Home » Modeling » EMF » Model Migration(References of models are not migrated within model migration)
Model Migration [message #1250862] Wed, 19 February 2014 12:22 Go to next message
I have one project in which there are two models- Model A and Model B.
Model A is referring Model B.(Example- Model A uses segment "TEST" which is present in Model B.)
Then I transformed these models from one form to another form using model to model transformation. And those got transformed successfully.(Model A and Model B are migrated from one form to another form.)
However,
(Model A uses segment "TEST" from Model B) - references of segment "TEST" (which is present in Model B) is not updated in Model A after transformation.
So, do I need to do something additional to resolve this issue?
Please suggest.
Thanks in advance.
Re: Model Migration [message #1250917 is a reply to message #1250862] Wed, 19 February 2014 13:31 Go to previous messageGo to next message
Bhushan,
Comments below.
On 19/02/2014 7:07 PM, Bhushan Patil wrote:
What do you mean bu uses segment "TEST"?
> another form.)
And serialized somehow...
> However,
> transformation.
The URI references you see in the serialization always reflect the URI
of the referenced resource at the time the serialization was produced.
It's not clear what the issue is, but if you're serializing the
transformed resources to a new location, be sure to change the URI of
both resources before saving either.
> Please suggest.
> Thanks in advance.
Re: Model Migration [message #1251527 is a reply to message #1250917] Thu, 20 February 2014 05:05 Go to previous messageGo to next message
Hi Ed,
Thanks for your reply.
What do you mean by uses segment "TEST"?
--> I mean - Model A refers to element "TEST" which is present in Model B.
The issue is -
When Model A and Model B are transformed from one form to another form, the location of element "TEST" in Model B gets changed.
But Model A still refers to OLD location of element "TEST" (which is not available in Model B after transformation.)
Please suggest - what should do I need to do to resolve this issue?
Thanks.
Re: Model Migration [message #1251579 is a reply to message #1251527] Thu, 20 February 2014 06:18 Go to previous messageGo to next message
Bhushan,
Comment below.
On 20/02/2014 11:05 AM, Bhushan Patil wrote:
> Hi Ed,
> Model B.
> The issue is - When Model A and Model B are transformed from one form
What does model A refer to in memory at the time it's serialized?
It's a question of what A is referring to at the time it's serialized
and what the URI of the referenced resource is at that time. But I can
know nothing about that from what you've said.
> Thanks.
Re: Model Migration [message #1252653 is a reply to message #1251579] Fri, 21 February 2014 07:59 Go to previous messageGo to next message
Hi Ed,
I have two models - Model-A and Model-B with specific meta-models structure. Model-A contain one element ElementTypeA and Model-B contains another element ElementTypeB.
ElementTypeB has some attributes one of which (is of type ElementTypeA) "refer" to ElementTypeA. This means Model-B is referring Model-A.
If I open Model-B using text editor then I can see this relationship (relative href is used for referencing)
Now my meta-model has got changed. So I have transformed Model-A and Model-B from OLD meta-models structure to NEW meta-models structure using model to model transformation (QVTo).
My assumption is if I open both these models and invoke a QVTo (models passed as inout params) to perform "model-migration" EMF should appropriately take care of reference changes.
Following code will give better idea of how I am opening models.
// open Model-A using resourceset
private EList<EObject> getResourceObjects(final IFile file) {
ResourceSet resourceSet = new ResourceSetImpl();
URI resourceUri = URI.createPlatformResourceURI(file.getFullPath()
.toString(), false);
return resourceSet.getResource(resourceUri.trimFragment(), true)
.getContents();
// open Model-B using resourceset
same as above just pass path of Model-B
// perform transformation
transformation UpdateModels(inout model:ModelAorB);
// save Model-B and Model-A one after the other
for (EObject eObj : outObjects) {
Resource targetResource = resourceSet
.createResource(file.getFullPath());
targetResource.getContents().add(eObj);
List<Resource> resList = resourceSet.getResources();
for (Resource res : resList){
res.save(Collections.EMPTY_MAP);
But in reality this is not working and references are not getting resolved properly. So when I open Model-B and expect that it is referring to Model-A appropriate element - its not the case. Sad
Re: Model Migration [message #1252834 is a reply to message #1252653] Fri, 21 February 2014 11:50 Go to previous message
Bhushan,
Comments below.
On 21/02/2014 1:59 PM, Bhushan Patil wrote:
> Hi Ed,
> contains another element ElementTypeB. ElementTypeB has some
So you transformed tw
> toString(), false);
> getContents();
But not using the same resource set. That seems like a bad idea,
especially if you plan to transform both A and B.
So A and B are in different resource sets so model B will be referring
to a different copy of A than the one you are transforming.
> for (EObject eObj : outObjects) { Resource targetResource = resourceSet
You're creating more than one resource with the same URI?
> resolved properly.
No doubt because the transformed B refers to the untransformed A that's
in B's resource set.
> appropriate element - its not the case. :(
If you used the debugger wisely, you'd have noticed that B is referring
to a different A than the one you transformed.
Previous Topic:[CDO] disable commit info.
Next Topic:EMF Compare FeatureNotFoundException
Current Time: Wed Jul 23 19:43:05 EDT 2025
Powered by FUDForum. Page generated in 0.07980 seconds
