Home » Modeling » OCL » Pivot Setting Deletegate and oclIsKindOf operation problem
Pivot Setting Deletegate and oclIsKindOf operation problem [message #1081487] Wed, 07 August 2013 05:31 Go to next message
I have a very simple model with very simple ocl statement containing oclIsKindOf.
When i try to parse the statement, it works fine but when i try to evaluate using setting delegates i get
org.eclipse.ocl.common.internal.delegate.OCLDelegateException: 'Property::CompatibleDefaultExpression' constraint is not satisfied for 'Property attribute'
at org.eclipse.ocl.examples.pivot.delegate.AbstractDelegatedBehavior.validate(AbstractDelegatedBehavior.java:243)
at org.eclipse.ocl.examples.pivot.delegate.OCLSettingDelegate.get(OCLSettingDelegate.java:68)
at org.eclipse.emf.ecore.util.BasicSettingDelegate$Stateless.dynamicGet(BasicSettingDelegate.java:185)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1027)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
is this a bug in pivot evaluation?
regards,
Re: Pivot Setting Deletegate and oclIsKindOf operation problem [message #1081494 is a reply to message #1081487] Wed, 07 August 2013 05:43 Go to previous messageGo to next message
I have found the problem and have fixed it
thanks
Re: Pivot Setting Deletegate and oclIsKindOf operation problem [message #1249833 is a reply to message #1081494] Tue, 18 February 2014 12:30 Go to previous messageGo to next message
May I ask you how you fixed?
I have a model in a GMF-based editor that I need to select (click on) some relations before having the validator correctly evaluating some attributes of instances of the related class. The stacktrace is the same you had, maybe the issue is the same, too.
Thanks!
Re: Pivot Setting Deletegate and oclIsKindOf operation problem [message #1250349 is a reply to message #1249833] Wed, 19 February 2014 01:32 Go to previous message
HI
The original problem had at its heart
so I suspect the user fixed the bad property default.
Ed Willink
> Thanks!
Previous Topic:Dos/Don'ts for OCLinEcore/Pivot?
Next Topic:How to exploit OCL constraints on derived features?
Current Time: Sat Jul 26 03:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.04582 seconds
