Home » Archived » BIRT » different styles for pdf and html
different styles for pdf and html [message #124672] Mon, 06 February 2006 04:50 Go to next message
Originally posted by: stefano.comarin.primeur.com
my problem is that fonts are bigger in HTML output than in PDF output so
I want to apply different styles to report elements based on the output
format: is there a simple way to do this? If not, it would be a great
feature for the next release :)
I think I could use a parameter to specify the output format and set a
different library of styles based on the parameter, is it possible?
Stefano
Re: different styles for pdf and html [message #125125 is a reply to message #124672] Tue, 07 February 2006 03:38 Go to previous messageGo to next message
It seems that there isn't a simple solution to this problem so I decided
to create two libraries or two different themes in my library. Does
anyonw know how to change the library or the theme at runtime (probably
in the beforeRender method) ?
Stefano
Stefano Comarin wrote:
> Stefano
Re: different styles for pdf and html [message #126225 is a reply to message #125125] Wed, 08 February 2006 11:40 Go to previous message
If it's not possible to set the library or theme with scripting, at
least how can I set the font size of a style at runtime?
Stefano
> Stefano
>> Hi,
>> so I want to apply different styles to report elements based on the
>> output format: is there a simple way to do this? If not, it would be a
>> great feature for the next release :)
>> Thanks,
>> Stefano
Previous Topic:Reg : How to the chart report into diffrent pages
Next Topic:BIRT Report Viewer in my application
Current Time: Tue Jul 29 02:16:02 EDT 2025
Powered by FUDForum. Page generated in 0.64048 seconds
