Home » Modeling » QVT-OML » Invalid transformation Problem
Invalid transformation Problem [message #1251680] Thu, 20 February 2014 08:31 Go to next message
I am trying simple HelloWorld QVTO example given at http://www.levysiqueira.com.br/2011/01/eclipse-qvto-hello-world/
When i run transformation. i get the following exception. Any idea why it is so?
Caused by: java.lang.IllegalArgumentException: Invalid transformation HelloWorldTransformation
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.InMemoryQvtLaunchConfigurationDelegate.launch(InMemoryQvtLaunchConfigurationDelegate.java:58)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:884)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlugin.java:1129)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Root exception:
same is the case when i run the default qvt example project Simpleuml To Rdb
Caused by: java.lang.IllegalArgumentException: Invalid transformation Simpleuml_To_Rdb
Root exception:
i am uing Eclipse Version: Luna M5 Release
Build id: 20140130-1145
[Updated on: Thu, 20 February 2014 08:40] by Moderator
Re: Invalid transformation Problem [message #1251813 is a reply to message #1251680] Thu, 20 February 2014 11:22 Go to previous messageGo to next message
Use the SimpleUMLtoRdbms example if you don't know what you'rwe doing.
Ed Willink
On 20/02/2014 13:31, ModelGeek Mising name wrote:
> it is so?
> at
> at
> at
> at
> at
> at
> Root exception:
> at
> at
> at
> at
> at
> at
> Cheers,
Re: Invalid transformation Problem [message #1252820 is a reply to message #1251813] Fri, 21 February 2014 11:39 Go to previous messageGo to next message
I have tried the simpleUMLTORDB example but i get the same exception.
The other problem i have noticed that when i run the transformation and in the run transformation dialog... it keep showing the warning at top "Destination 'platform:/resource/SimpleUML to RDB/Simpleuml_To_Rdb123.rdb' already exists". Although there is no such file exists..
I also wanted to attach the screen shot for the error message but some how the option to attach files is not available on the web interface for forum......
My eclipse is :
eclipse.buildId=4.4.0.I20131030-2000
java.version=1.7.0_03
Root exception:
[Updated on: Fri, 21 February 2014 11:41] by Moderator
Re: Invalid transformation Problem [message #1254672 is a reply to message #1252820] Sun, 23 February 2014 12:33 Go to previous messageGo to next message
The 'already exists' is an irritating but benign warning that crept in
to the Kepler release; now fixed.
Beyond that you'll need to provide much more detailed information and
files since it works fine for developers and many users.
Ed Willink
> such file exists..
> for forum......
> Simpleuml_To_Rdb
> at
> at
> at
> at
> at
> at
> Root exception:
> Simpleuml_To_Rdb
> at
> at
> at
> at
> at
> at
Re: Invalid transformation Problem [message #1255404 is a reply to message #1254672] Mon, 24 February 2014 07:01 Go to previous messageGo to next message
I am trying to attach screen shots and project but attachment panel does not seems to be working as there is no field available in attachment panel... is there any problem with forum's web interface?
Re: Invalid transformation Problem [message #1262114 is a reply to message #1254672] Mon, 03 March 2014 04:23 Go to previous messageGo to next message
I am going to describe in detail.
I am using example project "SimpleUML to RDB". It contains "Simpleuml_To_Rdb.qvto". I select this qvto file in Package Explorer and I go to run menu and select "Transformation" menu option. It brings dialog where i again select "Simpleuml_To_Rdb.qvto" and press "next". It finally brings tranformation dialog.
I have following setting on the dialog :
IN uml: UML(http://www.eclispe.org/qvt/1.0.0/Operational/examples/simpleuml)
Model URI : platform:/resource/SimpleUML to RDB/pim.simpleuml
OUT $1 : RDB(http://www.eclispe.org/qvt/1.0.0/Operational/examples/rdb)
Model URI : platform:/resource/SimpleUML to RDB/Simpleuml_To_Rdb.rdb
so when i press "finish" i get the following exception :
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:422)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:513)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:961)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:996)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:971)
at org.eclipse.debug.internal.ui.DebugUIPlugin.launchInForeground(DebugUIPlugin.java:1137)
at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:768)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.wizards.RunInterpretedTransformationWizard.performFinishBody(RunInterpretedTransformationWizard.java:136)
at org.eclipse.m2m.internal.qvt.oml.common.ui.wizards.PersistedValuesWizard.performFinish(PersistedValuesWizard.java:65)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:851)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:437)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:633)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.actions.RunInterpretedTransformationAction.invokeWizard(RunInterpretedTransformationAction.java:57)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.actions.RunInterpretedTransformationAction.runImpl(RunInterpretedTransformationAction.java:42)
at org.eclipse.m2m.internal.qvt.oml.common.ui.action.WindowActionDelegate.run(WindowActionDelegate.java:50)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:588)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:505)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:415)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1006)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:146)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:615)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:109)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:80)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:372)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:226)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Am i doing anything wrong here?
I have been trying to attach project and screen shots but attachment seems to be disabled....
cheers,
[Updated on: Mon, 03 March 2014 04:28] by Moderator
Re: Invalid transformation Problem [message #1262142 is a reply to message #1262114] Mon, 03 March 2014 05:00 Go to previous messageGo to next message
I have just realized that if i run "SimpleUML to RDB.launch" by right clicking and selecting the option "Run As"-> "Simple UML to RDB" then it works and it creates "Simpleuml_To_Rdb.rdb" in the project.
what is the difference between running the launch file and running the transformation using Run->Transformation menu option through transformation dialog?
Re: Invalid transformation Problem [message #1262174 is a reply to message #1262114] Mon, 03 March 2014 05:36 Go to previous messageGo to next message
What versions are you using?
I see no "Transformation" menu option on a *.qvto file. Might it be an
ATL or Xtend or ... option?
I see only Run As->Run Configurations... QVTo Interpreter
Use Alt+Shift+F2 to see who is contributing it.
Ed Willink
> IN uml:
> Simpleuml_To_Rdb
> at
> at
> at
> at
> at
> at
> cheers,
Re: Invalid transformation Problem [message #1262226 is a reply to message #1262174] Mon, 03 March 2014 06:49 Go to previous messageGo to next message
I have tried the Alt + Shift + F2 and it says
The active contribution item identifier:
org.eclipse.m2m.internal.qvt.oml.runtime.ui.wizards.RunInterpretedTransformationActionId
The active action set identifier:
org.eclipse.m2m.qvt.oml.runtime.actions
Eclipse Standard/SDK
For me i have main menu option Run->Transformation. To activate this, i have to select qvto file in package expolrer. It brings a dialog where it asks to select the qvto file again and then comes main transformation dialog where i have to give IN and OUT parameters.
[Updated on: Mon, 03 March 2014 06:51] by Moderator
Re: Invalid transformation Problem [message #1262252 is a reply to message #1262226] Mon, 03 March 2014 07:25 Go to previous messageGo to next message
Thanks (you didn't make it clear that you were using Toolbar Run)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=429449 raised.
Ed Willink
> Cheers,
Re: Invalid transformation Problem [message #1262401 is a reply to message #1262252] Mon, 03 March 2014 10:49 Go to previous message
thank you so much! I really appreciate your help
Previous Topic:Transformations chaining for inout model
Next Topic:Research survey to improve quality of QVTo code
Current Time: Thu Sep 11 02:49:12 EDT 2025
Powered by FUDForum. Page generated in 0.07807 seconds
