Home » Eclipse Projects » Eclipse 4 » JFace databinding issues after migration
JFace databinding issues after migration [message #1244718] Wed, 12 February 2014 14:53 Go to next message
I had a small app that used the following to monitor a change in an textfield :
WidgetProperties.text(SWT.Modify).observe(source);
And it worked perfectly (of course I didn't paste all the code)
I update to 4.4M5 and now I have multiple issues with databinding.
- WidgetProperties.text(int event) is deprecated (amongst other)
- PojoObservables class is deprecated,
I have multiple warning about rawtypes, etc...
I also have a stack trace when launching the application (thrown by the WidgetProperties line above). See at the end of the post.
Can anyone point me to a changelog or even a javadoc ?
I couldn't find anything in the milestone bug fix description...
org.eclipse.e4.core.di.InjectionException: java.lang.NoSuchMethodError: org.eclipse.core.databinding.property.value.DelegatingValueProperty.<init>(Ljava/lang/Class;)V
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:958)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:642)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:744)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:715)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:709)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:694)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1219)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:185)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4731)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:208)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:101)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:658)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:67)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:654)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:639)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1047)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1006)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:146)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:165)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:109)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:80)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:372)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:226)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Re: JFace databinding issues after migration [message #1245095 is a reply to message #1244718] Thu, 13 February 2014 04:29 Go to previous messageGo to next message
What version of databinding are you using? For me none of the above are
marked as deprecated! Did you by chance installed the e4 version of
Eclipse Databinding?
Tom
On 12.02.14 20:53, ALex W wrote:
> Hello,
> textfield :
> Thanks
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> at
> at
> at
Re: JFace databinding issues after migration [message #1245359 is a reply to message #1245095] Thu, 13 February 2014 12:49 Go to previous messageGo to next message
Hi Thomas,
Thanks for the answer
I'm using (for instance) BeansObservables from this plugin :
C:\eclipse\eclipse\plugins\org.eclipse.core.databinding.beans_1.5.0.v20130628-1928.jar
And it's reported to me as deprecated...
Same goes for PojoObservables.java from the same jar...
I guess previous version of this Jar was org.eclipse.core.databinding.beans_1.2.200.v20120523-1955
I'm kind of lost here...
Re: JFace databinding issues after migration [message #1245776 is a reply to message #1245359] Fri, 14 February 2014 03:49 Go to previous messageGo to next message
So what did you install? In the platform-git repo [1] we have 1.2.200 -
so it looks like you've installed a different through some other
repository - I think it is the one from e4 [2] where people forked it
for now to add generics to it!
Tom
[1]http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/bundles/org.eclipse.core.databinding.beans/META-INF/MANIFEST.MF
[2]http://git.eclipse.org/c/e4/org.eclipse.e4.databinding.git/tree/bundles/org.eclipse.core.databinding.beans/META-INF/MANIFEST.MF
On 13.02.14 18:49, ALex W wrote:
> Hi Thomas,
Re: JFace databinding issues after migration [message #1251721 is a reply to message #1245776] Thu, 20 February 2014 09:26 Go to previous message
Hi Thomas,
I double checked and during migration, new jface bundle appeared (probably, as you mentionned, the e4 including generics).
I had to modify my plugins dependencies to specify the required version of the bundle.
It looks ok now.
Previous Topic:dynamic command parameter and converter
Next Topic:Exception when using application editor for RCP app.
Current Time: Sat Jul 26 21:01:16 EDT 2025
Powered by FUDForum. Page generated in 0.04372 seconds
