| Problems during startup....but no .log [message #125038] |
Fri, 05 December 2003 17:44   |
Eclipse User  |
After restarting Eclipse 2.1.2 on Linux RH 9 I am getting "Prolbmes during
startup, Check the ".log" file in the ".metadata" directory of your
workspace."
Now I am not new to Eclipse, I know where the .metadata directory is, I
know where the .log normally is so that isn't the problem.   There is NO
log file to Check.
The heaviest lifting done today was a build after setting debug="on" and
debuglevel="lines,vars,source" in my build.xml and running ant with no
errors.  I shutdown Eclipse when I went to lunch and got the error when I
returned.  No configuration changes, new plugins, etc.
What now?
Ollie
| Re: Problems during startup....but no .log [message #125051 is a reply to message #125038] |
Fri, 05 December 2003 17:52   |
Eclipse User  |
> workspace."
> log file to Check.
> What now?
> Ollie
Try Try again,
Just tried one more time for grins, and it did give me a .log file this
time.
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Dec 05, 2003 15:28:21.209
!MESSAGE Exception launching the Eclipse Platform:
!STACK
	at
	at
	at java.lang.reflect.Method.invoke(Method.java:324)
	at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
	at org.eclipse.core.launcher.Main.run(Main.java:747)
	at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.RuntimeException: Fatal Error: Unable to locate
matching org.eclipse.core.runtime plug-in.
	at
 org.eclipse.core.internal.boot.PlatformConfiguration.locateD efaultPlugins(PlatformConfiguration.java:2264)
	at
org.eclipse.core.internal.boot.PlatformConfiguration.<init>(PlatformConfiguration.java:903)
	at
 org.eclipse.core.internal.boot.PlatformConfiguration.startup (PlatformConfiguration.java:1368)
	at
 org.eclipse.core.internal.boot.InternalBootLoader.initialize (InternalBootLoader.java:582)
	at
 org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1035)
	at
 org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
	at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
	... 7 more
Still same question, what now?
Ollie
FUDForum. Page generated in 0.29964 seconds
