's at least very complex
to check whether a set of changes is actually neutralizes itself. To
begin with, you'd have to record all changes since the last save until
you know you're back at 0, and that might take forever if the user comes
in at 8, and saves once at 5. :)
I also felt incomfortable with this problem once until I realized that
it's more a theoretical issue than something that would affect a user
too much.
Re: How to check if a model is changed ? [message #1253681 is a reply to message #1253585] Sat, 22 February 2014 10:04 Go to previous messageGo to next message
Hi, Roger,
As long as your application consistently uses Commands executed on an
EditingDomain's CommandStack to modify your model instance, then the
CommandStack tracks whether it has been changed from the last saved
state. See how the generated editor for your model implements its
"dirty" property.
HTH,
Christian
> @Override
Re: How to check if a model is changed ? [message #1255779 is a reply to message #1253665] Mon, 24 February 2014 15:23 Go to previous messageGo to next message
I now agree. It is more a theoretical problem.
Re: How to check if a model is changed ? [message #1256101 is a reply to message #1255779] Mon, 24 February 2014 23:58 Go to previous messageGo to next message
A ChangeRecorder is much like a content adapter and it's purpose is to
detect real value changes between the start point and the end point.
But as others have pointed out, in an editor (or anywhere that undo
support is needed), a command stack is very effective.
Re: How to check if a model is changed ? [message #1256251 is a reply to message #1256101] Tue, 25 February 2014 03:42 Go to previous messageGo to next message
> detect real value changes between the start point and the end point. But
> as others have pointed out, in an editor (or anywhere that undo support
Oh, I thought a changerecorder would not be that clever. I thought it
simply accumulates notifications. You say it computes a "total delta"?
I know there's a whole chapter in the book about it, so maybe I'll look
at it again sometime.
Re: How to check if a model is changed ? [message #1256309 is a reply to message #1256251] Tue, 25 February 2014 04:48 Go to previous message
Felix,
Yes, the change recorder effectively remembers the original state as
state changes arrive and then at the end effectively compares the final
state to the original state to compute a description of any actual
deltas. So it is not just an event recorder...
> look at it again sometime.
Previous Topic:[XCORE] How to make feature readonly with xcore
Next Topic:To fragment an EMF model and partially load the model
Current Time: Sun Sep 21 12:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
