Home » Archived » Visual Editor (VE) » Visual editor not able to write the code returned by the custom property editor
Visual editor not able to write the code returned by the custom property editor [message #125047] Fri, 19 May 2006 02:32
Originally posted by: rashmi_h_r.rediffmail.com
Hi All,
I am facing a problem with the custom property editor that I have written
for my custom widgets property list. The type of the property that I am
trying to edit is a double dimension String array. All the other property
editors which are used to edit a simple string/list are working fine. The
'getJavaInitialization()' method is called for them. Only in the property
editor with the complex data type (Double dimension String array) the
getJavaInitialization() method is not called.
'getAsText()' method is called directly and anything returned from that
method is not reflected (written) on to the code in the Editor window.
The string returned from the 'getAsText()'method for the property is
visible correctly as the cell value in the Properties View, but nothing is
being written to the code in the Editor window.
The return string from the 'getAsText()' Method is of the form as given
below
return "new String [][]{{\"ssss\",\"ssss\"}}";
When I explicitly invoke the 'setValue()' method from getAsText() method
of the property editor class with a dummy value, the string is written to
the code in the editor window. Also, explicit invocation of the
'setValue()' method is not advised in the API.
The cust6om property editor for a double dimensional string array that I
have implemented is working fine in another IDE. I have also tried
clearing all the bean info cache (from
..metadata\.plugins\org.eclipse.jem.beaninfo and
..metadata\.plugins\org.eclipse.core.resources\.projects\<yourproject >\org.eclipse.jem.beaninfo).
But it is still not working.
Can anybody please help me in this regard?
I could post code in case needed.
Thank you and Best Regards,
Rashmi H.R
Previous Topic:VE doesn't display components in the Palette menu
Next Topic:Visual editor not able to write the code returned by the custom property editor
Current Time: Sat Nov 08 02:36:12 EST 2025
Powered by FUDForum. Page generated in 0.03284 seconds
