Home » Modeling » EMF » EMF Compare FeatureNotFoundException
EMF Compare FeatureNotFoundException [message #1248834] Mon, 17 February 2014 13:03 Go to next message
Hi, I'm getting a
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found.
when I try to compare 2 xmi files with Emf Compare.
I'm kind of a beginner with this but I'm having a lot of trouble trying to fix this issue. Here's the code :
public static void compare() {
EPackage.Registry.INSTANCE.put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
// Load the two input models
ResourceSet resourceSet1 = new ResourceSetImpl();
ResourceSet resourceSet2 = new ResourceSetImpl();
URI uri = URI.createFileURI(new File("xmi/test1.xmi").getAbsolutePath());
URI uri2 = URI.createFileURI(new File("xmi/test2.xmi").getAbsolutePath());
resourceSet1.getPackageRegistry().put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
resourceSet2.getPackageRegistry().put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
resourceSet1.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XmiResourceFactoryImpl());
resourceSet2.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XmiResourceFactoryImpl());
resourceSet1.getResource(uri, true);
resourceSet2.getResource(uri, true);
// Configure EMF Compare
IEObjectMatcher matcher = DefaultMatchEngine.createDefaultEObjectMatcher(UseIdentifiers.NEVER);
IComparisonFactory comparisonFactory = new DefaultComparisonFactory(new DefaultEqualityHelperFactory());
IMatchEngine.Factory matchEngineFactory = new MatchEngineFactoryImpl(matcher, comparisonFactory);
matchEngineFactory.setRanking(20);
IMatchEngine.Factory.Registry matchEngineRegistry = new MatchEngineFactoryRegistryImpl();
matchEngineRegistry.add(matchEngineFactory);
EMFCompare comparator = EMFCompare.builder().setMatchEngineFactoryRegistry(matchEngineRegistry).build();
// Compare the two models
IComparisonScope scope = EMFCompare.createDefaultScope(resourceSet1, resourceSet2);
ICompareEditingDomain editingDomain = EMFCompareEditingDomain.create(resourceSet1, resourceSet2, null);
AdapterFactory adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
@SuppressWarnings("restriction")
CompareEditorInput input = new ComparisonScopeEditorInput(new CompareConfiguration(),
editingDomain, adapterFactory, comparator, scope);
CompareUI.openCompareDialog(input);
and the exception :
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found. (file:/C:/Users/Maxime/Documents/Documents/IUT/XMIGraph/xmi/test1.xmi, 6, 70)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at compare.Compare.compare(Compare.java:90)
at compare.Compare.main(Compare.java:70)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found. (file:/C:/Users/Maxime/Documents/Documents/IUT/XMIGraph/xmi/test1.xmi, 6, 70)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:1998)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1962)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1906)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 3 more
I'd appreciate some help Smile Thanks !
Re: EMF Compare FeatureNotFoundException [message #1249263 is a reply to message #1248834] Mon, 17 February 2014 23:37 Go to previous messageGo to next message
Pey,
Comments below.
On 17/02/2014 10:02 PM, Pey Max wrote:
> Hi, I'm getting a
> not found.
EMF provides XMIResourceFactoryImpl so what is XmiResourceFactoryImpl?
> CompareConfiguration(), editingDomain, adapterFactory, comparator,
> scope);
> and the exception :
> not found.
> 6, 70)
> at
> at
> at
> 'Model' not found.
> 6, 70)
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 3 more
It's impossible to comment on why your unknown-to-me serialization
doesn't conform to your unknown-to-me model. Can you read and write
instance of your model with the generated editor?
> I'd appreciate some help :) Thanks !
Re: EMF Compare FeatureNotFoundException [message #1249841 is a reply to message #1249263] Tue, 18 February 2014 12:42 Go to previous messageGo to next message
Thanks but I'm gonna need some more help, because I'm really new to EMF and I don't have any idea how to do this :/
Re: EMF Compare FeatureNotFoundException [message #1249854 is a reply to message #1249841] Tue, 18 February 2014 12:55 Go to previous messageGo to next message
Pey,
Is this your own model you've developed yourself? Where did the
serialization you're trying to load come from?
Re: EMF Compare FeatureNotFoundException [message #1249867 is a reply to message #1249854] Tue, 18 February 2014 13:17 Go to previous messageGo to next message
Well I'm working on a project that was created by 4 students two years ago and they developed the model themselves. And the serialization is just something I found on the web.
[Updated on: Tue, 18 February 2014 13:20] by Moderator
Re: EMF Compare FeatureNotFoundException [message #1249876 is a reply to message #1249867] Tue, 18 February 2014 13:25 Go to previous messageGo to next message
Pey,
The serialization must correspond to a model, so if that's not the case
(which sounds like it), then you'll not be able to load it.
On 18/02/2014 7:17 PM, Pey Max wrote:
> Well I'm trying on a project that was created by 4 students two years
Re: EMF Compare FeatureNotFoundException [message #1252759 is a reply to message #1249876] Fri, 21 February 2014 10:23 Go to previous messageGo to next message
What do you mean by "serialization" ?
Re: EMF Compare FeatureNotFoundException [message #1252839 is a reply to message #1252759] Fri, 21 February 2014 11:58 Go to previous messageGo to next message
Pey,
You said "And the serialization is just something I found on the web."
What do you mean by "serialization"? I assumed you meant the XML/XMI
file you're trying to read; it must correspond to a model, e.g., this
UmlPackage model you seem to be using. That appears not to be the case.
Re: EMF Compare FeatureNotFoundException [message #1253017 is a reply to message #1252839] Fri, 21 February 2014 16:29 Go to previous messageGo to next message
Well I actually don't know what is the package for the model I'm using. How do I found out ? I used UmlPackage because I saw a lot of people using it on the web but since the serialization is based on a custom metamodel, I should probably use another ... But I got no idea how to find it.
Re: EMF Compare FeatureNotFoundException [message #1253334 is a reply to message #1253017] Sat, 22 February 2014 00:56 Go to previous message
Pey,
Comments below.
From the namespace. Top level element(s) in the XMI. There must be an
EPackage with an nsURI that corresponds and then the rest of the
serialization must conform the EClasses defined in that model.
Nor do I.
Previous Topic:Model Migration
Next Topic:XSD Importer and FeatureMap
Current Time: Fri Jul 18 18:54:14 EDT 2025
Powered by FUDForum. Page generated in 0.04417 seconds
